1. Offline
    usbseawolf2000 HSD PhD
    Sep 22, 2004
    Message Count:
    9,659
    1,270
    Queens, NY
    Your Vehicle Year:
    - The new Prius eliminates the need for the thermos bottle system that preheats the catalyst to reduce emissions. It also reduces the time to heat cabin air by a full minute.
    - The LEDs in the taillights consume 88% less energy than previous incandescent bulbs.
    - LED headlights are also available that use 17% less energy.
    - You get a car the EPA rates at a combined 50 mpg, despite being 110 pounds heavier.
    - The fruit of a massive engineering and styling exercise that has occupied four and a half years time and the best efforts of 2000 engineers, led by Chief Engineer Akihiko Otsuka.
    - Otsukasan explained to me that when he was appointed chief engineer, his mandate was to improve the performance of the new Prius by 75 percent, a demanding goal considering the high standards the generation two model set when it first appeared in 2003.
    Source
    - In road tests last week by Bloomberg, the new Prius averaged 48 mpg to 53 mpg in California’s Napa County.
    Source
    - when attempting to pass in "Eco" mode, the 2010 Prius takes 5.8 seconds to scoot from 30 miles an hour to 50 mph; in "Power" mode it takes just 4.4 seconds, a 24 percent improvement.
    For reference, the Iconic Prius takes about 4.8 seconds for 30-50 mph.
    Source
  2. Offline
    Jun 27, 2007
    Message Count:
    1,671
    87
    Out there, somewhere
    Your Vehicle Year:
    75% of what? 0-60 time? Fail. MPG. Fail. Emissions? Already nearly perfect. Fail. Battery life. Same one. Fail. EV time. Fail. Sticker price? Fail.
    Not to say that the 2010 isn't wornderfully improved, but the 75% figure is meaningless.
  3. Offline
    bwilson4web 03 and 10 Prius
    Message Count:
    7,495
    1,394
    Huntsville AL with 2003 Prius
    Your Vehicle Year:
    <AHEM>I believe it preheats the engine block. Thanks for the 'heads up,' I'll pass on that source.
  4. Offline
    KK6PD _ . _ . / _ _ . _
    Mar 24, 2008
    Message Count:
    3,083
    455
    Los Angeles
    Your Vehicle Year:
    Great, that means that it would take me 9 minutes, instead of 10 for me to get cabin temp to 74, at 5am, and 41 degree outside air temp. on my 15 minute drive to work!
    The rest of you all who live in the real ICEBOX, well you can gauge your results accordingly!
  5. Offline
    HTMLSpinnr Gen III Forums Moderator
    Dec 8, 2003
    Message Count:
    4,975
    717
    Surprise, AZ (Phoenix)
    Your Vehicle Year:
    The tail lights in the US prototypes were still incandescent. :-(
  6. Offline
    fuzzy1 New Member
    Message Count:
    4,363
    716
    Your Vehicle Year:
    Isn't that part of the chain towards getting cabin heat?
    Considering how little attention most people pay towards engine warmup, cabin heat is another way to advertise this improvement.
  7. Offline
    Sep 22, 2004
    Message Count:
    9,659
    1,270
    Queens, NY
    Your Vehicle Year:
    That got me wondering if the Li-ion didn't get delayed... Should we expect 75% improvement in the next gen plug-in?
  8. Offline
    Sep 22, 2004
    Message Count:
    9,659
    1,270
    Queens, NY
    Your Vehicle Year:
    It seriously take you 10 mins? I have not measure but the warm air comes out of the vent shortly after I merge into the highway. I live close to the highway so I probably won't see one full minute advantage.
  9. Offline
    • Moderator
    Message Count:
    27,008
    1,175
    Your Vehicle Year:
    Sounds about right. It takes me nearly 3/4 of my route before the Prius would shut down at a traffic light at around 0°C
    Not that I remembered. They were LEDs. Check out KK6PD's pic of his Barcelona Red vs. the new one.
  10. Offline
    Dec 8, 2003
    Message Count:
    4,975
    717
    Your Vehicle Year:
    Right - the Brake LED cluster doubles as a rear tail light. I'm referring to turn signal indicators and reverse lights. Guess I wasn't specific ;)
    [IMG]
  11. Offline
    john1701a New Member
    Jan 6, 2004
    Message Count:
    5,511
    968
    Your Vehicle Year:
    I get decent heat by the time the second 5-min segment appears on the consumption screen. That's from a garage at about 20°F in outside temps below 0°F on the highway about 3 blocks from my house.
