2013 v JBL radio issues
Discussion in 'Prius v Main Forum' started by abra, Sep 16, 2014.
  1. abra
    abra Member
    197
    Austin, Tx
    Three Touring
    How do I get the JBL radio to stop changing sources when using the channel up/down on steering wheel?
    It goes from FM1 to Sat
  2. Tideland Prius
    16,059
    Maybe take it into the dealer? Looks like some wiring got crossed. It shouldn't do that - MODE should be the button that changes source.
  3. abra
    abra Member
    197
    Austin, Tx
    Three Touring
    MODE does its job just fine too.
  4. Chazz8
    Chazz8 Gadget Lover
    744
    234
    61
    Central New York
    The up/down button on the steering wheel goes up and down on the preset station list that you input. So if you have a SAT/XM channel next to an AM channel next to a FM channel then the up-and-down button will scroll through three sources (XM AM & FM) as you button through those three stations in your preset list.
    You can minimize the source skipping by keeping each sources presets next to each other in your preset list, i.e. all FM presets then all SAT presets, then any AM presets.
    Hope this helps.
    sleeper760 likes this.
  5. abra
    abra Member
    197
    Austin, Tx
    Three Touring
    The older radio (my past 3 JBL priis).
    If I was on FM on preset 6 and I pushed up it went to 1, 2, 3, 4, 5.
    Not 4, 5, 6, SAT 1.
    This makes zereo since.
  6. Chazz8
    Chazz8 Gadget Lover
    744
    234
    61
    Central New York
    My presets (adv. Tech. Pkg.) can have XM 122 on preset 1, and FM 89.9 on preset 2. Then the source changes when you scroll via steering wheel buttons from preset 1 to 2. It is up to you to keep them on separate or same preset bank of 6 presets. I get 6 banks of 6 presets for a total of 36 presets to play with.
    Oh I see what you are saying. You are saying it should only scroll through one bank of presets rolling around from 1 to 6 on the same bank. I just went out and checked and it rolls from the sixth preset to the next bank preset one. I guess the workaround is to know when you are on preset 6 and press back 5 times to get to preset 1 of the same bank.
  7. rdgrimes
    rdgrimes Senior Member
    1,740
    444
    New Mexico, USA
    2018 Prius Prime
    Radical idea: Reach over and select the station you want on the screen. ;)
