1. Offline
    scramjett New Member
    Start a Conversation
    Jan 9, 2012
    61
    Sacramento, CA
    Your Vehicle Year:
    Hi all,
    New to the forum, but not to the Prius (I got my 2007 Prius brand new nearly 5 years ago). Until recently, it has been a great car. I would typically average about 45 MPG in summer, 43-44 MPG in winter and 48 MPG the rest of the year. However, starting in November (2011) the mileage in the car took a huge nose dive. When we drove down to SoCal, it got horrible mileage. We typically do not get the best mileage on these trips to SoCal, averaging usually around 43 MPG with our worst ever having been about 40. That is, until November. We got our worst ever mileage on this trip of 36 MPG (at the time). At first I thought it was just a fluke, especially when we did a little better on the trip back. I needed to have its 50k service done so I mentioned it to the service folks. After giving every stinking excuse in the book, blaming everything from tire pressure, to gas to anything else you could think of, they performed a health check. They didn't find any problems but as it turned out, the tires were low (~28 psi) but I had filled them up before the SoCal trip. I had chalked it up to a faulty pressure gauge (I had problems with it before) and didn't think anything of it until our Christmas trip. I double checked the tire pressure before leaving and the tires showed about 35 psi on all 4 tires when I left (using a different gauge). However, I once again got horrible gas mileage, worse than the last at 33 MPG!!! I had to stop half way to LA for gas for the first time EVER!!! (Most of the time I am able to make it on a single tank and only 2 or 3 times I had to stop over the grapevine to fill up). When I got to LA, I again checked the tires just to make sure and they STILL showed 35 psi. Elk Grove Toyota had neglected to reset the maintenance light after the service so I reset it myself while in LA. When that happened, the car went back to normal (more on that later) and we averaged 44 MPG on the trip back.
    So after resetting the maintenance light, I thought, "ok, maybe the car went into 'limp home mode' when the maintenance light was on and that was why it behaved the way it did." Wrong! On a trip to Stockton, again, low gas mileage of 33 MPG. I checked the tires with a digital pressure gauge and it showed 31 PSI on all 4 tires. I refilled them to about 37 PSI only to get an average of 36 MPG on the trip back! Since then, it has flip flopped between ok gas mileage of around 43 MPG (I once got 44 MPG coming from Folsom which is mostly downhill) and 36 MPG (which has been mostly typical lately). I have noticed the car doing some odd things which I'll explain after the questionnaire.
    I am filling out the MPG questionnaire since it is required and may help you guys rule out the more common problems (answers in blue):
    - Have you read This Thead Yet?
    Yes
    - What fuel economy are you getting and how are you determining fuel economy? (trip computer or manual calculations)
    Approximately 36 MPG, sometimes closer to 40 or 41 if I'm having a good day. I'm using both.
    - What fuel economy are you expecting and why?
    This time of year, I am expecting around 43 MPG on cold days (~30F in the mornings and ~50F in the afternoon) and closer to 45 MPG on warmer days (afternoons ~60F, mornings same)
    - What are the approximate outside air temps?
    See above
    - How long are your trips?
    The trips to SoCal are around 370 miles. Most other trips are 15 miles one way. Ever since we got the Nissan Leaf, we have rarely used the Prius for short trips (in fact, the problems started after we got the Leaf).
    - How much of it is city vs. highway? Roughly what's the average speed in overall and and of each segment? Is there a lot of stop and go driving?
    It is mostly highway. We generally go around 70 in the Sac area but 75 on our trips to LA.
    - What region/state are you in? (if you haven't set your location in your profile)
    Sacramento, CA
    - What's the terrain like of your drives? (e.g. flat, gentle hills, steep hills, etc.)
    Mostly flat with some gentle hills. On LA trips, there is the grapevine with its steep hills but I usually make up the loss going up on the downhill trip into the LA basin.
    - Is your oil overfilled? (i.e. above the full mark on the dipstick)
    No
    How old is your 12v battery? What is the voltage reading of your 12v battery after sitting over night? (Method Here)
    As old as the car. Voltage reading shows 12.1 Volts after sitting overnight (more on the battery after the questionnaire).
    Have you had your alignment checked? Any pulling or abnormal tire wear?
    No checks on my own (don't know if Elk Grove Toyota checks it). No unusual wear on my last set of tires and no pulling.
    - Are you using the factory tires and wheels? If not, please indicate tire make, model and size (e.g. Goodyear Assurance Fuel Max 185/65R15).
