2010 Oil Change: Wrench for Filter Housing
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by bauerhillboy, Sep 20, 2013.
  1. bauerhillboy
    bauerhillboy Junior Member
    Assenmacher Toy 640 sound familiar to anyone? $16 or so on Amazon.
  2. VTAERO
    VTAERO Junior Member
    Fredericksburg, VA
    That's the one I just bought. But I haven't tried it yet. I did some cross checking and it appears right. I'll know for sure when I actually do the job for the first time on my "new to me" 2010.
  3. ny_rob
    ny_rob Senior Member
    1,909
    715
    L.I.- NY
    2014 Chevy Volt
    I bought that exact model over a year ago and have used it several times.
    It's an exact fit for the Gen III Prius.
  4. bauerhillboy
  5. vito.a
    vito.a Junior Member
    52
    Tucson, AZ
    I purchased the Assenmacher filter wrench about 2 weeks ago. It works great. It also has great reviews. The stamped steel wrenches will not remove a very tight filter.
    It would be nice if the Assenmacher filter wrench still had a 3/8" square drive hole so a ratchet or extension could fit it directly instead of using a 15/16" socket. I may have to do some machining on mine.
  6. jdcollins5
    jdcollins5 Senior Member
    4,925
    1,075
    Wilmington, NC
    When did they stop providing the 3/8" hole in the back of the filter wrench? That was one of the nicest features.
  7. walter Lee
    1,121
    367
    Maryland
    when u do your oil change - I would be interested in how it turned out for you.
  8. zander
    zander Junior Member
    45
    connecticut
    Put a little grease in side the filter wrench and the wrench will come off the filter .
    ny_rob and dhancock like this.
  9. vito.a
    52
    Tucson, AZ
    I read it in the reviews and when I received my wrench, it did not have the hole. It now has a 15/16" hex.
  10. Fluxuated
    Fluxuated Member
    133
    51
    Guelph, ON
    Bought that one as well. Mine also has the 15/16" Hex. I've not used it yet, but will in the next few weeks.
  11. ny_rob
    1,909
    715
    L.I.- NY
    2014 Chevy Volt
    Good idea.
    I currently break the filter cover lose (1/2 turn or so) from the engine- then remove the ratchet and give the filter wrench a couple of taps to break it lose from the filter cover. I like your method better if it works. I'll try it on my next oil change!
