2010 Prius died - P0A94 - Inverter Failure - Replaced
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kc410, Jun 26, 2014.
  1. kc410
    kc410 Active Member
    262
    250
    2010 Prius IV
    Hi! I'm a longtime reader & today I got a excellent reason to make a post - I was at ~20mph & had just went around a corner & tried to accelerate fairly briskly & the car just dies. Hybrid Failure iirc. I got out of traffic & pulled the codes (BT dongle already installed) Torque shows P0A94 Powertrain. I reset the code & power cycled the car but nothing changed. The traction battery still was showing 5-bars so I moved the vehicle <.1 mile to a safe location. Battery was still at 2-bars when I powered it down.
    Got the car towed to the Toyota dealer where I had purchased it used the end of November with ~99K.
    The service dept. was open til 7pm & the vehicle got there ~6:30. Just before 7pm the service adviser came out & told me of the ongoing recall (which I knew of, but had not been done) on the Prius & that the problem I was having may be related to the recall. He said that he had not seen the exact same problem as I am having & it will have to wait for a tech to look at it.
    Its got ~121K on it now & has been performing great. Mobil1 0W-20 @ 5-10K. Engine & Inverter coolant was changed by the dealer at 100K. The trip odometer (reset at every fillup) shows ~250 miles & 55.3mpg with AC all the time.
    I'll keep this updated as I find out more...
    also: A BIG THANKS to all the fellow members for posting so much information
    Kim
    Sylvia prius likes this.
    48,945
    how old is the 12 volt?
  3. kc410
    kc410 Active Member
    262
    250
    2010 Prius IV
    The 12V is oem I think! I have never looked at it.
    I do monitor the voltage after sitting overnight (Fluke 87) & it had always been ~12.8 at the fusebox terminals.
    I had been driving the car all day with AC & the last trip was ~5 miles at 50mph before the failure.
    I use eco setting _all_ the time & it was in eco when it failed.
    Mod: thanks for moving this to the proper forum.
  4. wjtracy
    wjtracy Senior Member
    11,312
    3,588
    Northern VA (NoVA)
    Gen3 hybrid batts have been very reliable so far. Not sure if we even have a single report of a US Gen3 hv batt failure yet on PriusChat. We do have some complaints in Europe I know.
  5. kc410
    kc410 Active Member
    262
    250
    2010 Prius IV
    11:40 am - service adviser calls & says my Prius is ready to be picked up!
    The failure was indeed related to the recall.
    Inverter has been replaced & the recall has been performed - no charge (@ ~121K).
    I will try to find out more when I pick up the Prius.
    happy-happy-happy :)
    ibmoses and sprtent like this.
  6. smokiejoe
    smokiejoe Member
    178
    30
    PA
    Back in Business for another 121K...
  7. kc410
    kc410 Active Member
    262
    250
    2010 Prius IV
    Well, just as the service adviser advised, the car was repaired & ready to go.
    No charge - invoice has "Warranty" in the amount column.
    By 1:00 I was on the road! This almost has to be some sort of record?
    Yesterday afternoon at 5:12 the car died - towed to the dealer & dropped off by 6:30.
    Dealer was open til 7pm so I got it checked in & I am driving it by 1pm the next day.
    My only expense ($95) was the tow of ~12 miles to Earl Stewart Toyota in Lake Park.
    The invoice "service & parts" has:
    22TOZEOE: Software Update, certain 2010-2014 Prius vehicles
    Installed G9200-49025 Inverter Assy, w/con(verter)
    Installed 00272-SLLC2 Super Long Life Cool(ant)
    Under the hood, the new inverter is bright & shiny.
    The tag on the inverter has:
    Inverter Assy w/converter
    Toyota
    G9200-47190
    22JTE47190A14C310125
    I put ~50 miles on it this afternoon & it drives the same to me.
    I keep it in eco mode & fuel mileage appears to be very close to the same.
    I sure hope I have some Karma left over for the rest of the year!
