2012 Gen 3. Fuse Panel Diagram Incorrect - Low Beam HL Fuses??
Discussion in 'Gen 3 Prius Audio and Electronics' started by jc60752, Nov 3, 2016.
  1. jc60752
    jc60752 New Member
    New Braunfels, TX
    In the image, the green dots on the right show the slots that should contain fuses but do not, as indicated by the diagram on the left.
    Is there a corrected version? Does anyone know where the H-LP-LH LO fuse is???
  2. Rebound
    Rebound Senior Member
    3,961
    2,609
    Portland, OR
    There are different trim levels of Prius. The unused fuse locations could be for models with auto leveling headlights, LED headlights, Hid lights, or the dynamic cruise control, power seats, seat heaters, or any or several other options your car doesn't have.
  3. ChapmanF
    15,067
    I had been meaning to mention the same thing, and Rebound beat me to it. Overall, I find the legends printed in the fuse box covers to be pretty much as accurate as the ones in your grandfather's fusebox at home ... whatever is written next to one fuse is probably at least related to one thing that's fed on that circuit, but there can be other things you wouldn't think of, look in the wiring diagram and it's full of surprises, and some of them depend on the trim levels and options.
    If you look at this post here, it's about somebody else's different question, but it shows the way Toyota marks up optional wiring alternatives in the wiring diagram. Look at the way they have numbered notes *1, *2, *3, and so on, and then some wires in the diagram are shown going one place with a *1 or some other place with a *2, so you look in the notes to see which number matches your options, and then you look for the bits matching that in the diagram.
    -Chap
    Robert Holt and Rebound like this.
  4. Robert Holt
    Robert Holt Senior Member
    1,313
    888
    Can those "spare" fuse openings in that fuse block have a fuse inserted and then be used to power a new circuit? Say, for example, a new fuse to power a new set of LED DRLs installed up front with a fuse-protected power supply?
  5. ChapmanF
    15,067
    When you look up that box in the wiring diagram, one of the pages you'll find is "internal connections" which, just as it sounds, shows you how all of those slots are connected internally, which will show you where the open slots get their power from, where the downstream connection comes out, etc.
    -Chap
    Robert Holt likes this.
  6. Robert Holt
    1,313
    888
    Thank you, Chap!
    Although I must say this wiring diagram is at least one order of magnitude more complicated than the 1963 Plymouth Valiant that I rewired long ago!
    Wow, need to pick an extra slot where an extra 2 or 3 amp draw will not overload things. Time for homework.
  7. RRxing
    RRxing Senior Member
    2,518
    1,790
    NEPA
    From the 2010 fuse layout:
    Top left dot is for the headlight cleaner (washer).
    Bottom left dot shows "No Circuit."
    The "S-Horn" fuse on the attached shows it as fuse #4 "No Circuit", but in a different location than your photo. Your photo also shows it as a larger fuse. May also be "No Circuit" for you as well.
    The 40A P/I 2 fuse (near bottom center) is for low beams (H-LP-LH LO)
    See attached (for 2010)
    #7 RRxing, Nov 7, 2016
  8. Robert Holt
    1,313
    888
    Thanks for that PDF!
    Am I correct that one simple approach to powering additional LED DRLs,on my Prius would be the following:
    As we do not have heated seats , could I simply tap into the fuse position 4 and 5 of the left side instrument panel fuse box using 5 amp fuses (maximum draw should be 1-2 Amps.)?
    Or could those fuse positions be used for something completely different on a 2012 trim level 3 hatchback?
  9. ChapmanF
    15,067
    No doubt! :)
    On the other hand, I bet that Valiant wiring diagram was all on sheets of paper you'd have to follow around with your finger, and dog-ear the corners or stick pencils and wrenches in to hold your place. The interactive way you can just click around the online Toyota diagrams can make life really easy once you get the hang of it. This post (though it's about somebody else's question) should give the idea.
    I would definitely check the diagram for your model year, and pay attention to the *1, *2, ... option markings, to be sure you're making the right conclusions for your car.
    -Chap
  10. Robert Holt
    1,313
    888
    The temptation to simply bull through to a solution without doing my homework is quite strong.
    I will try to resist that temptation as such a course of action can, of course, have disastrous consequences .
    Thank you, Chap!
    gggGary likes this.
  11. Rebound
    3,961
    2,609
    Portland, OR
    Basically, no. It's much less work to just use an in-line fuse holder for a new circuit than to remove the fuse box housing, install wiring underneath with a fuse holder, and wire it up. It may be that there are unused terminal screws attached to fuseholders, which could make it easier, but I'm not sure.
  12. xliderider
    xliderider Senior Member
    7,848
    3,102
    Honolulu, HI
    The Gen 3 has two open 1/4 inch terminals at the back of the engine fuse box that is constant +12v power. In this picture, it has two red wires going to them:
    Robert Holt and kc410 like this.
  13. Robert Holt
    1,313
    888
    Thank you. That could be useful for this install! Need to get slightly smaller light assemblies to fit the tow hook openings as the 2"x2" metal housings are about 1/8" too large unless I start cutting out the slots, which I would prefer to not do.
  14. Rebound
    3,961
    2,609
    Portland, OR
    Just to be clear -- those terminals aren't fused, and you should add an inline fuse holder with fuse if you use those power terminals.
  15. xliderider
    7,848
    3,102
    Honolulu, HI
    Fuse holder, and controlled by a relay. (y)
  16. saak
    saak Junior Member
    42
    Alberta, Canada
    My 2010 Gen3 Prius, rear defroster not working, could you please help me finding the fuse or relay, I dont see any in under the hood fuse box.
  17. xliderider
    7,848
    3,102
    Honolulu, HI
    There's a fuse panel under the driver's side of the dashboard, next to the kick panel as well. The fuse locations are listed on the inside of the cover.
    Rebound likes this.
  18. MH1
    MH1 Junior Member
    oakland
    2013 Prius Plug-in
    Hello there,
    I have a 2013 Prius Plug-in. HID headlamps installed (before me). One of the sides went out, so I purchased 2 new kits.
    Installed them but both sides didn't work. I then swapped out lamps, ballasts, wires, and then finally ended up installing all the old components but was never able to get the original working lamp back to working.
    I figured it was a fuse issue, opened the fuse box, and the 2 fuses and 1 relay labeled for the low beams are "missing", similar to the picture in the #1 post by jc60752.
    Are the fuses not needed for HID installation?
    I'm trying to troubleshoot what I can on my side before returning the kits back for a replacement.
    Thanks!
    gggGary likes this.
