2010 Prius Grill Blocking strategy
Discussion in 'Gen 3 Prius Accessories and Modifications' started by ken1784, May 31, 2009.
  1. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    Unfortunately it can not. I think it must have a sensor to tell if it's to hot, cold would never be a problem for it. There may be a way to read it using the Xguage feature on the scan gauge but no one knows the coding for the Gen3 yet. I agree with you I won't block the upper either.
  2. Airbalancer
    Airbalancer Active Member
    892
    73
    Cobourg, On, Canada
    Has anyone been able to attach anything behind the grill to block the airflow?
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Originally I wanted to do that but couldn't find an easy or hard way for that matter. It would have required removing many parts. And then I didn't want to block too much. At least this way, I could remove some of the blocking if I felt the car getting too hot.
  4. chiguy
    chiguy New Member
    25
    Champaign/Urbana
    Is monitoring the engine coolant temp reading on the Scanguage sufficient or do I actually need to program an Xguage to get the actual engine temp?
  5. Airbalancer
    892
    73
    Cobourg, On, Canada
    I was able to get a piece off the top today, but still it was to hard to get my arm down there
    pick up some 1/2 in pipe insulation today. 89 cents for a 6 ft piece
    Block the lower grill today
  6. tumbleweed
    4,067
    687
    Eastern Oregon
    What the scan gauge reads for engine coolant temperature is just fine. What is really needed is a way to monitor inverter coolant temperature. Then we could block the whole grill (upper and lower) without fear.
  7. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    From the inside or the outside?
  8. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I wonder if R7 could tell us that information using TechStream?
  9. Airbalancer
    892
    73
    Cobourg, On, Canada
    outside
  10. sumguy
    sumguy Junior Member
    92
    Ohio
    Winter temps (now thru March) rarely get over 40. Deep winter hangs out in 20's and with the occasional arctic blast. Going with 100% lower, 1/2 inch foam. No ScanGauge but as long as I leave the top open there shouldn't be a problem?
  11. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    i do 100% as soon as temps hit 50º been doing it for 5 years....hopefully, i be ok
  12. tumbleweed
    4,067
    687
    Eastern Oregon
    I think if the top is open you will be OK till spring. BTW I think the ScanGaugeII is on sale for $137 or so.
  13. bighouse
    bighouse Active Member
    822
    126
    Guerneville, CA
    Do any of you Grillblockers use a garland or wreath at this time of year to block your grill???
  14. Tideland Prius
    16,017
    No but it would be in the spirit of the holiday season!
  15. dan2l
    dan2l 2014 Prius v wagon
    654
    263
    Vancouver Wasington
    2014 Prius v wagon
    I removed the sheild that is above the radiator close to the hood latch (3 pop out plastic rivits). Then I slipped a piece of carpet down the slot onto the front of the radiator, I attached 2 wires like cabletyes to hold it in place, it covers about 50% of the radiator. Then I replaced the shield.
    I am not really happy with this. I want more blockage and easier ability to adjust it if I get a warmer day. I will keep working on it.
    Thanks,
    Dan
  16. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    I recommend you undo your cardboard block. If your blocking the top half of the radiator your really blocking all of the inverter radiator, this you do not want to do. I would recommend the pipe insulation method as being easier to implement and you can selectively remove pieces to account for temperature changes.
    Wayne
    2 people like this.
  17. Airbalancer
    892
    73
    Cobourg, On, Canada
    I was able to to get the top off but could not get my hand there to do anything
  18. kawita
    kawita Junior Member
    88
    Batavia, IL
    Went ahead and blocked the lower grill 99% today.
    You'll notice the engine block heater plug in the upper right corner.
    I don't think it looks that bad...
  19. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Looks good. After the first snow and sanding it will all blend in nicely.:)
  20. Mitchellsprius
    Mitchellsprius New Member
    91
    monterey
    Thanks
    So your saying on Gen III block lower grill. My temps are between 41 to 65 most of the time.
