2010 Keyfob Programming to unlock all doors at once ???
Discussion in 'Gen 3 Prius Main Forum' started by revhigh, Apr 28, 2011.
  1. revhigh
    revhigh MPG Enthusiast
    986
    141
    PA - Pocono Mountain Area
    Hi All,
    Yes, I've searched for this !!
    I had the dealer program the smartkey to open all the doors at once by grabbing the handle, but pressing the button on the keyfob to unlock the doors requires the two pushes and it's driving me crazy.
    Is this something that a user can do, or is it something that needs to be done by the dealer ?
    I've searched the manual, asked some people at Toyota, but no one seems to know for sure how to do this.
    I'm sure I could have missed it in my search, but if anyone knows, could they please direct me to the post via link or refer me to the manual page number ?
    Thanks very much !
    REV
  2. RRxing
    RRxing Senior Member
    2,518
    1,790
    NEPA
    The unlocking function to unlock all doors with one press on the fob (wireless remote control) is a dealer customization.
  3. jjcgolf72
    jjcgolf72 New Member
    Chicago, IL
    The manual tells you how to unlock all doors by grabbing the handle. I did mine and it works. Sorry not near my vehicle to find the exact page but it is there. All I do now is touch my handle and every door unlocks.
  4. bobraynard
    bobraynard New Member
    Shreveport
    On your remote press the "lock" and "unlock" buttons at the same time.The Prius will chirp it's acknowledgment to you then you can release the buttons...
    All doors will now unlock.
  5. Mendel Leisk
    38,247
    +1 for bobbraynard's suggestion. Each time you press-and-hold both the lock & unlock (on the fob), it toggles between unlock just drivers door and unlock all doors. Also:
    The dash displays a picture of a car, with either just driver's door open, or all doors open, and there's a long beep, then a few short beeps. I believe the beep sequence is a little different for each case, but the pic alone will confirm.
    You can do this immediately after getting into the car, it doesn't need to in accessory or ready mode, just off.
    I did find this in the manual once, but can't seem to find it this morning.
  6. larry@SfToyota
    larry@SfToyota SanFrancisco Toyota Ambassador
    San Francisco Ca.
    Oops, just re-read the post. My apologies. Remote programming with the fob is a adjustment by the Technician.
  7. revhigh
    986
    141
    Thanks All !!
    I'll try that and report back !
    Much appreciated.
    REV
  8. revhigh
    986
    141
    Didn't work.
    Holding down lock and unlock until you hear the confirmation tone (two beeps two times (or three times)) makes the KEYLESS part toggle like that when you grab the handle, but DOES NOT change the functionality of the remote itself. My remotes will only unlock the drivers door no matter the setting.
    Doing the above DOES toggle the handle grabbing functionality between unlocking all doors and unlocking the drivers door only.
    Damn !! Any other ideas ?
    REV
  9. VA_Joe
    VA_Joe Junior Member
    Virginia
    Dealer needs to make this change.
    I looked through the entire Customization section of the owner's manual and the dealer made all the changes I wanted during my 5K service (no charge).
  10. 32kcolors
    32kcolors Senior Member
    5,683
    952
    124
    Redondo Beach, CA
    I had the dealer program the fob to open all doors at once.
    It isn't too smart or safe to have all the doors open at once by grabbing the handle. Someone could gain entry on the other side and it's not worth the risk. I'll only use the fob to open all doors at once when I'm with someone and not alone.
  11. Judgeless
    Judgeless Senior Member
    1,821
    255
    Cleveland, OH
    I had a Viper system installed that lets me change this option. It has a mode that sends a single or double pulse to the ECU to unlock the doors. A double pulse unlocks all the door.
    This will not help you but if you are on the fence of a getting a after market remote start system this is good info.
  12. Dave14Prius
    Dave14Prius Member
    72
    26
    NE Missouri