    Happy Driving
    Kim
    #7 kc410, Jun 27, 2014
  8. kc410
    kc410 Active Member
    262
    250
    2010 Prius IV
    I _really_ hope so - on July 9 I just put a set of Michelin Defender tires on.
    Got ~2K on them - I am _VERY_ pleased with them!
    I'm going to try & get >100K out of them. Tire Pressures are 44/42.
    The car came with well used Toyo Versado eco tires that I got ~20K out of.
    They had been run under-inflated & I had them at 44/40 to try & correct the wear.
    The higher TP just stopped them from wearing unevenly but that was fine with me.
  9. kc410
    kc410 Active Member
    262
    250
    2010 Prius IV
    I just checked the 12V battery after the vehicle has been sitting all night...
    12.93V at the fuseblock terminal - measured with Fluke 87 III
  10. edthefox5
    edthefox5 Senior Member
    10,096
    4,795
    Clearwater, Florida
    Way overdue for transmission fluid change.
  11. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    Fantastic to hear a good dealer story!!
  12. kc410
    kc410 Active Member
    262
    250
    2010 Prius IV
    Thanks for the reminder - that was one of the first things I did after I purchased it in November, at 100K (thanks to reading about it on priuschat).
    Actually changed Dec 11 @ 101K - the old fluid was black & very thin iirc.
    The _only_ document that I have found that talks about scheduled mtce. on the transaxle is the following:
    https://autoteacher.net/uploads/Toyota_Hybrid_Presentation.pdf
    Page 42 shows:
    Fluid Type: WS
    Capacity: 3.5 qts
    Maintenance Interval (initial): 100,000 miles
    Maintenance Interval (subsequent): 50,000 miles
    Feri likes this.
  13. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    Good service. I wonder why they did not pick the bill up for the tow? H
    kc410 likes this.
  14. kc410
    kc410 Active Member
    262
    250
    2010 Prius IV
    Good Question! Even the service adviser said it was a good question...
    I stopped at the dealer this afternoon & my service adviser was working.
    The first thing I told him was the car was fine! :)
    He knew I was online at priuschat & I told him someone had asked why Toyota had not picked up the tow bill.
    After a few phone calls he said Toyota would cover it!
    The towing company does lots of this dealers work & the tow driver asked me if I wanted him to bill the tow to the dealer or pay cash - I had elected to pay cash so I had a receipt for the tow. I gave it to the service adviser & he says I will get a check in a while.
    I had told the service adviser that I did not want to harass the dealer for the $95, I just wanted to be able to answer the question.
    But since Toyota was paying, that was fine with me!
    HaroldW - I would also like to thank you for asking that question.
    I'm about 4K miles away, but if I ever get close, I'll get the first few rounds :)
    Guess the Karma is still holding out..
    Kim
  15. bisco
    48,945
    congrats all around!(y)
  16. Feri
    Feri Active Member
    761
    144
    What a fantastic document. Thank you for posting!!:)(y)
  17. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Another failed inverter story though :(
    Sounds a very similar experience to how mine failed and how the car would crawl to a safer location on electric.
    Wonder if there's some bad programming that has been corrected by the recall rather than just a faulty or weak inverter?
  18. HaroldW
    716
    95
    I believe the recall was done to correct a issue! H
  19. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    It was, and the op appears to have not had it done.
    I was trying to highlight the importance of having the recall if not done already :)
  20. kc410
    kc410 Active Member
    262
    250
    2010 Prius IV
    I am the OP & you are correct - The recall had not been performed on the Prius.
    "the car would crawl to a safer location on electric" - yes, that is exactly what it would do.
    I only moved it 200-300 ft. down a small hill (overpass) but I remember maneuvering it so the tow driver could easily pick it up :)
    The motor drive was still functional in both fwd & reverse as I used both - at the very slow crawl speed.
    I'm guessing the step-up inverter 200V -> 650V DC-DC converter went & the crawl speed is because the motor driver only has 200V to work with instead of the normal (up-to) 650V.
    I wish this failure on no one! Where ever you are is where you stay until help arrives.
    Prius continues to perform well - Kim
    #20 kc410, Jun 30, 2014
    GrumpyCabbie likes this.
