1. Offline
    poodlemaster187 New Member
    Start a Conversation
    Apr 6, 2009
    harrisburg, pa
    Your Vehicle Year:
    People have reported having no issues towing up to 1000lbs with no issues with current G2 prius. The 2010 prius has 2 more horsepower than corolla and corolla is rated at towing 1500lbs. The new prius in power mode should definitely not have any problems of course with no backseat passengers towing 1000-1500lbs. And, yes i know the cvt may not be able to handle it but i find that doubtful as other cvt's out there are able to tow. I would just like to tow a 1000lb jet ski and 200lb trailer, and don't want to step down from my current prius to a corolla. Any thoughts? Oh, and I'm well aware that toyota won't be giving the prius a towing capacity.
  2. Offline
    Jul 12, 2007
    10,602
    488
    Adelaide South Australia
    Your Vehicle Year:
    Check local law, in Australia it is illegal to tow any weight trailer with a Prius.
    Manufacturers rated towing capacity braked or unbraked = 0kg
  3. Offline
    qbee42 My other car is a boat
    Mar 2, 2006
    18,043
    2,916
    Northern Michigan
    Your Vehicle Year:
    You do realize that the Prius doesn't have a CVT in any conventional sense of the word, so stating that other cars with CVTs can tow is meaningless.
    Tom
  4. Offline
    • Moderator
    HTMLSpinnr Moderator
    Dec 8, 2003
    5,191
    789
    Surprise, AZ (Phoenix)
    Your Vehicle Year:
    Folks in the past have towed small utility trailers w/ the Prius. I'd be concerned more about stopping power and braking ability, but Motor/Generator "temps" should be monitored via Scangauge if extended hill climbing is expected.
  5. Offline
    paulemus New Member
    Jan 4, 2010
    93
    San Diego
    Your Vehicle Year:
    I don't understand why people want to defeat the aerodynamic drag coefficient with add ons like racks and trailers. I go camping, but want all my gear packed in a slip stream capsule for the trip down the highway.
  6. Offline
    Mar 2, 2006
    18,043
    2,916
    Northern Michigan
    Your Vehicle Year:
    The answer is simple: not everything will fit inside of a Prius. For example, it's pretty hard to fit a 17' canoe inside. I suppose you could cut it into pieces, or perhaps compact it into a block, but that might hurt the utility of it just a tiny bit, and certainly make it harder to paddle.
    Tom
    1 people like this.
  7. Offline
    Skoorbmax Senior Member
    Mar 19, 2010
    2,629
    254
    Western NY
    Your Vehicle Year:
    If it was possible to fit a Jetski in the back of an enclosed Prius your post would have made more sense. :)
    1 people like this.
  8. Offline
    Much More Better Active Member
    Nov 2, 2009
    583
    118
    Your Vehicle Year:
    I actually LOL'ed. Thanks Tom :)
  9. Online
    bwilson4web 03 and 10 Prius
    9,720
    2,458
    Huntsville AL with 2003 Prius
    Your Vehicle Year:
    Agreed, especially with rear drum brakes like the NHW11 and NHW20s. The ZVW30 are much improved.
    If my vehicle display is limited, I would monitor the traction battery temperature before MG2 temperature. The traction battery can be 'heat pumped' to higher temperatures from the exothermic charging on the downgrades. For sure, use "B" at every opportunity when descending. When towing, the goal should be on reducing stress on the Prius by using lower speeds and "B" on the downgrades.
  10. Offline
    Nov 2, 2009
    583
    118
    Your Vehicle Year:
    Are you serious? How much difference will a bike rack make? (shakes head) It's not on permanently anyway. How else do you travel with two mountain bikes?
  11. Offline
    Mar 2, 2006
    18,043
    2,916
    Northern Michigan
    Your Vehicle Year:
    It will make a huge difference, depending on the type of rack. The Prius has very good aerodynamics, unlike most cars. Sticking anything into the airflow will have a noticeable effect.
    As for not being on permanently, that is the key. It's all about priorities. If you want to go biking, you have to carry bicycles.
    Tom
  12. Offline
    garygid Senior Member - Blizzard Pearl
    Aug 23, 2009
    380
    22
    Orange County, CA
    Your Vehicle Year:
    Assuming that one needs to tow something, how and where does one get and mount a good tow hitch?
    Thanks
  13. Offline
    Mar 2, 2006
    18,043
    2,916
    Northern Michigan
    Your Vehicle Year:
    Curt hitch is generally considered the best for the Prius. Mounting it is simple if you can use hand tools.
    Tom
  14. Offline
    cycledrum PSOCSOASP
    Apr 9, 2008
    6,173
    611
    NorCal
    Your Vehicle Year:
    Keep in mind a trailer will add more rolling resistance from tires and aerodynamic drag. So, if you have 500 lb trailer/load and 325lb occupants, it's effectively more than the 825 payload limit of the car.
    I'm sure the new Prius would be pretty bad at towing 1,200 lbs.
  15. Offline
    vegasjetskier New Member
    Dec 26, 2009
    268
    27
    East Coast of Florida, USA
    Your Vehicle Year:
    I think the GVWR is for what you put IN the car, so as not to exceed the axle ratings or the ability of the brakes to stop the car.
  16. Offline
    bcy475 New Member
    Vermont
    Your Vehicle Year:
    Is one better off towing a trailer(400lbs) and putting most of the stuff one would take IN the Prius in the trailer instead?
    I load the Prius up to the top usually for a trip to PA and last year was just off balance enough that the gas guage was off by 2-3 bars. This year not need as much but still a bunch as left most there in a storage unit.
  17. Online
    cwerdna Senior Member
    Sep 4, 2005
    11,670
    1,664
    SF Bay Area, CA
    Your Vehicle Year:
  18. Offline
    RobH Senior Member
    Sep 18, 2006
    1,551
    289
    Sunnyvale, California
    Your Vehicle Year:
    I've towed a 560 pound teardrop size trailer behind a 2006. The mileage was about 32 mpg instead of the more usual 47. It all worked, but the legal speed limit is 55 with a trailer here in California. If it's all equipment that fits inside the car, then that would probably be better than towing the trailer. Another option would be a roof rack, although that has got to make a similar impact on mileage and wind sensitivity.
  19. Offline
    Teakwood New Member
    Jun 23, 2010
    489
    67
    New Mexico
    Your Vehicle Year:
    ... or you could buy or rent a different vehicle if you want to tow something.:eek:
  20. Offline
    frayz Junior Member
    Jun 25, 2010
    30
    Mobile, Al
    Your Vehicle Year:
    Hmm. Ok It seems everyone here is against this idea complete. I am a very avid prius owner. I plan on buying another prius in the next year or so for the wife. so she doesn't have to drive our other vehicle(07 dodge ram v8).
    I just purchased a curt hitch for my 08 prius after much reading. i have a <200lb jet ski trailer and a 400-500lb motorcycle I plan on hauling with it. I think it should be similar as to driving the car with 4-5 grown people in it(avg 150-200lb each) aside from the added wind drag.
    This all being said. I've seen people in the past pull small trailers and I would just like to save a little bit more money on long road trips getting 30-40mpg instead of 17-20mpg in my truck.
Share This Page