    My guess is the advantage will reveal itself more for those that do lots of non-highway driving. But then again, at 70 MPH, the chilling affect on a car is well pronounced.
  12. Offline
    Apr 13, 2004
    Message Count:
    14,718
    519
    South Puget Sound, WA
    Your Vehicle Year:
    one minute faster on warmup sounds like a near 75% improvement on that. which in turn, reduces the inefficient segment of the early morning drive by a similar amount meaning that people with short commutes like me (me 7.1 miles, her 5.5 miles one way) may see a very significant overall improvement. on both our commutes, the max speed is 35 mph... makes warmups as slow as they can be.
    and i think the 75% improvement figure is based on several different parameters... power is 7%, gas mileage is 6%, etc.... add it up, might not be all that far from 75% after all
  13. Offline
    Jan 6, 2004
    Message Count:
    5,511
    968
    Your Vehicle Year:
    Yup, we could see a big bump in efficiency during that first 5-min warmup segment.
    It will be fascinating to hear the first ownr reports coming in. Of course this time, we have a summer debut... which will be quite different from the winter debut last time. Remember that? Reporters took advantage of the cold weather MPG to give the impression the Iconic model didn't deliver as promised. But then when the weather warmed, all the criticism vanished.
  14. Offline
    • Moderator
    Message Count:
    27,008
    1,175
    Your Vehicle Year:
    Ohhh, taillight cluster lol.....
  15. Offline
    Jun 27, 2007
    Message Count:
    1,671
    87
    Your Vehicle Year:
    One, I don't think that addition was what was said.
    Two, that is such astonishingly bad math thinking, I don't know how to respond. If I take 10% of the federal health budget, 10% off the military, 10% off education, 10% off welfare, 10% off foreign aid, have I reduced the Federal budget by %50?
  16. Offline
    a priori Canonus Curiosus
    Aug 14, 2007
    Message Count:
    2,668
    313
    Chicagoland (West)
    Your Vehicle Year:
    No, but everyone who heard that is now 50% more stupid for having heard it!:rolleyes:
    (My apologies to Dave and some old movie script writer. Was it in Tommy Boy?)
  17. Offline
    danl New Member
    Jan 26, 2009
    Message Count:
    230
    Boston, MA
    Your Vehicle Year:
    Vague statement yes, but I believe the effort for 75% improvement probably went into other factors of the car as well, i.e. space, comfort, and performance.
  18. Offline
    danl New Member
    Jan 26, 2009
    Message Count:
    230
    Boston, MA
    Your Vehicle Year:
    Most politicians would say yes. :p
  19. Online
    David Beale New Member
    Jul 24, 2006
    Message Count:
    3,454
    375
    Edmonton Alberta
    Your Vehicle Year:
    I suspect the "75% improvement" is a "translation error". They probably meant "reduce inefficiency to 75% of previous model", or a 25% improvement in efficiency.
    Just getting rid of the thermos, electric coolant transfer pump, and fuel tank bladder is a real benefit as far as I'm concerned!
    During the Edmonton "meet the Prius" event, I was explaining to another participant the bladder was gone and one engineer commented to me "that bladder reduced your tank capacity by five litres in the winter, right?" My answer was no, because there was never any way to figure out if or by how much it was/is reduced. It was/is inconsistent at best.
    I won't comment on the time taken to get the cabin temp up from a cold start, because unless I drive Pearl for more than 30 min. the cabin never fully warms up. We don't have a thermometer inside anyway (though I had one stuck to the dash for a year, but discarded it as it was garbage). I do get nice hot air blowing out of the vents after about 5 min. of driving. Of course our ambient temps are a little low right now (STILL!!), currently at -27C, "warming up" to a nice -21C this afternoon. :)
  20. Offline
    • Moderator
    Message Count:
    27,008
    1,175
    Your Vehicle Year:
    ha! It's already reduced in the summer (most I got into a tank was 40 litres). In the mild west coast weather, I'm in the 30s and once during this winter's snowy stretch, the light came on and I only pumped in 27 litres!
Share This Page