    Kumho Eco Solus HM KR22 P185/65R15. Replaced factory tires in October.
    - What are your tire pressures?
    Last check was on 1/15 and read ~35 psi on 3 tires and ~33 PSI on one. I topped off to 37 PSI on all 4.
    - Make, model, year, engine and transmission of previous car? (e.g. 08 Honda Civic Si 2.0L 4 cylinder, manual transmission) What did you actually get on the same trips/commute? (Please give us actual numbers, not EPA ratings.)
    2005 Mazda 3 2.3L 4 cylinder, manual transmission. Lived in LA at the time but trips between Stockton and LA, also about 360 miles, I averaged about 28 - 29 MPG (my calc).
    - How are you trying to drive (e.g. trying to stay in electric only?) and how hard are you braking?
    I mostly just drive normally, try to accelerate briskly but not aggressively and try to allow myself enough time to brake
    - Are you "warming up" the ICE (internal combustion engine) by letting it idle after powering on?
    No
    - Are you driving using D or B mode?
    Almost always in D mode. I rarely use B mode and its usually on a steep downhill with a relatively full battery
    - HVAC settings? Are you using the heater, AC, auto mode, etc.? If using auto, what temp is it set to?
    When the problem started, we had already stopped using AC. We usually have the temp set to low or around 65 to 68. Low fan speed. AC button is deliberately set to off to keep the compressor from running.
    - If reporting a mileage drop, did anything significant change on your car (e.g. accident, hit a curb or big pothole throwing off alignment, oil change/other maintenance/repairs, changed tires or wheels, etc.) or your commute?
    Changed tires. Also driving car less since we got the Nissan Leaf. But that is not unusual since before our son was born, we used to ride the bus a lot and the car would still sit for long periods of time. It is still driven at least once a week.
    Change in behavior:
    Since the problems started, I've been watching the power flow screen more to observe its behavior and I've noticed that it relies on the gas engine far more than it used to. For example, when going uphill, the engine races and the battery hardly contributes to the overall power. When going up the grapevine, I would typically have the battery drain down to about two bars of charge by the time I reach the top. Since the problem started, I would still have 6 bars of charge at the top! I had noticed that the engine was trying to charge the battery while going uphill even though it was in the green at 7 bars! It was as if the car thought it was on flat land! Also, the Prius normally maintains a charge of 6 bars at highway speed on flat land. Lately, it has been maintaining it at 7 bars in the green zone (see pics below).
    Highway speed pic:
    Hill climbing pic (not a gentle hill but not too steep either):
    I have been checking on the 12 volt battery quite frequently lately using the "hold info flash headlights 4 times" technique after at least 24 hours of the car sitting. It has been at least 12.1 Volts consistently. When putting the car from accessory mode to "on" the voltage drops to about 11.6 - 11.7 volts but then stabilizes at 11.8 - 11.9 volts. When I turn the car on (engine running) the voltage goes up to about 14.1 volts. I had hoped that the problem would be the 12 volt battery but based on what I've read in the forums, these readings are definitely within normal parameters.
    I have pounded the forums relentlessly and googled extensively and I have not found anything that sounds like the problem I am having. If anyone has any idea what the problem might be and how to fix, please tell me!
    PS - Earlier this month, I took the car back to Elk Grove Toyota to have them check it out again. After another "health check" they again found no problems like with the 50k checkup (I had them do a "health check then as well") and the tire pressure was ok (according to their printout). At that time, I had them reset the onboard computer. It doesn't seem to have fixed the problem at all. Please help!
    Thanks,
    Jeff
  2. Offline
    Jan 9, 2012
    61
    Sacramento, CA
    Your Vehicle Year:
    Me again. Let me know if the pics didn't work and I'll try to repost.
    Thanks,
    Jeff
  3. Online
    cwerdna Senior Member
    Sep 4, 2005
    11,801
    1,718
    SF Bay Area, CA
    Your Vehicle Year:
    Thanks for filling out the questionnaire. I believe their "health check" is mainly just a check for codes (DTCs).
    Dumb question, when you're checking your tire pressure, you are checking cold pressures, right? (Tire Tech Information - Air Pressure, Temperature Fluctuations). 35 psi is a bit low on the 2nd gen Prius. I'd recommend at least 38 front and 36 rear.
    You will get worse mileage in the winter, see http://priuschat.com/forums/gen-iii...mileage-gets-worse-in-winter.html#post1411488. Also, do keep in mind the illusion about mpg drops and why we should be looking at gallonage.
