1. Offline
    Lafferty Member
    Start a Conversation
    Apr 20, 2009
    163
    65
    Pacific Palisades
    Your Vehicle Year:
  2. Offline
    Lafferty Member
    Apr 20, 2009
    163
    65
    Pacific Palisades
    Your Vehicle Year:
    Found a couple more renderings at Motor Trend.
    [IMG]
    [IMG]
  3. Offline
    Matt Herring New Member
    Apr 28, 2009
    421
    50
    North Andover, MA
    Your Vehicle Year:
    Any documentation on how these "aero kits" improve aero?
  4. Offline
    bruceha_2000 Senior Member
    Jan 2, 2004
    2,686
    43
    South Burlington, VT
    Your Vehicle Year:
    Gee, can we 'uglify' the front end even more? I already don't like the gaping lower 'grill' on the stock model. At least it isn't as big as the one on the new Insight.
  5. Offline
    Lafferty Member
    Apr 20, 2009
    163
    65
    Pacific Palisades
    Your Vehicle Year:
    Yeah, that grille in the bottom pic isn't very attractive in my opinion.
  6. Online
    • Moderator
    HTMLSpinnr Moderator
    Dec 8, 2003
    5,191
    789
    Surprise, AZ (Phoenix)
    Your Vehicle Year:
    Some of it looks sweet, some does detract. I'd be concerned about overall Cd changes compared to improved handling.
  7. Offline
    Apr 28, 2009
    421
    50
    North Andover, MA
    Your Vehicle Year:
    In my opinion, these kits increase drag. Fine line between looking cool and mpg but this one gets a thumbs down from me on "aero." :mad:
    The only "aero" improvements that might be had are the upper grill block on the one and the side skirts on the other. The rest look like they eat air, trap it in the car and increase drag. These are definitely not "aero" kits...they are "bling kits."
  8. Offline
    • Moderator
    27,762
    1,327
    Your Vehicle Year:
    Kinda looks like a Mazda3 with that new kit for the front.
  9. Offline
    hyo silver Away
    Mar 2, 2005
    14,900
    1,201
    Sunset
    Your Vehicle Year:
    How about a lower grille block that opened when needed? That actually would be 'aero', as well as improving aesthetics and thermal efficiency.
  10. Offline
    Jan 2, 2004
    2,686
    43
    Your Vehicle Year:
    I think it would have to fill the space rather than just block the air from flowing through. Otherwise the increased flat front surface would INCREASE Cd.
    But, that is what I WANT Toyota to do. Put in an automatic aerodynamic, ICE temp based, blocking feature. They presumably want a low emission, high MPG car, why don't they do something to automatically keep the ICE at the desired temp in both hot and COLD weather??
  11. Offline
    1SMUGLEX I love the smug!
    Apr 29, 2009
    315
    50
    Atlanta
    Your Vehicle Year:
    depending, aerokits can help/hurt drag. they won't affect handling unless they weight 500lbs :D
    I like them.
  12. Offline
    don_chuwish Well Seasoned Member
    May 1, 2009
    657
    65
    Southern Oregon
    Your Vehicle Year:
    +1. Pretty simple thermally actuated louvre system. Heh, I say "simple" as if I could build it! But for someone with the right skills and resources, probably not too tough.
    - D
  13. Offline
    harry r slowly turning green
    Oct 31, 2010
    106
    NW of chitown
    Your Vehicle Year:
    interesting ideas. kinda have me thinking of some type of black foam pieces to be wedged in between the horizontal strakes of the lower area..
  14. Offline
    Ted in Olympia New Member
    Nov 29, 2010
    84
    Olympia WA
    Your Vehicle Year:
    They do not look that much better/different to me to be worth using. Also Toyota spend a lot of effort to get the drag coefficient down to .25 and I would want to see some wind tunnel testing to show that these are even better. I would bet that these "aero" kit makes it a lot worst.
    IMO if you want to do something like this to a car you should buy a Mustang or some other "sports" car. When you get done putting an aero kit on a Prius, you still have a Prius.
    TED
  15. Offline
    garylow Junior Member
    Jan 1, 2012
    16
    new jersey
    Your Vehicle Year:
    Instead of blocking the air that would increase drag why not use it to divert the air to keep block hot and open when it needs to cool it down? A y shaped duct with a flap that is controlled by a temperature controller to switch where the air goes depending on block temperature and/or outside temperature? Just a thought.
Share This Page
