1. Offline
    ronhowell New Member
    Oct 4, 2007
    Message Count:
    677
    30
    Cypress, CA.
    Your Vehicle Year:
    Anyone at the Detroit show note the OE tire manufacturer and if the recommended pressures are still 35F/33R psi? Also did anyone engage the Chief Engineer on the merits advocated by many on PC of the higher values many use?
  2. Offline
    HTMLSpinnr Gen III Forums Moderator
    Dec 8, 2003
    Message Count:
    4,975
    717
    Surprise, AZ (Phoenix)
    Your Vehicle Year:
    Sticker inside the door still listed 35/33 on the 15" and I believe even less on the 17" package.
    Doug Coleman did acknowledge our need to "over inflate".
    The tires shown on the Prius we saw are not necessarily the final tire, and we were specifically told that at the event.
  3. Offline
    Boo Boola Boola Member
    Feb 13, 2007
    Message Count:
    5,086
    602
    Flushing, NY
    Your Vehicle Year:
    Ron,
    You probably missed it, but ken1784 answered your questions posed on another thread regarding the recommended psi and the tires we saw in Detroit:
  4. Offline
    a priori Canonus Curiosus
    Aug 14, 2007
    Message Count:
    2,668
    313
    Chicagoland (West)
    Your Vehicle Year:
    He certainly did acknowledge our discussions and interest in tire pressure, though I remember that his words were more along the lines of "properly inflate.":rolleyes:
  5. Offline
    Rangerdavid New Member
    Jun 13, 2006
    Message Count:
    1,314
    Boone, North Carolina
    Your Vehicle Year:
    I'm sure he would be aware of the liability issues if he had given any indication of condoning my running 50-48 in my tires. :D
  6. Offline
    qbee42 My other car is a boat
    Mar 2, 2006
    Message Count:
    17,752
    2,804
    Northern Michigan
    Your Vehicle Year:
    He said: "You know how to properly inflate your tires!"
    Tom
  7. Offline
    Mike Dimmick New Member
    Aug 8, 2008
    Message Count:
    959
    226
    Reading, UK
    Your Vehicle Year:
    The wear pattern seen on cars that have used Toyota's stated inflation pressures - worn on the shoulders of the tyre, tread left in the centre - is consistent with under-inflation. To me, that says that the stated pressures are flat-out wrong.
    My car's sticker states 35/33 for 'regular' driving, 38/36 for 'highway' driving. I generally run 42/40.
    If the car, for ride comfort, needs pressures that are too low, the suspension is too stiff. F1 cars may rely on sidewall flex for much of their suspension travel, but this is a road car.
  8. Offline
    Dec 8, 2003
    Message Count:
    4,975
    717
    Your Vehicle Year:
    40/38 for the non-OEM's, the handling was to scary around corners otherwise. Integrity tires felt fine at 42/40 and that's where the new car will start.
  9. Offline
    skruse New Member
    Apr 6, 2004
    Message Count:
    1,407
    76
    Great Central Valley, Fresno, CA
    Your Vehicle Year:
    By running the 42/40 posted on PC I obtained 42k mi on my OEM tires. I am now on Michelin Hydroedge (90k) tires with no drop in mpg.
  10. Offline
    Oct 4, 2007
    Message Count:
    677
    30
    Cypress, CA.
    Your Vehicle Year:
    Thanks for all the comments everyone.
    Given what appears to be the plusher seating provided in the G3 Prius it would seem that higher tire pressures would be more tolerable from a ride-comfort standpoint. I run my 2008 Prius at 42F/40R, as do many others I believe. The ride is firm, but that is the way I like it. Not nearly as firm as the MG-TC I drove in my youth, but that was in a class of its own!
  11. Offline
    Aug 14, 2007
    Message Count:
    2,668
    313
    Chicagoland (West)
    Your Vehicle Year:
    Proffered Edit: I'm sure he would have been advised by Toyota legal counsel be aware of the potential that he could increase liability issues on the part of Toyota if he had given any indication of condoning my the practice of running 50-48 in my ones tires. :washing:
  12. Offline
    hgdempsey New Member
    Jul 20, 2009
    Message Count:
    Puyallup, Wa
    Your Vehicle Year:
    Yokohama's AVID S33D states 44PSI
Share This Page
