1. Offline
    exbauer Active Member
    Start a Conversation
    Aug 16, 2006
    1,054
    62
    Your Vehicle Year:
    Those of you with 2012 Prius Five with LED headlights does your beam pattern shake, vibrate, or dance when you drive over rough pavement? Like when you drive over cracks, potholes, rough pavement? I don't remember this in my 2010. I just find it annoying and wanted to make sure it just wasn't mine.
  2. Offline
    • Moderator
    Sep 22, 2005
    6,985
    1,744
    N.Y.
    Your Vehicle Year:
    Can't say I ever noticed this. I also had a 2010 and never noticed it before as well. I'll look again during some night driving and see if it is that visible.
  3. Offline
    ny_rob Active Member
    Feb 28, 2012
    924
    274
    L.I.- NY
    Your Vehicle Year:
    I haven't noticed this behavior on my Five. I haven't specifically looked for it- but I'm usually good at noticing rattles/vibrations, etc... and I'm sure I would have noticed an annoying trait like that.
  4. Offline
    mad-dog-one Prius Enthusiast
    Dec 31, 2009
    1,113
    313
    Loma Linda, CA
    Your Vehicle Year:
    We have two 2010 V's and have not noticed headlight shaking.
  5. Offline
    Aug 16, 2006
    1,054
    62
    Your Vehicle Year:
    I notice it and it's rather annoying to watch the beam bounce. This is only when I am driving close to the car in front where I can really see the cutoff. Otherwise if I'm just driving on the road and nothing in front of me nothing since I can't see the cutoff.
  6. Online
    Jonny Zero Giggidy
    Jun 22, 2012
    862
    166
    Austin, TX
    Your Vehicle Year:
    Nope. I drive through 6 miles of unlid, pot hole filled, two lane country road to get home everynight and have not noticed it. I usually do not use the high beam either.
    I wonder if there is something wrong with your auto level mechanism. Do you have a warning light on your dashboard that looks like a lowbeam symbol + up down arrows?
  7. Offline
    Aug 16, 2006
    1,054
    62
    Your Vehicle Year:
    I have seen the auto level work. It moves up or down depending on the load when I turn on the headlights. I only see it when I can get a good view of the cutoff on the car in front of me and I happen to drive over a crack or rough pavement.
  8. Offline
    yeldogt Member
    Jan 20, 2012
    330
    25
    NE
    Your Vehicle Year:
    The auto leveling works when you first turn on the car to adjust for the weight in the car -- it should then lock. If yours is bouncing then something is wrong.
  9. Offline
    Aug 16, 2006
    1,054
    62
    Your Vehicle Year:
    I went to the Toyota dealer tonight to test drive another Five. It did the same thing. Its slight and you have to really look for it. Eh, I won't worry about it too much now since the one I drove did the same thing.
  10. Offline
    BearInStPete Junior Member
    Apr 30, 2012
    St Petersburg
    Your Vehicle Year:
    I'll throw in a couple of pennies worth, on our new (as of 7/11) model 5 I seemed to notice a slight vibration in the beam, but I think it is more noticeable due to the sharp demarcation of the top edge of the beam pattern with these headlights. Similar vibration and shake may be present with the halogen system, but I suspect it is more difficult to notice?
Share This Page