    From my experience, people do drive quite fast up in the Sacramento area and people that drive between Nor Cal and So Cal drive pretty fast too (me included). Those high speeds will definitely hurt your mileage, but it's not as bad as you think, if you look at gallonage. See Consumer Reports tests speed vs MPG & comes to false conclusion about Honda Insight 2 - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com and http://priuschat.com/forums/gen-ii-...hy-drop-in-fuel-efficiency-6.html#post1378284.
    When I've done the trip between San Jose and the LA area, IIRC, I end up averaging in the low 40s, definitely not 45 mpg. I think it's a combination of the the hills at the Grapevine, high speeds (speed limit being 70 mph, IIRC and going 70 mph on I-5 == slow) and the hills on part of highway 152 near the San Luis Reservoir.
  4. Offline
    uart Senior Member
    Sep 7, 2009
    2,824
    500
    Australia
    Your Vehicle Year:
    It may be a combination of several minor things that are each just costing one or two MPG.
    - Winter temperatures and winter gas. Though I think you've already taken these into consideration. (BTW. They haven't increased the ethanol content of your gas recently have they?)
    - The battery is a bit weak, but probably just within normal range. Usually if they're holding close to 12.0 at ig-on they're ok. Maybe the battery is weak enough to be playing a small part in this.
    - You might be losing a couple of MPG due to the new tires.
    - Your driving pattern may have changed subtly since you got the leaf. You may be doing a greater percent of high speed freeway trips in the Prius and somewhat less of slower "local traffic" trips. That might hurt the averages a bit.
    1 people like this.
  5. Offline
    Jan 9, 2012
    61
    Sacramento, CA
    Your Vehicle Year:
    Hi cwerdna,
    Yes, that is essentially what I got from their explanation of a health check. Yes, I am checking the cold pressure. I usually try and check tire pressure on a day when I haven't driven the car yet so it has had 12 - 24 hours to reach ambient temp. Also, in my crazy engineer's head, I try and fill the tires so that they are at manufacturer spec (35/33) during the coldest part of the day. For example, if low of the day is 30F and it is 60F in my garage, I will fill the tires to 38/36, although lately I have been filling all four tires the same at Elk Grove Toyota's suggestion so in this case it would be 38 psi for all four tires. (No worries about it being a "dumb question," I believe that their is no such thing as a dumb question).
    As for the mileage in winter and on trips to LA, I never expect really good mileage. Generally in winter because of the cold and weather, I get around 42 to 43 MPG and in previous winters have not gotten worse than that. This is the first time I've ever been consistently below 40 MPG. Same with my trips to LA. I think the mileage on LA trips using I5 has to do with a combination of speed, hills (especially the grapevine), and the fact that it is frequently very windy (I call that stretch of I5 the wind tunnel, especially the stretch between 205 and 580). I haven't heard of gallonage, I'll have to look into that.
    What has boggled my mind is the cars behavior. The Prius has always coddled the battery but lately it won't even use it on hill climbing and acceleration. I don't know if my pictures came through, but in it, you can see the car is maintaining charge in the battery while I'm climbing a hill, even though it is already in the green zone! (7 bars of charge). On my recent trip to Monterey when I climbed over Pacheco Pass on 152, it barely used the battery. The charge dropped from 7 bars of charge (green) to 6 bars (blue). At one point, the electric motor was powering the wheels AND charging the battery! (NOT powering the motor!) I've only ever seen it do that when the charge level is low, like 2 or 3 bars (pink or low blue). It's also very random. This morning when I drove into work, it was mostly back to normal behavior (seems like it fixes itself after I do a battery check, go figure). Has anyone heard of a Prius doing that? Any ideas why? This type of behavior started before EG Toyota reset the onboard computer in case anyone was wondering.
    Thanks,
    Jeff
  6. Offline
    12,706
    1,814
    Your Vehicle Year:
    why not put in a new optima battery and see if that helps? you're gonna need one sooner or later. cheap money compared to the rest of your options.
    1 people like this.
  7. Offline
    uart Senior Member
    Sep 7, 2009
    2,824
    500
    Australia
    Your Vehicle Year:
    You could also give it test with/without any heat or air-cond just to see if anything weird is happening there.
    Also, though it's normally a warm weather problem, you should check the HV battery cooling fan to make sure it's not clogged. Next time it's playing up try this test, stop the car but leave it ready (in "P") then go around to the rear seat and listen for the fan running.
    BTW. When the car's warmed up, does the engine still cut out (at least after 7 to 10 seconds) after you stop.
