1. Offline
    Bart Baeckelandt New Member
    Start a Conversation
    Aug 8, 2012
    Your Vehicle Year:
    So I just turned 100k a couple weeks ago and now I think my rear wheels bearings are going I have a loud noise coming from the back of the car. I think its coming from the drivers side.
    so where to go to get the best prices on replacements and how bad of a job is it to replace?
    Appreciate feedback
  2. Offline
    Aug 8, 2012
    Your Vehicle Year:
    One other thing is it seems like there are hub assemblies and bearings which way to go??
  3. Offline
    smassey22180 New Member
    Jul 27, 2012
    Your Vehicle Year:
    This is what I use to find bad wheel bearings. Jack the car up. Spin the wheel. Probe the back side of the hub. Compare left to right sides. Amazon.com: Lisle 52500 Mechanic's Stethoscope: Automotive
    Does the noise change when going from pavement to concrete? If it is constant it is wheel bearing. If the pitch changes it may be a bad tire.
  4. Offline
    The Critic Resident Critic
    Oct 28, 2005
    1,972
    360
    Near Mazda Raceway Laguna Seca
    Your Vehicle Year:
    The job is REALLY easy. After removing the rotor, all you need to do is remove the 4 bolts and disconnect the electrical connector holding it in. It's a job that you can do in about 30 min if you are working fast.
    Sent from my iPhone using Tapatalk
  5. Offline
    El Dobro A Member
    Jul 12, 2011
    2,284
    556
    Your Vehicle Year:
    On the way to work a couple of days ago, I heard a crack and then the snap, crackle and pop of a rear wheel bearing. When I got to work, I jacked up the left rear wheel and spun it. Nothing. I got on my hands and looked underneath. A large twig jammed itself into the plastic wheelhousing and was dragging on the street. It sounded just like a bad wheel bearing.
  6. Offline
    spiderman wretched
    Jul 5, 2009
    6,795
    1,197
    Alaska
    Your Vehicle Year:
    OP, what is your general location? Another member had his rear wheel bearings go out prematurely and thought it might be because of the damp, salty location. I will try to find the thread... [edit] here it is.
  7. Offline
    Aug 8, 2012
    Your Vehicle Year:
    Well I ended up replacing the passenger rear wheel bearing I was surprised how rusted the part was already but I guess it was to be expected in Michigan
  8. Offline
    xliderider Active Member
    Apr 19, 2012
    911
    163
    Honolulu
    Your Vehicle Year:
    Should replace them in pairs don't you think? ;)
  9. Offline
    Aug 8, 2012
    Your Vehicle Year:
    Well I taled it over with my mechanic and there was hint of an issue on the other side so I will haold off until next month to do so
Share This Page
