2010 Prius OEM-quality Fog Light Kit Now Available!
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Danny, May 10, 2010.
  1. exbauer
    exbauer Active Member
    1,185
    96
    Washington
    I ordered my set. Can't wait to fill in the blanks on the Prius. Hopefully the install is pretty easy.
  2. putty
    putty Member
    147
    39
    somewhere in the swamps of Jersey
    the install is easy, the only tricky part is pulling the wire threw the grommet/firewall
    2 people like this.
  3. HI MPG
    HI MPG Active Member
    789
    133
    93
    Orange County, CA
    I agree. The installation is not that tough and the instructions are very simple to follow. Pulling through the grommet/firewall was a bit of a challenge, but if you tape the connector together like the picture, it should work fairly easily. Just pull slowly put with enough tug to get through the grommet.
    I believe another user said to inventory the screws and note their location when taking off the front undercover. I just went at it blindly and found that 1) one of the screws is not securing tightly, and 2) I have one extra (I've checked every hole on that black tray and each are covered with a screw...). I finally gave up. To make it easier, make sure you have sufficient space in the front (jacked or on ramps); it will make the installation that much easier.
    2 people like this.
  4. BBaggins
    BBaggins New Member
    26
    Cornfields of Illinois
    Best kit ever. Thought the grommet would be harder but followed the instructions and used the dish soap. No problem!
    The dash switch is first class!
  5. curtisfast
    curtisfast New Member
    What bulbs do these fogs use? ..
  6. putty
    putty Member
    147
    39
    they come with the needed H11's
  7. HI MPG
    789
    133
    93
    Orange County, CA
    I swapped out the bulbs that came with the kit with some yellow 2500K bulbs.
  8. RL Prius
    RL Prius Junior Member
    77
    Bay area
    HI MPG,
    Are those real HID bulbs?
    It looks nice and bright !
  9. HI MPG
    789
    133
    93
    Orange County, CA
    Thanks!
    Yeah, they are HIDs. I bought them from this retailer:
    HIDExtra.com - The Best Source for HID Xenon Light Conversion Kits
    Went with the 6000K kit. Easy installation, nice white color with tinges of blue at the edges, and haven't had any issues with them at all... (sorry about the shameless plug, I swear I don't have an endorsement deal with them. :) )
  10. Tideland Prius
    16,051
    Nice!!! What did you use for fogs? halogen or HID?
  11. HI MPG
    789
    133
    93
    Orange County, CA
    Thanks TP! I went with halogens. A few things turned me away from using HIDs for the fogs: 1) cost since I don't intend to use them that often, and 2) energy drain associated with the HID kit (less efficient). This is where I bought them:
    JDM Yellow Headlights by Luminics
    2 people like this.
  12. chartquist
    chartquist New Member
    37
    Memphis, TN
    Installed my fog light kit today. It looks terrific! Very high quality and well engineered. I too had a little trouble with the bridge connector cutting through the brown wire insulation, but once I stripped it a bit everything was fine.
  13. Tideland Prius
    16,051
    Thanks!
    hmm, two other forums have said they're not longer an authorized luminics distributor... there is luminicsusa.com though...
  14. HI MPG
    789
    133
    93
    Orange County, CA
    Thanks odd... I ordered from them no longer than 3 weeks ago.
  15. Tideland Prius
    16,051
    Oh I'm sure they still ship the product out but I'm just curious why they're not longer an authorized distributor (the forum posts that I saw were from 2006 so it's been a while) and what does that entail.
  16. MJ225
    MJ225 New Member
    39
    I just finished my install and made the same observation. Some of the pictures looks like its a flush fit. Is it just us 2 that did something wrong? Anyone, please advise with your experience. Thanks in advance.
  17. exbauer
    1,185
    96
    Washington
    The fog lamps on the V are not flush mount either. The kit is great. The illuminated switch could match the green lighting in the car a bit better. But, that's about it.
  18. Dmanpizza
    Dmanpizza 2010 IV Solar Roof & Navi
    57
    I got mine last week and installed them. The kit is very nice. The switch really does look factory. I was a little concerned with how recessed they looked. I really am very pleased with the look and the kit:)
  19. MJ225
    MJ225 New Member
    39
    Thanks, just wanted to make sure it wasn't just me.
  20. deltron3030
    deltron3030 New Member
    437
    64
    Lakewood, CA
    My grey plastic surrounds aren't perfecty flush fitted against the car nor are the lenses perfectly flush against the surrounds...about 98% perfect
