2008 HID Replacement: Failed again after 2 weeks :-(
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by drewtx, Nov 20, 2014.
  1. drewtx
    drewtx Junior Member
    Houston, TX
    Hi All,
    My Driver's side headlight recently started 'switching itself off' - which I understand is a pretty common problem.
    I'd already had the Passenger side replace a couple of years ago - by the dealership.
    But this time I figured I'd do it myself.
    So I bought, and installed 2 of these:
    The light quality is good, they seem brighter than stock. And whiter too - without being 'blue-white'
    (I installed these Yellow Fog Light bulbs at the same time, and they look good.
    I was VERY careful not to touch the glass of any of the bulb; I wore new surgical gloves and also didn't touch the glass at all.
    BUT ... my Driver's side Headlight it acting up again!
    Intermittently blinking out.
    After only 2 weeks!
    So I am wondering: What should be my next step?
    • Should I assume it was a bad bulb, or that I accidentally touched the glass, and replace it again?
    • Or is there something else in the headlight system that I should check/replace?
    Many thanks!
  2. ericbecky
    ericbecky Hybrid Battery Hero
    4,365
    3,209
    Madison, Wisconsin
    It could be the ballast, not the bulb.
    Much more expensive, and much more time-consuming to replace.
    Plan on a good hour and a half.
    Part from the dealer is over $300.
  3. drewtx
    Houston, TX
    Many thanks for the info Eric.
    • Is there any way to test the ballast before replacing it?
    • Or is it possible to swap the ballast between the Driver's and Passenger's sides - to see if the problem moves?
    I'm sort or wary of spending $300, because I am planing to trade it in in early 2015 (for a newer Prius :) )
