2007 passenger airbag sensor
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Vicki Raske, Aug 26, 2014.
  1. Vicki Raske
    Vicki Raske Junior Member
    My 2007 airbag sensor does not respond to a weight of 20 pounds or more, it continues to read "off". The dealer said the problem is in the female end of the seat belt; however, the seat belt sensor works perfectly. It sounds like the wrong diagnosis to me. Has anyone lease had this problem? if so, what was it was it repaired?
    48,971
    never heard of this before. are you sure the sensor isn't turned off?
    48,971
    will you be presenting this at tgb4?:cool:
    cwerdna likes this.
  4. Vicki Raske
    I took the car to a Toyota dealer because the airbag said "off" even with an adult in the seat. The service department said " the airbag sensor is in the female part of the seatbelt which requires a $500+ repair". Sounds like a fund raiser to me, but I cannot find out where the airbag sensor
    ( for passenger front ) is located.
    Does anyone know???
  5. WilDavis
    WilDavis Senior Member
    2,489
    2,153
    49
    I'm sorry I don't have the answer you're looking for, but let me say "Welcome to PriusChat!" and I'm sure (in time) you'll get a more sensible answer from someone far smarter than I. You might add you location to your info. just to make it easier for folk to help you! - Wil
  6. bisco
    48,971
    i'm not sure either. i'll report this thread for you, hopefully, it will be moved to the appropriate forum and receive more attention. all the best!(y)
  7. JC91006
    16,470
    8,383
    If your sensor light says "off", there is something wrong with it. It should not have "on or off" lit unless someoneis on the seat. I had this problem and it was because the seat belt receiver buckle was not working properly. The fix for me was to change the buckle, however I found another seat on craigslist for $75 and I changed out the entire seat. Problem fixed
