2012 Prius Plug-In Window Sticker
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Tracksyde, Feb 28, 2012.
  1. Tracksyde
    Tracksyde Member
    1,380
    670
    So Cal
    Here it is
    7 people like this.
  2. Jeff N
    Jeff N The answer is 0042
    2,268
    1,178
    California, USA
    2011 Chevy Volt
    Thanks, but I can't read the fine print. Gotta be able to read the footnotes etc. which is where the information is that we haven't learned about yet such as how many kWh to charge the battery and maybe how much gas was blended in as part of the 11 mile range or 95 MPGe estimate.
    Is there is separate city and highway MPGe in addition to the 95 MPGe combined estimate?
    You might need to take more than one close up of the window sticker in order to capture all the details.
  3. Tracksyde
    Tracksyde Member
    1,380
    670
    So Cal
    Finishing up with the finance guy. If I don't get escorted off the property first, I'll go back and take some more pictures :)
  4. DianneWhitmire
    DianneWhitmire High PRIUStess
    3,780
    925
    64
    Laguna Niguel, CA
    LOL! Take as many pictures as you/they want, hon! We appreciate it!
    3 people like this.
  5. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,915
    Fort Lee, NJ
    The breakdown of the 95 MPGe is:
    0.2 Gallons / 100 miles
    29 kWh / 100 miles
    Blended range is 11 miles. AER seems to say 5 or 6 miles. It could be 0 mile also. :|
    Dianne, can you confirm what's the All Electric Range?
  6. Paradox
    29,026
    8,522
    201
    2014 Prius v wagon
    AER seems like 6 miles to me USBs... Edit, haha you said 5 before posting this but I'm pretty sure it says 6.
  7. Tracksyde
    Tracksyde Member
    1,380
    670
    So Cal
    The picture on my phone is bigger and clearer. I'm 95% sure it says 6 miles AER. But I'll go out and check in a bit.
  8. surfinjoe
    surfinjoe Junior Member
    48
    17
    san clemente
    Tracksyde, congrats on your new PIP!
  9. usbseawolf2000
    14,487
    2,915
    Fort Lee, NJ
    Yea, the first screenshot looked like 5. Second one looks like 6.
    Annual fuel cost of $1,000 is exactly the same as 2012 Volt. Fuel Economy and GHG Rating is the same at 10. Smog Rating is 7 (one better than Volt).
    Midsize Prius PHV does better than the compact Volt.
  10. Tracksyde
    Tracksyde Member
    1,380
    670
    So Cal
    Better?
    11 people like this.
  11. gwmort
    gwmort Active Member
    985
    211
    Delaware
    Thanks, let us know what you find out.
    Congratulations on your new car!
  12. Jeff N
    2,268
    1,178
    California, USA
    2011 Chevy Volt
    Do we know what AER means for a blended PHEV, according to EPA?
    I'm not sure how to interpret that.
  13. usbseawolf2000
    14,487
    2,915
    Fort Lee, NJ
    Determine the vehicle's Actual Charge-Depleting Range, Rcda. Determine separate range values for FTP-based city and HFET-based highway driving, then calculate a combined value by arithmetically averaging the two values, weighted 0.55 and 0.45 respectively, and rounding to the nearest whole number. Precondition the vehicle as needed to minimize engine operation for consuming stored fuel vapors in evaporative canisters; for example, you may purge the evaporative canister or time a refueling event to avoid engine starting related to purging the canister. For vehicles that use combined power from the battery and the engine before the battery is fully discharged, also use this procedure to establish an all electric range by determining the distance the vehicle drives before the engine starts, rounded to the nearest mile. You may represent this as a range of values. We may approve adjustments to these procedures if they are necessary to properly characterize a vehicle's all electric range.​
    Source
    Say, Prius PHV completed the entire 11 miles City cycle in EV mode and 0 mile in highway.
    (11 miles x 0.55) + (0 miles x 0.45) = 6 miles.
    I don't know for sure. That's how I would interpret it with numbers made up to match.
  14. drinnovation
    drinnovation EREV for EVER!
    2,027
    586
    65
    CO
  15. rogerv
    rogerv Senior Member
    1,632
    306
    Simi Valley, California
    Tracksyde,
    Congratulations on your new car! You may be the very first to take delivery in the nation. I would have thought the new car get-ready would take at least a day, but here you are getting yours practically off the truck. So, which trim and what color do you have? (Color me envious!)
  16. Tracksyde
    Tracksyde Member
    1,380
    670
    So Cal
    I got the Base/Standard/Basic (not sure what its officially called) model in Winter Gray Metallic. When I got to Carson Toyota, my car was actually in the service area up on a lift getting its dealer inspection done, I think.
    I may be the first to take delivery, but its actually still at Carson Toyota since I decided to get the aftermarket leather done. So I wont have any first-hand impressions until I pick it up "for real" (hopefully tomorrow or Thursday).
    When I bought my last car, I thought that was quick. In and out of the dealer in 90 minutes. Today, I drove to see Dianne (25 minutes on the freeway from work) at lunch and was done in about 60 minutes. Thanks, Dianne!
  17. stream
    stream Senior Member
    2,977
    445
    Long Island, NY
    Congrats--enjoy.
  18. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,285
    447
    Maine
    It's possible (from some reading about the SAE Jwotsit) that they're allowed to back-calculate range from electricity required to recharge after the cycle.
    Aa=.55Ca + .45Ha
    Aa rounded to nearer whole number.
    ~3kWh usable
    Ca = (Aa-.45Ha)/.55
    Ce ~= 3/Ca
    Column 1 Column 2 Column 3 Column 4
    0 Aa\Ha
    0​
    1​
    2​
    4 5.5 0.300 0.327 0.359
    5 6.0 0.275 0.297 0.324
    6 6.5 0.254 0.273 0.295
  19. Paradox
    29,026
    8,522
    201
    2014 Prius v wagon
    Enjoy your new car!!!
  20. DianneWhitmire
    3,780
    925
    64
    Laguna Niguel, CA
    Hiya A!! A pleasure to meet you finally. Your car's going to be ready in a day ... how exciting!! I promise to get everyone in and out PDQ! But, you need to leave some time for the delivery process... we don't want you to get the car home and not know the important basics!!
    2 people like this.
