2008 Prius ticking 2-1/2 Months Dealer Repair!! Still waiting!!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Prihaus, Mar 29, 2013.
  1. Prihaus
    Prihaus Junior Member
    Belmont, NC
    I am still waiting for my repair for the valve ticking problem repair!!
    Car in the dealer since 2nd week January 2013
    The dealer took the valve assembly apart and performed ?? work.
    Re-assembled and it still made the sound.
    The Toyota certified master mechanic, replaced the timing "can looking device"
    which drives the timing chain between the two cam shafts.
    Still made noise...
    They then inquired to Toyota and were told to look for a "nick" in the engine block which would produce a timing issue that in turn caused the ticking.
    They ordered a Short Block and are now re-assembling.
    Does anybody have some intelligent questions to ask the Master mechanic?
    Are they throwing me a curve ball?
    JMD likes this.
    48,980
    2 1/2 months?!? did they give you a loaner?
  3. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,796
    Undisclosed Location
    On the positive side?
    At least it sounds like The Dealership and Toyota believe you, and are working towards remedy, even if obviously there have been miss steps so far.
    Nobody is refusing to do work, or not pay for any of the remedies they have tried? If so that's good.
    I think the best you can do, is hope the short block which they are now replacing does the trick.
    By the way, you word your statement as " They ( The Dealership ) then inquired to Toyota and were told to look for a "nick" in the engine block which would produce a timing issue that in turn caused the ticking."
    Did they examine the engine block? Was a nick ever found?
    It's good that everyone seems to be working to resolve your issue. It's bad if they have reached a point where they are just taking shots in the dark.
    Good Luck.
  4. PLSPUSH
    PLSPUSH Active Member
    359
    132
    Tulsa, Okla.
  5. Former Member 68813
    3,524
    981
    US
    Who is paying for this?
  6. uart
    uart Senior Member
    4,215
    1,200
    Australia
    Yep, I'm interested in how many miles are on the engine and who's paying for it. It sounds like it's going to be an expensive tick!
  7. Prihaus
    Belmont, NC
    Yes, thankfully I had paid for an extended "platinum" add-on warranty... I am the second owner.
    The dealer loaned a "track"car. 2013 corolla.
    JMD likes this.
  8. Prihaus
    Belmont, NC
    Yes, they did find something on the block. Under the platinum insurance, it's req,d that the insurance adjuster justify the expense. They examined it and approved the repairs. I told the mechanic to take his time repairing the car, and to return the motor to its former stealth quietness.
  9. Prihaus
    Belmont, NC
    Here is a photo of the two camshafts and on the lower left is the can like device which advances or retards timing. image.jpg
  10. Prihaus
    Belmont, NC
    The Prius has just over 91000 miles. Aside from the deductible, it's paid for. The only thing is.... I've spent an additional $600 bucks extra on the 4200 miles driven in the loaner... Ouch!
    uart likes this.
  11. boppo
    boppo Active Member
    799
    138
    Owego, NY
    I hope he doesn't have any parts left over when he gets it all back together.
    Good luck
    JMD likes this.
  12. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    I would ask no questions. It is patience at this time. Sounds like you have a advocate at the dealer.
  13. bisco
    48,980
    i'm sure it must be frustrating, but i guess if they keep trying, what more can you ask for? this has to be costing someone a fortune. they might wish they dropped in a new motor at some point.:eek:
