1. Offline
    scramjett New Member
    Start a Conversation
    Jan 9, 2012
    61
    Sacramento, CA
    Your Vehicle Year:
    Hi F8L,
    I usually check them about once a month. I expect air loss as the temps get warmer and if we have a warm spell then a cool down, I'll definitely check them since I know that'll cause a pressure loss.
    Really? Hmm, I'll have to give it a shot. I think I'm only daring enough to go to 40/38 though. EG Toyota recommended that I keep the tire pressure the same on all 4 tires. Their reasoning was that because we have a toddler, a car seat, and cargo associated with him, we should add the extra 2 psi to the back tires to compensate. What are your thoughts on that? I can see doing that on our LA trips since we're usually pretty loaded down with luggage, but the rest of the time?
    Yes, some of my best mileage on LA trips was because I was daring enough to go slower (or traffic was nasty enough that I got out of the left lane and used the right lane more to avoid the constant speed up and slow downs between 55 and 85). My best mileage going to LA was 48 MPG, that was going 75 with a tail wind. Another time when I had a tail wind, I used it to my advantage and did 80 and still pulled off about 46 MPG.
    Given the fact that I have traveled between Sac and LA several times a year for the last 5 years, I know what to expect for my mileage, even worst case, and 36 was WAY too low so I knew something was wrong.
  2. Online
    Aug 14, 2006
    18,122
    3,436
    Sacramento, CA.
    Your Vehicle Year:
    I think the dealership's opinion on tire pressure is sound. If you keep the rear loaded down quite a bit then even tire pressure isn't a bad idea. I wouldn't worry about high pressure though. Most here run 44psi or so and a lot of us run 50psi or higher even during the summer months. You're actually more likely to have a blowout at lower pressure than high pressure due to excess heat build up during tire flex. A tire flexes more at low pressure. I understand that the safety of your child is your most important concern so I will not recommend anything higher than 40psi despite my own practices. :)
    1 people like this.
  3. Offline
    Jan 9, 2012
    61
    Sacramento, CA
    Your Vehicle Year:
    Hi Richard,
    Thanks! :) I think I will give it a shot (and I do check my tires once a month).
    Before, in September. I ran the pressure in the old tires pretty much the same as now, about 38/36.
    My tires still had some tread left to them. EG Toyota and America's Tire had both recommended to me that I replace them earlier last year, but I decided to wait until just before my October trip to replace them (and just before the winter weather).
    I don't know, I'm a little weary about grill blocking. Isn't the upper grill where the air intake is? Or is it the lower grill?
    Interesting. I think I can count the number of times on one hand that I've used Chevron and if I remember correctly, my mileage was not as good with them. Maybe its the additives? My use of Shell stems from convenience and that they are the lesser evil of most oil companies.
    I have to respectfully disagree. I've driven in cold weather with lower than normal tire pressure (for me, that would be lower then 38/36) before and I still managed around 41-42 MPG.
    As for the new tires, I wouldn't think they'd contribute to such a significant drop in MPG.
  4. Offline
    Jan 9, 2012
    61
    Sacramento, CA
    Your Vehicle Year:
    Hi all, after driving my car last night, I think uart is on to something when he mentioned the battery fan. Last night, I was observing the behavior of my car more closely as I was running errands. I made a few stops at stores and I noticed that after starting the car, it was behaving normally and the electric motor would use power from the battery to help accelerate. However, after a minute or so of driving, the electric motor would stop using battery power to accelerate and would rely solely on the engine or charge the battery pack, while accelerating! If the pack is starting to get too warm because the fan is clogged or not working, I can see how the motor would stop using it to accelerate.
    When I got home, I ran the car around the block in EV mode, so that I could try and get the battery fan to come on. After that, I put the car in park and put my ear next to the battery fan inlet and didn't hear anything. I also tried listening for it from the trunk. Nothing. I'm beginning to wonder if it's clogged or just stopped working. Thoughts?
