2008 Prius warning light - what does this one mean?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by elissacl, Jul 2, 2015.
  1. elissacl
    elissacl Junior Member
    Silver Spring, MD
    My 2008 Prius was bumped (fairly lightly) from behind by another vehicle while stopped at a light. No visible damage, and it rode fine afterwards. But there is a red warning light on now that is a picture of a car (no exclamation point in it). My husband is home with the car so that's all I know right now. He did not say it was flashing. Is this a sensor issue with the system for theft deterrence? Something else? I will have it looked at next week when i return home but should I be concerned? Thanks!
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,564
    4,432
    Texas Hill Country
    See attached pdf for details
    #2 rjparker, Jul 2, 2015
  3. elissacl
    Silver Spring, MD
    Thanks! I did find the owners manual online (but thank you for posting it!!). That's why i think it might be the theft immobilizer system, but since I'm not with the car i thought someone might have a firm idea. Maybe it's a sensor, though i don't know if that is costly to fix. The driver of the other car was a student and I'm not anxious to report this and cause him a problem if it's minor. (Also, I forgot to find out if the warning light is flashing, which would be normal; I only know it's red.)
  4. rjparker
    7,564
    4,432
    Texas Hill Country
    Some problems are simple (close the hatch door for example), some are not so cheap. I would think if it's the immobilizer the car would not be running. See the pdf attachment above for details from the manual.
  5. elissacl
    Silver Spring, MD
    Thanks. It's frustrating that I'm not there to try out different solutions. So all I can do is worry. :-(
  6. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Moved to the proper Gen II sub forum. You posted in the Prius v forums though you said you own a 2008 (which is a Gen II).
