1. Offline
    has been buy local, support your community
    Start a Conversation
    Apr 18, 2012
    250
    42
    pacific n'west
    Your Vehicle Year:
    At the first oil drain would like to replace oil pan drain plug with one that has a magnetic tip on it.
    Does anyone know the thread pitch, length, and such for this part?
  2. Offline
    xliderider Active Member
    Apr 19, 2012
    853
    149
    Honolulu
    Your Vehicle Year:
    Just stick a neodymium magnet on the OEM one?
  3. Offline
    Mike500 Interessen-Gemeinschaft Prius
    Mar 1, 2012
    952
    222
    Upstate, SC
    Your Vehicle Year:
    M12x1.25
    I've actually made my own by drilling out the cemter on a lathe with a 1/8 inch drill bit and locking in a 1/8x1/2 Neodymium magnet with green sleeve locking Loctite.
  4. Offline
    Apr 19, 2012
    853
    149
    Honolulu
    Your Vehicle Year:
    Hmm, another product from Mike500? ;)
  5. Offline
    Apr 18, 2012
    250
    42
    pacific n'west
    Your Vehicle Year:
    My logic tree dictates that I have one ready for my first oil change.
    Attaching a mag to an OEM plug or M12/1.25 bolt is a good idea and was going to do that.
    By the time I get a neo-mag and bolt together I could probly play some golf, do some work in the backyard....
    And I'll forget to get THAT ball rolling.
    So I ordered one.
    $18+ inc shipping.
    They use 5000 gauss neo's I think.
    It'll be on my porch probly around the same time as the oil change is ready.
    It's brilliant really.
    your efforts are appreciated - thank you
  6. Offline
    ny_rob Active Member
    Feb 28, 2012
    924
    273
    L.I.- NY
    Your Vehicle Year:
  7. Offline
    Mar 1, 2012
    952
    222
    Upstate, SC
    Your Vehicle Year:
    Even better;
    TOYOTA LEXUS NISSAN INFINITI OIL DRAIN PLUG MAGNETIC | eBay
    I like aluminum with a copper washer.
    The Toyota service dealer overtightening it would more likely strip the softer aluminum threads than the "steel" threads of the nut welded to the inside of the oil pam.
    $7.50 delivered is a great deal.
  8. Offline
    Apr 18, 2012
    250
    42
    pacific n'west
    Your Vehicle Year:
    That's a good price.
    Looks like a well made piece.
    Not so sure of the aluminum theory though.
    But I s'pose you could always drop the pan and clean out any offending members.
  9. Offline
    Apr 19, 2012
    853
    149
    Honolulu
    Your Vehicle Year:
  10. Offline
    Apr 18, 2012
    250
    42
    pacific n'west
    Your Vehicle Year:
    magplug.jpg Arrived today.
    Tried a pretty decent magnet from something else on a compass.
    From about one inch away it moved the needle.
    This magplug moved the needle from almost a foot away.
    Impressive.
    If there is any metal in the oil...guess where it's gonna end up.
  11. Offline
    Apr 19, 2012
    853
    149
    Honolulu
    Your Vehicle Year:
  12. Offline
    Apr 18, 2012
    250
    42
    pacific n'west
    Your Vehicle Year:
    Bolt is steel (preferred).
    The magnet is triple Gold plated for strength and durability.
    Made in USA.
    $18 inc shipping
    ordered it 4 days ago
  13. Offline
    Apr 18, 2012
    250
    42
    pacific n'west
    Your Vehicle Year:
    Not sure I would like the entire bolt magnetized.
    If so, debris would collect on plug threads and could be a remove/install problem with pan threads.
    It would also have a good chance of leaving debris in pan as it 'wiped' off threads as you removed bolt.
    This one is steel but the threads and head of bolt show very low mag properties.
    The washer isolates in a sense, compresses to seal ,and is non'mag, probably aluminum.
  14. Offline
    Mar 1, 2012
    952
    222
    Upstate, SC
    Your Vehicle Year:
    Anyone interested in the Genune Toyota OEM oil drain plug bored out on a lathe to take a 1/4 dia x 1/2 N48 neodymium magnet with a lift capacity of 8.63 pounds and fitted in with 640 permanent Loctite? That's the type used to retain cylinder sleeves in engine blocks.
    These are NOT cheap to make and would be the best availble. It will use the Genuine Toyota steel oil drain plug, which sells for nearly $5 retail. The magnets are about $3.50 each. I will include a genuine Totoya OEM washer gasket.
    The delivered price would be $20. I will need at least 15 buyers to make this cost effective.
    Please let me know.
    Mike500
  15. Offline
    Apr 18, 2012
    250
    42
    pacific n'west
    Your Vehicle Year:
    Of course they would be the best available.
    Nobody would dare to question that.
    Might get another as spare if you use 650 Loctite and it could pick 9 pounds.
  16. Offline
    Mar 1, 2012
    952
    222
    Upstate, SC
    Your Vehicle Year:
    I'm proposing making these for ablut cost, mainly because of the "economy of numbers" and that the cost of my time and labor is not that important to me, becuase I am making it for my own use.
    I'm just disappointed in the quality of the stuff available out there. They are all made in China or Taiwan. They might work, but they are definitely NOT the best.
    After inquiring one of the sealing washers, I am surprised on how much engineering Toyota spent on making it. It appears to have been made of soft malleable aluminum with a sealing polymer compound bonded to each side.
  17. Offline
    Apr 18, 2012
    250
    42
    pacific n'west
    Your Vehicle Year:
    goldplug.com
    part # AP-03 (2012 Prius)
    A quality product from Bozeman, Montana, USA
  18. Offline
    rrg Member
    May 18, 2010
    335
    78
    East coast - NJ
    Your Vehicle Year:
    Anyone have the 5k to 10K oil change on a magnet drain plug?
    I added a magnet plug and the collection of material from the oil is barely noticeable.
  19. Offline
    David Beale Senior Member
    Jul 24, 2006
    3,765
    454
    Edmonton Alberta
    Your Vehicle Year:
    The magnet won't attract bits of aluminum. It's an aluminum block and head. Also won't attract sand, such as casting sand.
    Nice idea, worked well in "lump motors" (cast iron blocks), but probably not very useful in a modern engine.
    Now, if you could put one on the HSD -that- might be useful!
  20. Offline
    Mar 1, 2012
    952
    222
    Upstate, SC
    Your Vehicle Year:
    Think so!
    The cylinder liners are still iron and, as well, the rings are, too.
Share This Page
