2007 prius. Dog chewed through wires under seat
Discussion in 'Gen 2 Prius Main Forum' started by bcprius1, Dec 19, 2014.
  1. bcprius1
    bcprius1 New Member
    calgary
    My dog crawled under the driver seat and chewed clean through a group of wires. There is no beeping when you do not have your seat belt on or if the door is open and the airbag light illuminated on the dash. we brought it to toyota and they want to replace the whole harness for $7000. is that necessary or is it as easy as soldering back together or some sort of splice? Will it sense a resistance? and the other thing is are those wires linked directly to the airbag and can it go off if i splice them.. If any one has some ideas can you please share. I would greatly appreciate it as i dont want to pay 7000 or get rid of my dog...
  2. JC91006
    16,463
    8,377
    What's to stop the dog from doing this again? You should try and splice and see how that goes. But the airbag sensor is the big hurdle.
    48,862
    how many wires?
  4. Yakoma
    Yakoma Active Member
    470
    121
    ATL-ish
    Sweet merciful crap, Batman. That's one expensive dog.
    kenoarto likes this.
  5. uart
    uart Senior Member
    4,215
    1,200
    Australia
    Do you have any independent workshops near by that work on Priuses. Seeing as the damage is in a known location (that's a huge help), and presumably quite localized, I'm pretty sure that any good independent workshop could repair it as good as new for vastly less than what the dealer has quoted you.
  6. bisco
    48,862
    take it to the best buy stereo shoppe.
  7. Britprius
    Britprius Senior Member
    5,194
    1,910
    Herefordshire England
    Splicing the wires by soldering is perfectly ok. Insulate, and protect each splice with heat shrink tube after soldering. The resistance of the joints will be less than the wires they replace so that will not be a problem. The 12 volt battery must be disconnected before carrying out this work to eliminate any risk of airbag deployment. It "may" be required to turn off the trouble codes for the airbags once the work has been carried out, but they "may" reset themselves.
    John (Britprius)
  8. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    :mad: no more rides in the car for that dog....
    id remove the seat to make life a little easier..
    you might want to remove the orange safety plug as well as the 12 volt battery and let it sit overnight so everything discharges ..
    good luck
  9. xliderider
    xliderider Senior Member
    7,842
    3,099
    Honolulu, HI
    Hmm, rats love to chew on Prius wiring. Sounds like your beloved pet isn't much bigger than the rodent to be able to squeeze under the seat. :eek: :D
    SCH-I535
  10. frodoz737
    frodoz737 Top Wrench
    4,297
    2,347
    33
    Unless the wires are to close to the connector/s, repair them with environmental or butt splices. Even shielded wires and coax can be repaired if you have the right splices.
