2011 Prius blows headlamps way too often, not HID
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by TroyMclure, Mar 30, 2015.
  1. TroyMclure
    TroyMclure New Member
    U.S.A
    Hello, 2011 Prius has about 85K miles on it, and we have gone through about 8 pairs of running headlamp bulbs. I called the dealership and they said that there is no known issue for this. Sure seems like a voltage regulator-type issue. Is it possible that a single wiring harness can affect both left and right? It's strange, because if the left one blows today, the right one will blow within a day or two. I've tried every brand of bulb, and no, I do not touch the glass with my hands. Any ideas before I throw my car to the mercy of the dealership? Thanks!
  2. Cozynest
    Cozynest Junior Member
    St. Louis
    No ideas, but I can empathize. Last week both of my headlights went out at the same time. I've had the car for exactly 2 years and 20k miles and so far I've replaced both bulbs twice. Not necessarily a huge problem, but the Prius is already competing with the total number of headlight bulbs I've had to change in 25 years. I searched this site to see if it might be a common problem, and it looks like maybe just a few people have similar complaints. Just make sure to document everything. At least you'll know what you're talking about if you have to make that complaint to the dealer.
  3. rjparker
    rjparker Tu Humilde Sirviente
    7,570
    4,438
    Texas Hill Country
    Could be vibration and cheap bulbs. In reality most of the bulbs are made in China, probably by the same people. Try the autozone bulbs.
  4. ursle
    ursle Gas miser
    1,049
    192
    NH
    Are you the original owner, if not was there ever a fender bender that damaged the wiring harness?
    Lots of gen2's had hid problems, this is the first gen3 headlight problem to surface.
    Err, mice?
  5. rjparker
    7,570
    4,438
    Texas Hill Country
    It's difficult for me to understand how wiring would blow out bulbs. If anything, bad wiring might add resistance to the circuit which is only 12v and reduce amps dimming the bulbs. Arcing at the bulb contacts might be a problem but that would be clearly evident, both in operation (flickering) and at replacement (blackened areas). Even vibration is questionable for these kinds of bulbs. I would wear disposable nitrate gloves when changing them and ensure there is no moisture in the housing.
    #5 rjparker, Mar 30, 2015
  6. alekska
    alekska Active Member
    435
    138
    Atl
    I think there was a TSB on defective headlight wiring in Prius, which causes bulbs to burn often. It was mentioned here at Priuschat. Your dealer is probably unaware of this TSB. Look for a better dealer?
    In any case the bulbs would burn out fast when there is either too high or too low voltage on them. For a proper long life of halogen-filled bulb the temperature inside should be high enough to allow for halogen cycle to restore the filament material. Low voltage would cause temperatire to be low. The voltage too high is unlikely in Prius as there is no alternator+regulator. 12V is made inside inventor and is well-controlled by electronics. Defective wiring or relay can cause voltage at bulb to be too low. Another thing to look at is a plug that connects into the bulb.... if it has bad contact it would overheat and melt, but that is probably not your case.
    - Alex
  7. TroyMclure
    U.S.A
    Thanks everyone - Yep, I'm the original owner, and no accidents or fender benders besides my daughter scraping the front on curbs. At first I thought it was bad luck. Then, I thought it was because I subbed cheap bulbs. Then, I started trying every brand out there. One thing that makes me think it's irregular voltage, is one of the times they blew, my wife ran the car without the headlights on for a while. Then, when she turned them on, one blew. Kind of like it can't handle initial voltage. Or is this just crazy?
  8. alekska
    435
    138
    Atl
    The instant the bulb is turned on is usually the time they burn. At this moment the resistance of the metal filament is the lowest that causes the highest current. As filament heats up, the resistance increases and current decreases
    - Alex
  9. rjparker
    7,570
    4,438
    Texas Hill Country
    You could check the voltage from inside the car with a lighter plug hooked up to a voltmeter and watch the voltage as someone else drives with the headlights on (they are a high load). It will probably start out at 14.8 vdc and go down to 13.5 vdc. You would need voltage pretty high (let's say 18vdc or more to blow out the bulbs), which I serious believe would cause damage to other bulbs and parts. You can also watch voltage on the MFD but it may not be as realtime. The voltage anywhere in the car will read the same in an overvoltage condition. Also watch for flickering or changing intensity of the headlights at night.
  10. alekska
    435
    138
    Atl
    The problem is most likely the voltage AT THE BULB, not at the cigarette lighter. They will always will be different as The wiring path is different for those two.
    - Alex
  11. mrbigh
    3,686
    699
    Long Island, NY
    I have the same problem with my wife's 2011, it blows.....
  12. CR94
    CR94 Senior Member
    2,642
    1,134
    Northwestern S.C.
    Are you leaving the headlight switch turned on when you park, letting them go off and on automatically?
  13. mrbigh
    3,686
    699
    Long Island, NY
    My wife does, she likes that feature, tho
    #13 mrbigh, Mar 31, 2015
  14. TroyMclure
    U.S.A
    Yep, we leave ours on, to run automatically.
  15. Mike500
    Mike500 Senior Member
    2,593
    763
    The OP lists no location in his or her profile. If he or she lives and drives the car in a seal coastal area or one where they heavily salt the roads in the winter, I'd suspect corroded or loose connections.
    Also, a cracked housing or bad seal in the headlight housing may allow water vapor to intrude, corrode the connections or even affect the surface of the bulb.
  16. mrbigh
    3,686
    699
    Long Island, NY
    In the last 10 years that I owned Prii, I never had a corroded lamp contact; maybe tarnished.......
  17. Mike500
    2,593
    763
    One, two or even three units do NOT count as a "representative sample" in statistics.
    As for the OP, I would connect an ohmmeter through the fuse block to check the headlamp circuit for a "phantom" drain or a short.
  18. TroyMclure
    U.S.A
    I'm in Minnesota, however this problem has been there basically since we bought the car so I don't think conditions would be much of a factor. It must be something originally wrong with the vehicle.
  19. CR94
    CR94 Senior Member
    2,642
    1,134
    Northwestern S.C.
    There have been numerous other threads on this topic. Some members have theorized that leaving headlights on like that subjects them to damaging voltage spikes. I'm not sure whether that's true, but why take the chance?
  20. Okinawa
    Okinawa Senior Member
    1,333
    317
    I had a 2011 Prius Two for three years. I put 48,000 miles on it and never replaced a headlight bulb.