  5. Offline
    Jan 9, 2012
    61
    Sacramento, CA
    Your Vehicle Year:
    Wow, I did not know that! It makes sense though. Thanks, I'll try running 40 psi and see how that effects my mileage when my car starts behaving normally again. :)
  6. Offline
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    Jul 18, 2009
    2,131
    388
    Maine
    Your Vehicle Year:
    I believe that as long as your traction battery has adequate initial charge and the initial temperature isn't too low your car may actually want to use the battery assist early in engine warm-up because the engine is particularly inefficient at that point. Then, as the engine warms up more or if the battery gets too low it will lean more heavily on the engine for acceleration until it completes its warm-up and can use the battery effectively.
    If I'm right (and wait for the tech experts to tell me I'm wrong!) you might find different behavior when the initial battery charge is lower.
  7. Offline
    Jan 9, 2012
    61
    Sacramento, CA
    Your Vehicle Year:
    If I understand you correctly, your thinking is that the charge in the battery is low when I started the car? If that's the case, I can tell you that it wasn't. The charge level was at 6 bars (top of the blue range) when I observed this behavior. It's similar to the kind of odd behavior I noticed before but this was the first time I noticed the car doing what it's supposed to, albeit briefly.
  8. Offline
    qbee42 My other car is a boat
    Mar 2, 2006
    18,043
    2,916
    Northern Michigan
    Your Vehicle Year:
    Well, 53,000 is not very much for a Prius battery, so it would be very unusual if that is the problem. Focus on the other possibilities, but if you can't find anything make sure to log the issue with your dealer. If it does turn out to be a battery issue you want to make sure it is covered by the warranty.
    Tom
    1 people like this.
  9. Online
    Aug 14, 2006
    18,122
    3,436
    Sacramento, CA.
    Your Vehicle Year:
    Sorry. I meant pressure not temperature. I edited my original post. :)
  10. Offline
    Jan 9, 2012
    61
    Sacramento, CA
    Your Vehicle Year:
    Ah, got it now. Thanks! :)
  11. Offline
    Jan 9, 2012
    61
    Sacramento, CA
    Your Vehicle Year:
    Hi all,
    I'm trying to add the images that were in my original post. Hopefully this will work. The first image was taken while I was driving on flat road. The second was on a hill. Notice the behavior of the car and the state of charge of the battery?
    Flat:
    Hill:
    It should be noted that it was at that state of charge the whole time I was on the freeway and was NOT the result of going downhill. The car would deliberately charge the battery up to that level.
  12. Offline
    Buffet New Member
    Jan 26, 2012
    NC Raleigh
    Your Vehicle Year:
    Just purchased a 2008 Prius as well, seems having the same problems,
    Fill up the tank, and now it drop to 5 bars, only traveled 185 miles,
    Not sure the MPG yet, will keep track it and update!
    Hope you have good solution that fix mine as well!!:)
  13. Offline
    uart Senior Member
    Sep 7, 2009
    2,761
    475
    Australia
    Your Vehicle Year:
    Seriously the answer is no, you most likely aren't.
    What is likely however is that you're jumping to conclusions before you've properly calculated your MPG even once!
    1 people like this.
  14. Offline
    Mar 27, 2004
    7,634
    837
    United States
    Your Vehicle Year:
    Yep. The solution is to watch it for a couple of fillups, at least.
  15. Offline
    Mar 27, 2004
    7,634
    837
    United States
    Your Vehicle Year:
  16. Offline
    Jan 9, 2012
    61
    Sacramento, CA
    Your Vehicle Year:
    Re: 2007 Low MPG -- Can't figure our why -- Update
    Hi all,
    Ok, so yesterday, I opened up the battery cooling fan and was able to determine that it was not the cause. The thing was virtually spotless, just a little bit of dust. I went ahead and blew it out with a can of compressed air (the kind you use on keyboards and such) before putting it all back together. I got half way through putting the trunk back together before I realized I hadn't taken a picture, so I hope y'all will believe me when I say that it was pretty dang clean.
