Toyota Prius: Next Chapter Opens in January - AutoObserver
According to this the New Prius will be bigger (by a couple of inches) and more powerful (up to 160 HP).
It will also get slightly better mileage (50-55 on the new EPA scale?)
But, I really worry that Toyota is missing the point.
Every Model always seems to 'creep' up in power and size.
For me, that's most definitely NOT what I want to see.
Something the size of the current Prius that gets the BEST MILEAGE POSSIBLE is what I want.
Toyota - PLEASE!!!! - Don't go down this road with the Prius.
So you made it bigger without Increased Weight? Why didn't you make it the same size and Decrease Weight?
So you made it faster? WHO CARES?
If this is true, it's exactly what I was afraid of. If they start creeping the Prius up, that they risk loosing the very audience that made the Prius the success it is.
Excerpts:
"While it's still of course firmly under wraps, a well-placed Toyota source says the next generation Prius looks good. "Still Prius-eque, but a bit bigger and more solid looking."
Toyota will re-engineer the Prius' unique gas engine/electric motor/battery powertrain to make it more efficient, more tightly packaged and to extend the driving range using battery the electric motor.
Toyota will install a bigger 1797 cc four cylinder gas engine to cope with the bigger body and counter criticism in some quarters of the weedy performance of the current 1.5.
With the new 1.8, output's expected to shift from today's 75 bhp to a more rousing 100 bhp. This together with a next generation electric motor should lift combined system output from the current 110 bhp to some 160 bhp, sources predict.
As such, the next Prius will be significantly faster, especially off the line and in low to mid range. But advances with the motor, battery and recharging inside Toyota's trick Hybrid Synergy Drive means economy won't be adversely affected.
Quite the reverse, in fact. While the current Prius posts a class-leading 35.5 km/l in Japan's 10.15-mode fuel cycle (equal to 83.5 mpg in the US), Toyota's reported target with the Mk 3 Prius is a stellar 40 km/l (94 mpg) in the same cycle.
Different markets around the world have their own take on exactly how green and frugal the Prius actually is. America, for instance, rates the 2008 Prius at a far more real world-like 48 mpg/45 mpg/46 mpg for city/highway/combined.
Japan's 10.15 mode, nevertheless, while not perfect, does give an idea of the kind of efficiency improvements we can expect with the next Prius (ie some 10 per cent-plus) and suggests, perhaps, that America's Combined rating for the 2010 Prius will lift up to the 50-55 mpg mark."
I will be REALLY disappointed if the next gen only gets 50-55 MPG.
2009 Prius BIGGER and FASTER (Yeah better mileage too)
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Tempus, Apr 28, 2008.
Comments
Page 1 of 6
Page 1 of 6
