1. Offline
    Flying White Dutchman New Member
    Dec 29, 2007
    Message Count:
    3,765
    235
    Your Vehicle Year:
    anyone try the glide and stuff with the 2010 prius
    is it still the same ?
  2. Offline
    • Moderator
    Message Count:
    27,008
    1,175
    Your Vehicle Year:
    Yeah but harder. The TCH was already hard to P&G. I actually had to cheat and use N.
    In the 2010, it's slightly easier than the TCH but still harder than the Gen 2.
  3. Offline
    kinghuang New Member
    Feb 28, 2005
    Message Count:
    112
    Calgary, AB, Canada
    Your Vehicle Year:
    What do you mean by it's harder to pulse & glide in the 2010? Is it harder to hold the gas pedal at a point where it's effectively N?
  4. Offline
    HTMLSpinnr Gen III Forums Moderator
    Dec 8, 2003
    Message Count:
    4,975
    717
    Surprise, AZ (Phoenix)
    Your Vehicle Year:
    Pedal modulation may be harder, but there's a distinct region in the hybrid system indicator (which some have coined HSI, but that will always be an aircraft instrument for me) that specifically shows no charge or power delivery.
  5. Offline
    ronhowell New Member
    Oct 4, 2007
    Message Count:
    677
    30
    Cypress, CA.
    Your Vehicle Year:
    HSI? - what aircraft indicator? I'm familiar with a VSI!
  6. Offline
    Oct 4, 2007
    Message Count:
    677
    30
    Cypress, CA.
    Your Vehicle Year:
    Question. If "Pulse and Glide" is really the optimum way to maximize your MPG in the Prius, with minimal use of the traction battery at all times, why have an EV button at all?
    Using it kind of defeats the objective, doesn't it?. Wouldn't it have been preferable for Toyota to have engineered the G3 Prius to simply glide when taking one's foot off the accelerator at all times, and substituted a "Regen" switch in place of the EV button? At the same time, activating regeneration as usual when applying the brake.
    Just a thought!
    Or maybe that is what the "Eco" mode does.
  7. Offline
    • Moderator
    Message Count:
    27,008
    1,175
    Your Vehicle Year:
    Yeah. On the Hybrid System Indicator (HSI), when you see no bars on the screen, it's effectively gliding. However, you really have to be careful because there may even be a sliver of a bar and you'll be in EV mode instead of gliding.
    On several occasions, I thought I was gliding and when I switched to the Energy Monitor, I was EVing...
    EV Button isn't really used for driving even though the media has been touting it as such (even saying that it can improve your mileage because it worked for them on the last mile of the test route).
    EV Drive Mode for me works in the following situations but it may vary for you
    - moving in/out of the garage
    - switching parking spots
    - moving in and around an enclosed area such as an underground parking lot
    - forcing the engine off on part of the commute it normally would be off on its own
    - forcing the engine off on the final approach to home on a route it'll normally be off and you don't need a warm engine (i.e. last ride of the day)
    - keeping the engine off til you've had a chance to merge onto the main street from a parking lot
    I'm sure you can come up with more situations.
  8. Offline
    Dec 8, 2003
    Message Count:
    4,975
    717
    Your Vehicle Year:
    Horizontal Situation Indicator - usually electric and typically replaces a vacuum driven directional gyro. Overlays VOR (or other course info like GPS), ILS, etc. with the heading indicator.
    See: Wikipedia: Horizontal Situation Indicator
  9. Offline
    Zhentar New Member
    Jan 15, 2009
    Message Count:
    33
    Madison, WI
    Your Vehicle Year:
    The Prius wasn't designed with the goal of great gas mileage for hypermilers; it was designed for good gas mileage for normal drivers while still feeling like a normal car. The light braking effect not only mimics the feel of a non-hybrid, but the energy can be used to keep the engine turning without consuming any gas or battery, when needed.
