2010 Prius with P0A93 P0A94 c1259 c1310
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Sweetgreen02, May 1, 2016.
  1. Sweetgreen02
    Sweetgreen02 Junior Member
    Denver
    About three weeks ago while driving my Prius and accelerating the car jerked suddenly and warning lights came on. I was able to read the above codes with tech stream. The car still drives but has limited horsepower. The engine also does not seem to rev down like a normal hybrid. I have not had good experiences with the local Toyota dealer so I am wondering if there is way that I can further diagnose the issue and potentially fix it
    48,945
    how is your 12v health? how many miles on her?
  3. Sweetgreen02
    Denver
    Just replaced with an optima less than a year ago.
    When I cleared codes, the exclamation point, the check engine, and the traction light flashed off but immediately came back
    48,945
  5. Mendel Leisk
    38,207
    Failed inverter coolant pump?
    P0A93 code | PriusChat
    Seems like something you shouldn't delay on, and potentially more damage if you let it slide.
  6. Sweetgreen02
    Denver
    166 on the car
    5k on the optima 12v
  7. Sweetgreen02
    Denver
    Is there any chance this is subject to a recall so I can get it done without paying too much?
  8. bisco
    48,945
    you can log into toyota's owners website with your vin to see if you have any open recalls.
    still might be worth checking the 12v, it's quick and dirty.
  9. Mendel Leisk
    38,207
    I was thinking warranty?
    Oh hang on: 2004?
  10. Sweetgreen02
    Denver
    It is a 2010
  11. Sweetgreen02
    Denver
    I got out the voltmeter. Car had been at rest for
    Several hours. It was 12.33
  12. bisco
    48,945
    that's low for a one year old battery, maybe you should throw a trickle on her. not saying it's the problem though.
  13. Bsedgal
    Bsedgal Junior Member
    Il
  14. Mendel Leisk
    38,207
    Isn't that warranty then, 8 years? Or too much mileage?