  8. Offline
    Jan 9, 2012
    61
    Sacramento, CA
    Your Vehicle Year:
    Hi uart,
    Love the pic! :)
    Last time I checked, the ethanol content has been 10% which I believe has been that way in California for 10 years at least.
    Do you think that even though the battery is on the low end of the normal range that it might still be causing the cars weird behavior? And why it seems to fix itself each time I do a battery check?
    Losing mileage due to the new tires is something that had crossed my mind. It didn't escape my notice that this started around the same time I got the tires but I've since ruled that out. I'm well past the break in period for them and I would think that the new tires would only cause a small drop, like maybe 0.5 MPG. But maybe, as you pointed out, it's a combination of things.
    That is a definite possibility, we had become more aware of the Prius's engine after getting the Leaf. However, we live in a suburban area with high speed limits. We usually get better mileage on the freeway because in the suburban area, we are usually doing high speed stop and go due to the higher speed limits (around 45 mph) and frequent traffic lights. Also, this is not the first time the Prius has seen limited use. When we used to ride the bus a lot, the Prius would spend much of its time sitting in the garage as well. On the other hand, we'd use it for errands on the weekend which is what we primarily use the Leaf for now. So, while we've always used it for mostly highway driving, you could say that it is driven on the highway even more so now. We still tend to meet or exceed the EPA highway mileage figure of 45 MPG though, especially on a clear day in winter since we barely use the heater and I go out of my way to avoid using the defroster.
    Thanks for your feedback! :)
    Jeff
  9. Offline
    Jan 9, 2012
    61
    Sacramento, CA
    Your Vehicle Year:
    Hi Bisco,
    Yeah, it may come to that. I've read a few threads here that said their Prius was getting bad mileage and determined it to be related to the 12 V battery. I was really hopeful that the 12 V was the source of my problem but it had been testing consistently at about 12.1 Volts which folks here say is normal. The only thing that seemed abnormal was the drop to about 11.5 V when switching to ig-on but then it stabilizes to about 11.8 or 11.9 V which I also read was normal (though on the lower side of normal). I'm not really wanting to spend the $200 to replace the battery (but I am seriously considering the optima when I do) but if I can't figure out any other cause, I may give that a shot.
    Thanks for the feedback!
  10. Offline
    Jan 9, 2012
    61
    Sacramento, CA
    Your Vehicle Year:
    Hmmm, hadn't considered the battery fan. It could explain why the Prius is behaving the way it is, protecting the battery more than usual. I'll try that on my drive home this evening and see what happens.
    Yes, once warmed up, the engine does cut out after its normal 7 - 10 second run time.
  11. Offline
    uart Senior Member
    Sep 7, 2009
    2,824
    500
    Australia
    Your Vehicle Year:
    Yeah some of your symptoms do seem like a traction battery issue. Of course it could be that the actual battery (HV) is failing, but hopefully it's something simpler. The first summer that I owned the Prius (bought S/H) the traction battery was running too hot due to a clogged fan and yeah it was noticeable that it tried to use the battery a lot less. In my case however I picked up on it pretty quickly because the rear vent fan started getting pretty loud as it was working hard trying to pump air (but getting almost none). If yours is quiet then maybe it's not spinning at all (which is actually normal most of the time in cold weather, but if the battery is not in the best of health it still could be getting hot).
    See my photos on checking the fan here (reply #31): http://priuschat.com/forums/gen-ii-...ur-dirt-causing-major-battery-problems-4.html
    1 people like this.
  12. Offline
    Jan 9, 2012
    61
    Sacramento, CA
    Your Vehicle Year:
    Yeah, I hope it is a simple thing like the battery fan. Is there a way to test the HV battery itself? EG Toyota claims they tested it but I really have no way of knowing if they did or did not.
  13. Offline
    qbee42 My other car is a boat
    Mar 2, 2006
    18,043
    2,918
    Northern Michigan
    Your Vehicle Year:
    I probably missed it in your post, but how many miles are on your Prius?
    On the face of it, it sounds like your HV battery is developing a bad cell. Since this is a difficult thing to diagnose until you get a failure, it makes sense to first try and eliminate all of the less costly possibilities, as suggested in the other posts.
    Tom
  14. Offline
    6lark5 New Member
    Dec 6, 2011
    28
    San Jose, CA
    Your Vehicle Year:
    Your auxiliary battery is probably on its way out. When I put an Optima in my '06, it made a huge difference in mileage.
    Your elevated speed didn't help, especially on the hills.
    You could inflate your tires a bit more. 42/40psi is common.
