2011 Prius, Alpine INA-Z928HD installation!
Discussion in 'Gen 3 Prius Audio and Electronics' started by BlackSpade317, Oct 2, 2012.
  1. BlackSpade317
    BlackSpade317 New Member
    Indianapolis, IN
    Well today I received my INA-Z928HD and my perfect fit kit from Alpine. I absolutely love this radio with its huge 8inch display! The features this radio has are amazing. HD radio, Bluetooth, Pandora, all my factory steering controls work flawlessly with the Alpine as well. I cant thank Alpine enough for the perfect fit kit that they released for our vehicles, it came with everything I needed to install into my car.
    Dawit and usbseawolf2000 like this.
  2. tach18k
    tach18k Member
    406
    38
    SoCal Beach Area
    Thats very neat
  3. 3264884
    3264884 Junior Member
    New York
    I had the same unit installed in my 2012 Prius 2 on Friday. It took me a while to configure all the options available. The only issue I had was getting the direct connect backup camera to work, the AUX camera was configured as the rear camera. Once I turned the AUX off, it allowed me to configure the direct connect camera to be the rear camera.
    Where did you mount the microphone for the bluetooth? I had the installer mount mine in the factory position in the overhead lights panel.
  4. 1ULV2H8
    1ULV2H8 Member
    66
    25
    Columbia, SC
    That head unit and dash kit looks killer! Wish mine looked that good.
  5. jlulu
    jlulu Junior Member
    BlackSpade,
    Great install with an AWESOME unit! Did you install yourself? What was the difficulty level?
  6. yyyiiikes
    yyyiiikes Junior Member
    84
    Austin, TX
    I waited and waited for that model to be released. Original launch date was April.
    The stock unit was too irritating for the wait so I gave up and went with something.
    Glad to see that it is finally here. Looks very nice.
  7. rrg
    rrg Active Member
    458
    120
    East coast - NJ
    That new trim bezel looks like it will work just fine on the Ipad mini ; )
    Who's will be first to try?
    Your setup does look great with the larger screen size.
    The bezel can be found at Crutchfield.
    Trim bezel part number:
    KTX-PRS8-S, SRI: $199.95
    Toyota Prius (excludes C, V and navigation and JBL models), 2009-2012
  8. greekchampion04
    95
    27
    that looks great! wish i had the cash to do that myself.
  9. BlackSpade317
    Indianapolis, IN
    Yeah I installed it myself, I work for a local car audio shop. It was a breeze to install, Alpine was nice enough to include the wiring harness, antenna adapter, and the module to make the steering controls work flawlessly.
    I mounted my mic on the windshield in the small gap between the mirror and the headliner. We install radios with Bluetooth on a daily basis. From doing so we have found for it to sound the best it should be installed in that location.
  10. Danger
    Danger Member
    175
    22
    Frisco
    WOW!! I didn't know they made such a trim panel and a such a huge screen. It looks perfect. I have a GEN3 IV so I have BT, Navi + back up camera. Can I reuse the mic in my car already instead of the one provided?
  11. Burgosla1
    Burgosla1 New Member
    Virginia
    I
    Just bought a 2010 Prius two weeks ago and i really want to replace the OEM unit. I was seriously considering going with a Pioneer HU (AVH-4400BH) until I found this thread. The Alpine unit with the trim kit looks killer! I noticed that they mention it will not fit in cars with the JBL system. Is this true? Also, does the Alpine unit support video from iPhone/iPad apps like Netflix? The Pioneer unit does with the right cable. Thanks.
  12. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,994
    Fort Lee, NJ
    Great to see Prius getting better after-market support.
  13. Rebound
    Rebound Senior Member
    3,961
    2,609
    Portland, OR
    Sweet! Can you post a review of the Alpine, with any bugs or glitches you find?
  14. BlackSpade317
    Indianapolis, IN
    I have not been able to find any bugs or glitches just yet. I will if I end up finding any.
  15. 1ULV2H8
    1ULV2H8 Member
    66
    25
    Columbia, SC
    I may be wrong, but the bezel rrg posted looks different from the one black spade has. The top of the bezel black spade has seems to protrude out, while the one rrg posted seems to recess in. So I'm wondering if they are 2 different styles. Anyone else see this?
  16. ucsmfu
    ucsmfu Senior Member
    1,498
    420
    canada
    which adapters did you use ?
  17. 3264884
    New York
    I have the same setup. Alpine has the Perfect Kit KTX-PRS8-S that makes the install plug and play. It includes the wiring harnesses and the steering wheel adapter module. If I recall, there are only three wires that have to be connected to the car (Emergency Brake, Brake and Vehicle Speed Sensor). All other connections are through the wiring harness, which is plug and play.
    The top of the bezel protrudes outward and the image rrg posted is the same, but the lighting/shadow makes it look like it is recessed.
  18. Danger
    Danger Member
    175
    22
    Frisco
    They should make 7" ones also.
  19. nelsc
    nelsc New Member
    For those that have installed the Alpine INA-Z928HD are you still happy with it, any issues? Also what features did you give up by removing the factory HU, I programmed like my door locks to work like I wanted and so forth, did yours default to what you had set or is there a different way to do this?
  20. Blu-ray
    Blu-ray Blizzard Brigade #215
    471
    198
    TampaBay, FL
    No XM?
    Does the system show the car consumption and stuff on the screen?