    My next step will be to order the 12 V optima battery. I've already looked around but it seems like I have to order it online. Is that the case or has anyone been able to find it in a auto parts store like Autozone or Kragen?
  17. Offline
    Codyroo Senior Member
    Oct 24, 2007
    1,686
    408
    Pleasanton, Ca
    Your Vehicle Year:
    I purchased mine online (I did a cursorary check of stores, but online was the way to go). I hope this resolves the issue for you.
    It may be a silly question, but do you know if the last couple of times that you drove to LA if it was particularily windy on those days? You've noted that when you had a tailwind, that you got great mileage. It could be that some of your lower mileage was that you were driving into a headwind (or a crosswind that was also a headwind).
    In regards to tire inflation.....I've run my 2010 at 44 PSI fronts and 42 PSI rears since I got it nearly 2 years ago. I've put 40,000 miles on the car and the tires are wearing evenly. Given the original depth (10/32) and the current depth (5/32 or 5-6/32), I expect to get another 20,000 miles on the OEM Yokohama Avid S33 tires. Inflating to max PSI will lengthen the overall tire life and you won't wear out the edges of the tires.
    Another silly question, you haven't added anything like a roof rack have you? Things that might impact the aerodynamics of the car.
  18. Offline
    Jan 9, 2012
    61
    Sacramento, CA
    Your Vehicle Year:
    Yeah, that's what I figured I would have to do. Did you order straight from Optima or did you get it from an online retailer (ie Amazon, buy.com, etc)? I hope it resolves my issue as well.
    There are no such things as silly questions! :)
    The trip in November was very windy. One of the reasons why I took so long in coming to the conclusion that something was wrong was because I attributed that trip to the nasty weather. However, the trip back was rather calm and balmy but I still got sub 40 MPG. Then I recalled a previous trip with crazy winds and cruising at about 75ish and my average was still around 41 MPG, not 36! I was floored by that! Also the December trip, which was pretty calm and mild, registered at 33 MPG! As I think about it, it would make sense that the 12 V is dying. I can see how on longer trips constant 14+ V charging would cause the charge level to go down while the shorter trips around Sac wouldn't really show as much charge depletion.
    Yeah, I think I'm going to start inflating them to higher levels now. I'll probably just start with 40 psi on all four tires (I'm not daring enough to go higher yet :) ).
    Nope, nothing on the roof. Gave some thought awhile ago about adding a receiver hitch for a bike rack, but decided against it. Ever since my son was born, my bike riding has gone down to practically non-existent. When he's older, I might pick it up again so I can bike ride with him but I'm hoping I won't need the receiver hitch and that something better will be out there (I expect I'll have something different like the Prius V or plug-in Prius anyway).
  19. Offline
    Oct 24, 2007
    1,686
    408
    Pleasanton, Ca
    Your Vehicle Year:
    I went straight through Optima. That way, if there was an issue, I'd already be set up with the manufacturer/ordering site. BTW, there was no issue.
    However, my 12V battery definitely had issues. Was down to 10.0 Volts (+/- 0.1 volts) at start up. Now is a healthy 12.X volts. I hope to get a nice long life from it.
    You've had yours for around 5 years, and that is generally considered the effective lifetime for the 12V battery (although your readings look good), so replacing it now is a good preventive maintenance step.
  20. Offline
    Jan 9, 2012
    61
    Sacramento, CA
    Your Vehicle Year:
    Wow! That is pretty dang low. I haven't started the car for a few days so I'll have to see what the current voltage level is. It has typically been around 12.0 V. I re-read Richard's 12 Volt battery thread the other day and noticed that his specs called for 12.4 - 12.8 V at startup and 12.1 V at ig-on. I think I'm below spec based on his thread but not as low as 10 V!
Share This Page
