2012 Bluetooth Pairing Issue
Discussion in 'Gen 3 Prius Audio and Electronics' started by DRB4381, Dec 16, 2012.
  1. DRB4381
    DRB4381 Junior Member
    I have a 2012 Prius Two and having issue with trying to pair bluetooth devices. When I go to the add new screen, I get the Registration Waiting, but the little searching symbol in the upper right corner is not rotating and nothing will pair. It seems like it's really not searching since the symbol is not rotating. Is there a way to reset the head unit? Anyone else had such issue? Thanks
  2. MBRGuru
    MBRGuru Member
    255
    26
    Can you see the device from your phone when it's on this screen? Does the icon freeze up when you select the device to pair, or as soon as the screen shows up? What type of phone do you have?
  3. DRB4381
    Thanks for the tip. The iphone 5 was seeing the device but would not pair to it, so I first deleting the device from my phone, then starting from scratch to re-pair it and that worked.
