1. Offline
    HTMLSpinnr Gen III Forums Moderator
    Dec 8, 2003
    Message Count:
    4,975
    717
    Surprise, AZ (Phoenix)
    Your Vehicle Year:
    Not sure how many of you opted for the cargo net in the 2010.
    I noticed when I took delivery that the cargo net was pulling the plastic panels apart because of the bungee effect.
    [IMG]
    The instructions and parts provided w/ the cargo net has the port tech install the cargo net through a single panel with a short stud. I.E. they did their job correctly.
    When I had the car in yesterday, one of their senior techs took a look and said they'd see if they couldn't quickly come up with something.
    Turns out the best fix was to drill through a second panel behind the separated one and to use a longer anchor stud. They had this done within 30 minutes and no more separation.
    Photo of fixed:
    [IMG]
    The tech went ahead and submitted a quality report which will hopefully get the part revised.
    14 people like this.
  2. Offline
    a priori Canonus Curiosus
    Aug 14, 2007
    Message Count:
    2,668
    313
    Chicagoland (West)
    Your Vehicle Year:
    I just had mine installed Monday, but I haven't put any pressure on it. I'll go back soon for the rear bumper applique, and I'll ask about it at the time.
    Rick -- if you're able to post an after picture, I'd appreciate it.
  3. Offline
    Dec 8, 2003
    Message Count:
    4,975
    717
    Your Vehicle Year:
    Will try to grab one tonight. According to my dealer, dbacksfan's car had the same issue and was fixed in the same way.
    1 people like this.
  4. Offline
    Aug 14, 2007
    Message Count:
    2,668
    313
    Chicagoland (West)
    Your Vehicle Year:
    Thanks! I'd appreciate all of the help possible, because I'm very likely going to face the same issue.
  5. Offline
    IraS New Member
    May 15, 2009
    Message Count:
    164
    48
    Austin, TX
    Your Vehicle Year:
    I currently have the cargo net with my 2004 Prius. I wasn't going to buy a new cargo net for my 2010 Prius because I assumed I could just attach my current net to the new car. Aren't the mountings for the top of the cargo net standard in the car? Or are they installed only if you purchase the cargo net? I need to know if I should change my order to include the cargo net.
  6. Offline
    • Moderator
    efusco Troll Slayer
    Nov 26, 2003
    Message Count:
    19,635
    881
    Nixa, MO
    Your Vehicle Year:
    In the 2G, and (I assume) the 3G there are metal anchor points on teh floor of the cargo area that are in every car. But the plastic d-rings must be added and are included with the cargo net when ordered.
    I would suggest you change your order OR wait until we see what fix Toyota comes up with and add it yourself later. It was very simple in the 2G requiring the drilling of 2 holes using a simple paper template as a guide.
  7. Offline
    dbacksfan New Member
    Apr 7, 2009
    Message Count:
    244
    17
    Scottsdale, Arizona
    Your Vehicle Year:
    Yes, thanks to your alert, we made sure to check this issue. I couldn't wait for them to fix it, as I was on a tight time schedule. So I'm having it fixed on Monday.
    Kudos to Avondale Toyota!!! Chuck, my sales manager, immediately committed to having it fixed, noted it in the sales paperwork, and personally introduced me to the assistant service manager and explained the issue. Very professionally handled, indeed.
    I hope others who encounter this issue will be treated with the same respect.
  8. Offline
    Dec 8, 2003
    Message Count:
    4,975
    717
    Your Vehicle Year:
    Original pic (putting here as well just for easy comparison):
    [IMG]
    Fixed pic same angle:
    [IMG]
  9. Offline
    Dec 8, 2003
    Message Count:
    4,975
    717
    Your Vehicle Year:
    The 2G cargo net anchors in a different spot than the 3G. 2G is right below the screw next to where the toneau cover locks in place when extended. 3G is further in mounted to the trim panel itself.
    Full pic of the 3G Cargo net:
    [IMG]
  10. Offline
    Aug 14, 2007
    Message Count:
    2,668
    313
    Chicagoland (West)
    Your Vehicle Year:
    Is that report generally available to Toyota Service Managers?
    I see the separation happening already, so I'd like to get my dealer to make the correction. Should I have the Service Manager contact Avondale Toyota, or is there a better way to handle it?
  11. Offline
    Dec 8, 2003
    Message Count:
    4,975
    717
    Your Vehicle Year:
    The Service Manager submitted a quality report through their channels but I don't know if that's distributed to other dealers or just internal to Toyota. I'm also not aware of how long it would take to get propagated down the line.
    Worst case, they could always call Avondale Toyota. They'll surely blame me though ;)
    1 people like this.
  12. Offline
    • Moderator
    Message Count:
    27,008
    1,175
    Your Vehicle Year:
    Could that possibly to help keep the cargo in the net further into the cargo area?
    I know with the current one, sometimes things get squished when the hatch is closed because the bags are all lined up fairly close to the edge of the hatch. With the top mounted a little further back, maybe that'll tilt the net and help keep the bags away from the hatch.
  13. Online
    ggood ggood
    Jan 17, 2004
    Message Count:
    1,917
    276
    Houston, Texas
    Your Vehicle Year:
    I decided to just use one of those canvas cargo boxes for that reason (also helped that I already had one and that GST gave me the wrong cargo net).
  14. Offline
    Dec 8, 2003
    Message Count:
    4,975
    717
    Your Vehicle Year:
    Tideland, I haven't tossed much into this cargo net, but that was a frequent problem w/ the '04 and that cargo net setup. I'll try it out this weekend.
    I can say this new cargo net is several inches taller, and possibly actually useful for a gallon of milk!
  15. Offline
    Mar 8, 2008
    Message Count:
    9,152
    1,793
    Your Vehicle Year:
    Fascinating, thanks for providing the resolution to this issue.
  16. Offline
    DianneWhitmire High PRIUStess
    Oct 23, 2007
    Message Count:
    2,686
    603
    Laguna Niguel, CA
    Your Vehicle Year:
    That explains it. Great pics, dear! Thanks... I sure appreciate the heads up too - I have a few cars arriving with cargo nets and hope the LB port facility is ON this issue!!!
  17. Offline
    DeanFL 2010 owner - 1st Prius
    Apr 13, 2009
    Message Count:
    986
    321
    Leesburg Florida USA
    Your Vehicle Year:
    I ordered the cargo net as a port option, but SET Jacksonville did not have it stock. I'll order it later or hopefully from PC Shop.
    Got some groceries yesterday including a small seedless watermelon. All in the Prius cargo area. Well, driving home, I'm hearing clunk....clunk...clunk while braking or accelerating. About a block from the house..."Oh crap - hope that watermelon didn't break open. Thankfully no. But the net would have been a perfect holder - or if I used my head, the rear floor... dope slap.
    Rick - does the tonneau cover still latch with the net attached up higher?
  18. Offline
    Dec 8, 2003
    Message Count:
    4,975
    717
    Your Vehicle Year:
    The slot visible in the picture above the anchor point is where the tonneau cover locks in. Problem is I've scratched the panels a few times being clumsy with the cover getting it secured.
  19. Offline
    dakshah Counting the dayz....
    May 19, 2009
    Message Count:
    36
    SillyCon Valley-ish
    Yes - so do I!!! Can I get it addressed at the dealership if it's not before I take possession?
  20. Offline
    zencat New Member
    May 23, 2009
    Message Count:
    94
    Studio City, CA
    Your Vehicle Year:
    Thank you for this. I have a net and I did notice this separation (also the scratching, but that's my fault). I will look into getting this fixed...maybe during my 5000 oil service.
Share This Page
