1. Offline
    dcatsss New Member
    Start a Conversation
    Oct 15, 2006
    I just bought a new 2007 Prius Touring with Navigation. I'm trying to override the navigaion but doesn't seem to be working. Does anyone know if Toyota change the navigation system from 2006 and before? I try going to the volume screen and pressing upper left, lower left, upper left and lower left. It does not work. Please help!!!!
  2. Offline
    mrichman New Member
    Apr 7, 2005
    In 2006, the display went from analog to digital and the volume, upper left, lower left "feature" does not work. I believe that you can enter destinations while moving through the voice recognition now or go third party for an over-ride box (Coastal Tech may have a unit that works for the 2006-2007, but I'm not certain).
    Mike
    <div class='quotetop'>QUOTE(dcatsss @ Oct 15 2006, 02:28 AM) [snapback]332945[/snapback]</div>
  3. Offline
    Alnilam The One in the Middle
    Jun 8, 2006
    760
    Carlsbad, CA
    Your Vehicle Year:
    <div class='quotetop'>QUOTE(dcatsss @ Oct 15 2006, 12:28 AM) [snapback]332945[/snapback]</div>
    You're SOL, as Granny used to say. (Short on Luck.) ;)
    After 2005 the system, as well as certain features of the BlueTooth phone system, have been locked out while in motion except, like he said, using voice commands or pre-installed points, like "Home" or "School" that you go to a lot and saved. The Coastal override box doesn't work for us. Neither does the selective massaging of the MFD screen. Give it up. Nobody has come up with a software fix yet.
    There is a modification, involving some wire cutting and dash intrusion that I'd suspect you'd feel better about doing after you get your first scratch. It's not hard. It justs sounds like insanity to start taking apart a new car, but you'll get into it after a bit.
    Good luck and enjoy your new vehicle. I've never regretted getting mine and wouldn't trade it for a Ferrari.
  4. Offline
    dcatsss New Member
    Oct 15, 2006
    <div class='quotetop'>QUOTE(mrichman @ Oct 15 2006, 08:55 AM) [snapback]332955[/snapback]</div>
    Thanks I will try them!
    <div class='quotetop'>QUOTE(Alnilam @ Oct 15 2006, 04:32 PM) [snapback]333101[/snapback]</div>
    Thanks for the help. It's not that big a deal yet. I'm sure someone will come out with something. The never of them trying to fix things on us!
Share This Page
