2010 Prius cargo net
Discussion in 'Newbie Forum' started by jaylevy, Nov 2, 2009.
  1. Offline
    jaylevy New Member
    Oct 9, 2009
    Message Count:
    Virginia
    Your Vehicle Year:
    I received my Pruis in mid September. I never received my cargo net. It is on backorder. Dealer said they are on hold as the weight on items put into the net makes the anchors on the side on truck pull out oof the sides and causing damages. Has anyone else run across this problem:(
  2. Offline
    • Moderator
    Message Count:
    27,008
    1,175
    Your Vehicle Year:
    Re: 2010 Pruis cargo net
    That is true. Toyota did have a stop on the release/sale of cargo nets but it was released today and dealers are allowed to put cargo nets on new vehicles.
    So it should be in very soon.
  3. Offline
    BillsPrius New Member
    Nov 1, 2009
    Message Count:
    NE Ohio
    Your Vehicle Year:
    Hmmm, my Prius is a few weeks old now (maybe 4) and I had a cargo net in it on delivery... Do you think that was a mistake of the dealer not taking it out? Did they do something different to strengthen the attachment points now or did they just officially OK the old design?
    Thanks,
    Bill
  4. Offline
    • Moderator
    Message Count:
    27,008
    1,175
    Your Vehicle Year:
    Do a quick search of the site (google is probably a better engine than the site's search function). You should be able to find a picture of the new hooks.
    Is the top part of your cargo net attached to metal hooks that are held by the same screws near the locking position for the tonneau cover? If so, then you have the "new", more secure hook points.
    If not, then you have the plastic hooks that are attached to the plastic piece slightly inboard from the edge of the cargo area and that's the original, not-so-secure hook points.
  5. Offline
    Nov 1, 2009
    Message Count:
    NE Ohio
    Your Vehicle Year:
    Thanks Tideland!
    I couldn't find pictures of the new metal clips but I saw pictures of the old style and went out to the car and sure enough I have the new clips that fit your description. :D
    Bill
  6. Offline
    Buzz New Member
    Oct 26, 2009
    Message Count:
    Aiken, South Carolina
    Your Vehicle Year:
    For what it is worth - I removed the cargo net and top anchor attachments from my old 06 Prius and installed it in my new 2010 Prius. I drilled holes in the hard plastic portion right below where the phillips screw is located and just popped in the old anchors and it seems to work fine "so far".
  7. Offline
    • Moderator
    Message Count:
    27,008
    1,175
    Your Vehicle Year:
    Great! I was hoping I wasn't getting too wordy with my description.
  8. Online
    tumbleweed New Member
    Oct 3, 2005
    Message Count:
    3,801
    551
    Eastern Oregon
    Your Vehicle Year:
    I took delivery of my car in August and it had the new style cargo net hooks installed by the port. Apparently some of the dealers didn't get the word yet.
Share This Page