    In the winter don't use the heater above 68F.
    Do you upper grill block in the winter?
    What actual brand/grade of gas?
    What oil weight? ?w??
  15. Offline
    Jan 9, 2012
    61
    Sacramento, CA
    Your Vehicle Year:
    Hi Tom,
    It is currently at about 53,000 miles. I have ruled out most things but I'm going to take a look at the HV battery fan as uart suggested. Failing that, I'm going to try replacing the 12 V before I'm ready to face the possibility of a bad cell in the HV battery (and trying to convince EG Toyota that the problem is with the HV battery who will no doubt vehemently deny that there is a problem at all). I'm hopeful that the HV battery is fine and that the problem lies somewhere else.
  16. Offline
    Jan 9, 2012
    61
    Sacramento, CA
    Your Vehicle Year:
    Hi 6lark5,
    I was hoping to put this off until late spring early summer. I am hoping that the aux battery is not the problem especially since it's reading at about 12.1 V in acc mode. However, as others have suggested, that is on the low end of spec and may be contributing.
    No, it doesn't, but this is the worst I've gotten by far (at least it was until the December trip). As an example, when I drove to LA back in October before the problem started, I averaged about 42 - 43 MPG driving around 78 - 80 MPH (I always look at it as a compromise in milage to minimize the rather long mundane trip). When I went down in November, I was far easier on the gas pedal than I normally am because of traffic (night before Thanksgiving) and so cruised at 70 until about Santa Nella and then kicked it up to about 75 when traffic eased up, yet I averaged 36 MPG!! I looked at my past mileage records and I usually average at least 5 MPG more than that at the same time of year, and I'm pretty sure the weather was milder this past November than November 2010.
    I prefer to keep it around 37 - 38 psi so the tires will wear a bit more evenly. I also don't want to take the risk that they could get overinflated in summer when we get our triple digit temps (since our garage is usually about 30F cooler than outside air).
    We're cold weather people. The heater is rarely, if ever, higher than that.
    No, I just recently learned about that, but I figure California winters were not cold enough to warrant that technique. If I ever live in Truckee, I'll probably give that a go. But until then, I probably won't practice that.
    Shell/87 Octane
    If EG Toyota is not using 5W30, I'll have words with them.
  17. Offline
    12,706
    1,814
    Your Vehicle Year:
    on the other hand, if it was the hv battery, it's under warranty!
  18. Offline
    Aug 14, 2006
    18,295
    3,517
    Sacramento, CA.
    Your Vehicle Year:
    Regarding the tires. I sure hope you are checking them more than once a season.
    Even at 38psi now you will be safe by summer due to lost air over the next 3-4months.
    You could easily inflate the tires to 44/42 now and adjust the pressure as temps warm up.
    As for the wear, well most of us have found that the tires wear more evenly on the Prius when run above manufacture specs. It's up to you.
    I agree with your original mpg from EG to LA. At approx. 80-85mph I tend to average 42mpg on the same trip. The one time I was crazy enough to do 65-70mph I got 50mpg. Your trip at 36mpg is definitely not right.
  19. Offline
    Mar 27, 2004
    7,642
    839
    United States
    Your Vehicle Year:
    No sense hobbling yourself: run the tires at 42/40 front/rear or higher and see what happens. Check them at least monthly, if not more often.
  20. Offline
    6lark5 New Member
    Dec 6, 2011
    28
    San Jose, CA
    Your Vehicle Year:
    Did you change your tires before or after your October trip?
    What pressure did you run the old tires?
    Your old tires were probably more "LRR" and bald then your new tires. Bald Goodyear Integrity tires give great mileage (assumed make/model). F8L is the tire guru in this neck of the woods.
    I live in the Bay Area and upper grill block from November on usually (80% upper blocked). I never block below the bumper, because the lower part of the radiator is used by the inverter in Gen 2s. I remove my grill blocking usually no later then May. You can grill block EVEN IN Sacramento.
    Full upper and lower grill blocking is common back east (where its below freezing for days/weeks at a time).
    I've had the best results with Shell 87.
    I drove from San Jose to Reno/Tahoe in September. The tank had Shell 87. Doing 65-72mph with light A/C, got 53.2 on the trip over.
    Filled up in Reno with Chevron 87. No a/c and the down hills were very long. Top speed was 70mph. Got 50.1 on the way back to San Jose.
    FWIW, I run my crap tires @ 42/40. Zero problems. Just rotate regularly.
    I'm betting your mileage issue is due to tires and the colder weather.
Share This Page
