2007 Headlight and Taillight outage-Halogen lights
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Brian Murphy, Jun 22, 2013.
  1. Brian Murphy
    Brian Murphy New Member
    I replaced both headlights a few months ago. Last week the left headlight and left taillight burned out. Is there anyone out there that has experienced this problem or is this just a fluke?
  2. nh7o
    nh7o Off grid since 1980
    1,686
    338
    Hawaii
    There has been a similar report or two here. I don't recall if the result was reported back. First thing is to check the 12V system voltage. If it is too high, then you will see reduced life of the lights. Then to check the ground connections for the lights, and make sure they are tight. If loose, the intermittent power can cause spikes that will likewise reduce life span.
  3. stevemcelroy
    stevemcelroy Active Member
    873
    194
    Boulder, CO
    I had a problem with both headlights burning out just a couple of months after they had been installed. I figured that the GE replacement bulbs were bad. The replacements from Sylvania have been just fine.
    Brian Murphy likes this.
