2009 Prius progressive loss of mileage
Discussion in 'Gen 2 Prius Fuel Economy' started by drmvk2000, May 10, 2011.
  1. drmvk2000
    drmvk2000 New Member
    miami florida
    I have been experiencing loss of mileage on my 2009 Prius ( 2years 11,700 miles) for about a year now. I moved from Maryland to Miami in June 2009 soon after buying my Prius. In MD I used to get around 47-50 MPG that dropped to 43-45 MPG in Miami over the initial few months. I attributed that to the summer heat and the load on the A/C( my pregnant wife also did not help- she liked to keep the A/C temp really low!!). Over the next year the MPG stayed around the 42-45 range. But since last April I have noticed the MPG declining steadily-its not a rapid decline but a tenth or two-tenths of a mile over each gas refill and is now hovering around the 36 MPG range. Now I must say that I have a very short commute ( 3 miles each way) to work everyday and that pretty much is all that my Prius does during the week ( 11, 700 miles in 2 years). The reason I bring this up is that whenever I have taken long drives ( 2 over the last year- each over 300 miles) the MPG goes back to the 45 MPG!! I am wondering if the short nature of my commute is a factor but then how can it explain the loss of mileage over the last year when it was same commute the year before.
    So I am perplexed. I mentioned this to the service guys when I took my Prius for its scheduled maintenance but they seemed to take no notice.
    BTW I have not changed tires and keep the tire pressure at the recommended levels. IN fact once I did try keep them a little over-inflated. That didn't help either.
    Does anyone else have the same problem? Or any suggestions?
  2. stefano5777
    stefano5777 Member
    380
    47
    St. Petersburg Florida
    There are a million variables but here are a few suggestions.Increase your tire pressure back up to 42 psi front / 40 rear. also have you rotated your tires? Changed your oil? Do you use cruise control to drive ? It will help with economy if you have not gotten a feel for your gas pedal. Check the voltage of your 12 v battery if it is low it will hurt fuel economy. Also lighten up on the gas pedal during acceleration the Prius has sweet spots that increase fuel economy. 1600 to 1800 rpm range seems to be a good starting point. I am sure I am forgetting a bunch but I will let others chime in to add to my suggestions. If you have further questions you can message me.
    48,980
    it's probably the commute. what was it when you were getting 45-50?
  4. sorka
    sorka Active Member
    1,004
    194
    Merced, CA
    2019 Prius
    Once my prius is warmed up, I get about 50 MPG freeway and close to 80 when hypermiling on expressways in the bay area. Yesterday I tried real hard and actually got 62 MPG over a 35 mile stretch from Livermore to Santa Clara all on the freeway, but I was keeping it 60 MPH. If I go my usual 75, I only get 50.
    However, if I only went 3 miles at a time to work and back, I'd only get about 25 MPG.
  5. drmvk2000
    miami florida
    I'm very conscious of the gas pedal when I drive I do try hypermiling as much as I can. In the mean tme I read through a lot of posts on this issue and realized that commutes of 10 min or less tend to give MPGs in the 30's.
    To answer Bisco's question in MD my commutes were longer ( mostly around 20-30 miles) but I was there only for the initial couple of months after I bought the car.
    My tire pressure is usually around 38 psi (all tires)
    Thanks for your suggestions.
    Someone in a post suggested using Chevron Techron Fuel System Cleaner. Would that help?
  6. richard schumacher
    7,663
    1,038
    United States
    No. There's little to be done about it except to increase tire pressures (you can go to the max shown on the sidewall) and realize that any other car under the same conditions would get about 1/2 the MPGs.
  7. drmvk2000
    miami florida
    I agree. But like many Prius lovers I bought it to make a statement. The added MPGs were only a bonus.
    I love the car nonetheless. I feel it has the smoothest ride of all cars in its class.
  8. ystasino
    ystasino Active Member
    793
    50
    Tucson, Arizona
    If you have A/C at max cold and you're only driving 3 mile commutes then your mileage doesn't seem extraordinary. Another thing to look at is whether your dealer overfills the oil which will impact your mpg.
    At what free way speeds and distances do you get 45 mpg?
    Florida is as flat as it gets so if you could get on the interstate and drive for 20 miles one way and 20 miles back at a speed of 60 mph, at 38 psi and without A/C you should get no less than 50 mpg.
    Also wait for about 50 s before you start your journey to give your engine a chance to warm up and run through its cycling. After 50 s or so, the car will shudder, the engine will turn itself off and your trip's mpg will increase as you won't be depleting your battery by driving your car during these first 50 seconds.
    If you're really worried you should make sure you car's engine gets into stage 4 and that your traction battery doesn't appear to charge/discharge way too fast.
  9. brick
    brick Active Member
    1,083
    78
    Upstate NY
    OP: Are you resetting the mileage on the MFD, or do you just leave it to track long-term trends? If the former, it's a little odd. If the latter, then your symptoms match perfectly with having started a commute that will definitely get you lousy mileage. In that case I don't think there's anything at all wrong with the car. Mileage on short trips just isn't as impressive as on long trips.
  10. bisco
    48,980
    if you have dropped from 42-45 to 36mpg under almost the exact same conditions, i would check your 12v battery, tire pressure, oil level, can't think of anything else, but something is not right.
  11. stevemcelroy
    stevemcelroy Active Member
    873
    194
    Boulder, CO
    I have a similar commute- just under 4 miles each way and my mileage stinks cause it is just too short. I have young kids so there is a fair bit of other driving - I have over 50,000 miles on my 2009 - and my mileage is in the right range on longer drives.
    So, my guess is it is just the commute. When looking at your mileage when it is such a small sample that I think you just need to let it go. As long as the car is performing as expected on longer trips where you are getting a better read on actual mileage you should be all set.
