2007 prius misfire
Discussion in 'Gen 2 Prius Technical Discussion' started by ed harvey, May 28, 2014.
  1. ed harvey
    ed harvey New Member
    Hello, I am new to the forum. Advice from anyone would be greatly appreciated. I own a 2007 prius, it has about 320,000 miles. It has recently been diagnosed with a #2 and #4 cylinder misfire. The car severely idles rough, but when getting in the gas it goes away. I have replaced the spark plugs, the old plugs were very white(lean), replaced fuel injectors, used fuel injector cleaner. I've sprayed carb cleaner around the intake to see if I might a leak--no leak. The motor uses about a quart of oil every 1,000 miles since about 100,000 miles. I'm just guessing, could it simply be low compression causing this? I pulled the new spark plugs after about 5,000 miles and they where white also. Any help or advice would be greatly appreciated. Thanks so much, Ed
  2. MTL_hihy
    MTL_hihy Active Member
    536
    261
    Maritimes, Canada
    That's a fair bit of miles for the ICE and since you have already replaced the plugs and fuel injectors (assume you used OEM), I would add some seafoam (2-3 cans per full tank) to be sure you don't have any water in your fuel and then check the compression on your engine. You'll need a mini VCI w/Techstream to command it in inspection/cranking mode or you can try just turning the start button on then off shortly after it starts (try to get cranking time the same for each cylinder) but plan on clearing lots of codes after each time you do this. Let us know how you make out and what cylinder pressures you saw.
    #2 MTL_hihy, May 28, 2014
  3. ericbecky
    ericbecky Hybrid Battery Hero
    4,365
    3,209
    Madison, Wisconsin
    Has anyone checked the coil packs? Easily accessed.
    XT1049 ?
  4. MTL_hihy
    536
    261
    Maritimes, Canada
    Seems unusual to have 2 coil packs go bad at the same time but I agree it´s very easy to just swap #2 and #4 over to the other cylinders and see if the misfire follows. If so then obviously replace them.
  5. ericbecky
    4,365
    3,209
    Madison, Wisconsin
    You are right. Not usual for two to go bad. But sometimes a bad coil pack in cylinder can cause other odd behavior. It's any easy thing to try which is why I suggested it.
    XT1049 ?
  6. MTL_hihy
    536
    261
    Maritimes, Canada
    Couldn't agree more.
  7. northcoaster
    northcoaster Junior Member
    32
    northcoast
    By who and how diagnosed the "misfire" and how much were they talking it would cost to fix? Also, how's your mpg? Going down, sameo-sameo or what? I've had a very rough idle when engine first started when cold, and it's gotten to do it some even when warm, rattleing and sounding off a bit. I've also replaced the spark plugs and cleaned very well the mass air sensor and next going to replace the fuel injectors and then the O2 senser, downstream first cause that's what I happened to buy do to reading that the downstream one could affect mpg as I've gone from mid 40's to 36-37, happened a few months ago...no codes whatsoever. car's only got 145K miles and definitely am going to get the HV battery checked out but don't trust the local dealer so will have to drive and hour plus, so be it. Haven't done much except routine maintenance.... does need the transaxle fluid changed, this week. Also, haven't replaced the whatchacallit ICE?? cooland yet, 140K miles probably should do that, eh??? Good Luck,
  8. northcoaster
    32
    northcoast
    OH, Ed sorry but I meant to ask you did you r&r your injectors yourself? if so how did you shut off the fuel? I seem to remember when I did the spark plugs I mistakenly disconnected a fuel line right there and gas just kind of dribbled out, I've read that the fuel pump should be disconnected or a fuse pulled or something because there's like 40psi on the fuel line, don't know why it couldn't just be pinched off for a bit to stop any fuel?? By the by my Prius has be using a quart-quart n 1/2 every oil change, which i do every 3,000-4,000 miles with regular 5w-30 and been using bosch oil filters but may try Wix next as heard they're as good or better? thanks for patience, Lynn
  9. MTL_hihy
    536
    261
    Maritimes, Canada
    Start by running some Seafoam in you tank (2 for a full tank) to see if it helps (will cure any water in fuel issues) and run the tank right down then run some Techtron injector cleaner (again 2 per full tank) and see how that worked (will help clogged or stuck injectors).
    The downstream O2 sensor is only uses to verify the converter is working properly. The upstream (closest to engine) sensor is use for adjusting the fuel trim on the injectors so that one does affect mileage. Make sure to only use Denso or NGK components (plugs, coils, etc) as some aftermarket stuff doesn't play nice and you'll be chasing multiple issues at that point. I would also clean the throttle body (remove the intake and use a toothbrush with TB cleaner). You'll also want to check fuel pressure and run a compression test to rule out any mechanical issues before replacing the injectors (again use OEM parts here). Yes, I would also change the tranny fluid and coolant (OEM Toyota).
    Changing injectors isn't too bad and the pressure in the lines will usually bleed off fairly well overnight. No need to pinch off any lines at all (may damage older lines). I would also suggest running synthetic oil since it tends to hold up much better under heat. As fir filters I usually just stick to stock (stay away from FRAM though).
    #9 MTL_hihy, Jun 1, 2014
  10. northcoaster
    32
    northcoast
    could we have a "how to" on the fuel injector replacement as I can't find anything on here about it and very little 'bout fuel injectors which is weird cause what i can find seems to say they are a bit of a problem on the Prius'sss thanks, Lynn
