1. Offline
    toyotareference New Member
    Apr 17, 2008
    Message Count:
    40
    Portland OR
    Your Vehicle Year:
    Anyone know the engine code for the 1.8L in the new Prius? Bonus points if you can also tell me the chassis code(s).
  2. Offline
    • Moderator
    Message Count:
    27,008
    1,175
    Your Vehicle Year:
    2ZR-FE (FXE for the Prius). Don't know the chassis code since it's a new chassis.
  3. Offline
    Apr 17, 2008
    Message Count:
    40
    Portland OR
    Your Vehicle Year:
    Ah, the same basic engine that is in the Corolla, Matrix and Scion xD. Thanks much!
    The chassis code could be the ZHW30... we'll see.
  4. Offline
    • Moderator
    Message Count:
    27,008
    1,175
    Your Vehicle Year:
    NHW you mean.
    Yes it's the same engine but with Atkinson cycle.
  5. Offline
    Apr 17, 2008
    Message Count:
    40
    Portland OR
    Your Vehicle Year:
    No, I mean ZHW. NHW would be the chassis code if it still had an N-series engine, but now that Toyota has put a Z-series engine into the car the chassis code will start with Z. I don't know if it will be a 30-series chassis code, but I would guess that it would since this is the third generation Prius. Of course, sometimes the platform is spun off of another car, then the code could be anything.
  6. Offline
    • Moderator
    Message Count:
    27,008
    1,175
    Your Vehicle Year:
    Hmm, I see. Should've asked us before we went to Detroit.
  7. Offline
    Apr 17, 2008
    Message Count:
    40
    Portland OR
    Your Vehicle Year:
    Well, often times they won't release the chassis code until the car is just about ready for sales. Once the cars start showing up in the dealer ordering system the chassis code will be available.
  8. Offline
    ken1784 SuperMID designer
    Dec 18, 2003
    Message Count:
    2,858
    1,106
    Yokohama, JAPAN
    Your Vehicle Year:
    The chassis code is ZVW30.
    Ken@Japan
    [IMG]
  9. Offline
    Apr 17, 2008
    Message Count:
    40
    Portland OR
    Your Vehicle Year:
  10. Offline
    rusty houndog mountain rider
    Jul 14, 2008
    Message Count:
    152
    Buffalo, Wyoming
    Your Vehicle Year:
    Does that mean the Corolla, Matrix, and Scion XD have an offset crankshaft? Or does that mean the Prius will not have an offset crankshaft?
  11. Offline
    HTMLSpinnr Gen III Forums Moderator
    Dec 8, 2003
    Message Count:
    4,975
    717
    Surprise, AZ (Phoenix)
    Your Vehicle Year:
    Speculation aside, I'd find it hard to believe Toyota backpedaling on such a successful design. Cylinder wall wear reduction was a motivator for this design IIRC, as well as a more efficient use of the power stroke at TDC.
  12. Offline
    Jun 27, 2007
    Message Count:
    1,671
    87
    Out there, somewhere
    Your Vehicle Year:
    Damn, you guys are good!
  13. Offline
    Dec 18, 2003
    Message Count:
    2,858
    1,106
    Yokohama, JAPAN
    Your Vehicle Year:
    The base 2ZR-FE engine has an offset crankshaft.
    Pressroom - Toyota - Press Kit Details
    "The fully balanced crankshaft is offset by 8mm to the intake side of the bore centres to reduce the maximum side force on the cylinder walls and increase fuel efficiency."
    Ken@Japan
  14. Offline
    Dec 8, 2003
    Message Count:
    4,975
    717
    Your Vehicle Year:
    I believe MRV took that photo. I was sitting in the driver's seat when it was taken and happy that she did so.
  15. Offline
    spwolf New Member
    Sep 16, 2005
    Message Count:
    2,230
    156
    Eastern Europe
    what car was that from? We can see that GVWR is only 200lb more than on 2004 Prius.
  16. Offline
    • Moderator
    Message Count:
    27,008
    1,175
    Your Vehicle Year:
    blue car with nav, 15" alloys and moonroof. They may all say the same number despite the options.
  17. Offline
    Dec 8, 2003
    Message Count:
    4,975
    717
    Your Vehicle Year:
    Gross weight will likley be fixed, it's curb weight that determines "carrying" capacity. Sadly, we don't treat our cars quite like airplanes and many of us may routinely exceed this w 5 adults, full gas, and some luggage.
  18. Offline
    spwolf New Member
    Sep 16, 2005
    Message Count:
    2,230
    156
    Eastern Europe
    nevertheless it pretty much confirms that 100lbs note from detroit... which is rather impressive.
    seeing new Avensis dismantled to pieces, latest vehicles get so much anti-crash protection, it is miracle that they are all not 5000lbs.
  19. Offline
    qbee42 My other car is a boat
    Mar 2, 2006
    Message Count:
    17,752
    2,804
    Northern Michigan
    Your Vehicle Year:
    You don't calculate weight and balance before you back out of the garage?
    Tom
  20. Offline
    Dec 8, 2003
    Message Count:
    4,975
    717
    Your Vehicle Year:
    No, and my tires hate me for it!
    On a different note, it was interesting that the Chief mentioned a requirement to keep weight UP in some ways for safety/crashworthiness reasons.
Share This Page
