2008 Prius 170k Miles - Synthetic Oil vs Conventional Oil
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Solrokk, Aug 31, 2015.
  1. Solrokk
    Solrokk New Member
    Simple question: I have searched the forums but there are dozens of posts and it's a lot of too long to read sort of thing for a specific simple question that I have.
    My Prius has 170k miles, and has had conventional oil changed every 5k miles.
    Questin: At this point should I stick with conventional oil, or go with a synthetic? If I go with Synthetic, what would be the benefits for this specific situation? As well as the disadvantages?
    One of the car experts on PC's great wisdom would be greatly appreciated. I'm also going to do to the oil change myself.
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,795
    Clearwater, Florida
    Stick with conventional.
  3. CooCooCaChoo
    CooCooCaChoo Active Member
    888
    494
    Cow-lee-fornia
    2023 Prius
    The only downside to switching to synthetic at this stage is that the synthetic can break apart sludge/oil build up and start leaking from there.
  4. Solrokk
    Solrokk New Member
    Thank you sirs. I will do that.
  5. Another
    Another Senior Member
    1,802
    510
    Naples, Florida
    Is this still the consensus on sticking with conventional? I’ve never used synthetic, the dealer recommends conventional, 5k changes, its half the price of synthetic and my Gen 2 is approaching 200k with no problems whatsoever. Not sure why anyone changes.
  6. edthefox5
    10,096
    4,795
    Clearwater, Florida
    At 200k miles I would not change. It probably eats a lot of oil. Tends to clog the throttle body pretty good though.
  7. 2Fats
    2Fats Member
    99
    60
    Missouri
    I think anymore it's personal preference. I changed to Synthetic at 160k because I tend to have my car sit for periods of time, and also tend to skip some oil changes. There are some months where I could potentially be changing the oil weekly if I went with every 5k miles, though then the car would sit for a month or two and not get driven at all, so it goes through extremes.
    I have no issues with leaking, it does use a little oil if I'm heavy on the pedal, but nothing unusual. I feel like it runs a little smoother on the synthetic, but nothing that would force me to change from conventional if I was home all the time and could just change my oil whenever.
    My reasoning is that there are people who run synthetic oil, and just change the filter from time to time and get the oil tested/ top off missing oil. They have went 100's of thousands of miles between oil changes, and had no issues with the oil breaking down, or parts going bad. I figure if I'm kind of hard on it by not changing the oil right at 5k miles, I have a little wiggle room, but I'm certainly not saving any money because of the higher cost of synthetic and buying the filter designed for longer intervals.
    On my larger cars, trucks and van I use Rotella oil for semi trucks with no ill effects, but I don't think the delicate little Prius motor would like that stuff too much.
  8. Another
    1,802
    510
    Naples, Florida
    Nope, doesn’t consume any oil between 5k changes. Get mpg in the 50’s routinely.