  10. Offline
    Dec 29, 2007
    Message Count:
    3,765
    235
    Your Vehicle Year:
    its not to mimic ice braking like a normal car its to regen and put energy into the battery
    and then the ICE is not turning without gas its not turning at all.
    of course the regen is less in off gaspadel then with braking
  11. Offline
    Mormegil New Member
    Sep 25, 2007
    Message Count:
    241
    I'm pretty sure it IS meant to simulate ICE compression braking in a standard automatic transmission car.
    Energy usage is less efficient with this feature, than without. So, why would they include it merely to regenerate the battery when regular braking will do it. Keep in mind, a manual transmission car doesn't have this issue, as you would typically apply clutch.
  12. Offline
    • Moderator
    Message Count:
    27,008
    1,175
    Your Vehicle Year:
    It's to simulate an automatic transmission which will have some drag when you let go of the accelerator.
  13. Offline
    Jul 12, 2007
    Message Count:
    10,558
    430
    Adelaide South Australia
    Your Vehicle Year:
    Sorry Mr Dutchman, I have to agree with the last 2 posters. It would be better if this wasn't the case to preserve that regen energy as kinetic energy to reduce conversion losses otherwise.
    It's all about making the car feel like old outdated cars. I'd love to be able to switch that feature off.
    What about including a foot off glide function in the ECO mode next time please Toyota? Why not an optional firmware update now?
  14. Offline
    SageBrush New Member
    Jun 4, 2008
    Message Count:
    5,841
    759
    Your Vehicle Year:
    I find the current setup where regen braking occurs when the gas pedal is completely released to be the most convenient for city driving. It means I can coast, glide, or accelerate all with one pedal.
  15. Offline
    V8Cobrakid Green Handyman
    Jun 6, 2004
    Message Count:
    3,703
    110
    Your Vehicle Year:
    i think the dutchman may have been refering to the incorrect reference of "letting the engine spin without fuel".. cuz it doesn't spin unless you exceed 46mph (gen 3)
    i'm wondering the recovery percentages of gen 2 to gen3
    i love to see the steps each car has taken... good data is hard to find. (except here.. given time)
  16. Offline
    • Moderator
    Message Count:
    27,008
    1,175
    Your Vehicle Year:
    That'll be awesome because as it stands, both Wayne and I had problems achieving Glide mode during the test drives.
  17. Offline
    PriusSport New Member
    May 20, 2008
    Message Count:
    1,463
    77
    SE PA
    Your Vehicle Year:
    Is it my imagination, or is my highway mileage really improving when I " gun" it up to 75-78 mph and then glide down to 65? On a level highway? My mpg was reading in the 80s at 75 mph the other night. I have an '08 Prius. Looked like I was using a fair amount of battery.
  18. Offline
    Dec 29, 2007
    Message Count:
    3,765
    235
    Your Vehicle Year:
    thats right..
    you got the point
    and the prius also auto glide's at moments when on cruis control and of course when you hit a situation where the gaspadel position and speed and current little downhil road will mean no need to any running motor or ice.
    i have seen this several time's now
    i also notice that when i regen with the gas padel off and no foot brake i put more real amps into the battery then with 30 amps or more of braking.. more energy is stored .
  19. Offline
    adrianblack Member
    Sep 26, 2009
    Message Count:
    447
    185
    Los Angeles
    Your Vehicle Year:
    That's what seems to suck on the Gen III -- it's hard to not be in EV or regen mode with the gas pedal.
    I would be so sweet to have a special ECO mode (hold the bottom for 3 seconds?) That would disable regen on coasting.
  20. Offline
    a64pilot New Member
    Aug 3, 2008
    Message Count:
    771
    56
    Albany Ga.
    Your Vehicle Year:
    P&G works, but for me N is most effective. It's deceptive though because your eating battery charge that is not being replaced, so you get initial great numbers that come down a lot as you deplete the battery, so initially you think your getting great mileage, but then you have to recharge the battery and your mileage comes down then.
    I have only really tried 45 to 25, above 46 I believe the ICE is running and consuming fuel, don't think warp stealth is possible in a Gen III, so I assume the most benefits are below 46 MPH?
Share This Page
