2015 Prius Two, no II - heat question
Discussion in 'Gen 3 Prius Main Forum' started by kdyj15, Nov 30, 2015.
  1. kdyj15
    kdyj15 Junior Member
    Hi: I live in DE and recently the weather is getting cold. In the morning time it is around 40 degree, my AC set to 70 degree, and set to AUTO, but when I start the engine, the heat/fan is not start right away, and I need to drive at least 5-6 minutes to wait the fan go up to the max. So my question is that during the first 5-6 minutes I do not have any fan/heat at all, so does anyone has same issue? or what is the setting you have in your car.
    Please share your information.
    Kevin
  2. john1701a
    john1701a Prius Guru
    12,748
    5,243
    57
    Just like with any other engine powered vehicle, heat is provided by warmth from the engine. The same coolant used to cool the engine is what supplies warmth to the heater-core. In other words, it's an exchange that takes a few minutes to accomplish... since you first have to wait for the engine to warm up.
  3. BZzap!
    BZzap! Senior Member
    1,607
    877
    The system is smart enough to know not to blow ice cold air in your face. When the engine temperature comes up then the system serves out the air you requested
  4. fuzzy1
    10,039
    I don't have any problem putting my defroster fan on immediately, but then my AC is turned off, and I don't use Auto mode. Plus, if the windshield is fogged or frosty, I switch on the front defroster.
    No, also I don't get much heat for a few miles. But at least I do get dehumidified airflow to clear the windows.
  5. bisco
    48,945
    you can shut off the 'auto', turn the temp and fan to high, but you won't get heat until the engine can produce it. takes a couple miles around these parts.
    if you want heat sooner, get a remote starter, or a block heater.
  6. BZzap!
    1,607
    877
    Solution ^^^
  7. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Yes, the fan won't run unless there is heat to blow. Normal. But you can defrost the windshield (A/C system removes moisture from the air it blows on the windshield).
  8. qdllc
    qdllc Senior Member
    1,358
    396
    +1 on remote start.
    My Prius is garage-kept, so this isn't an issue in the morning, but I didn't want to deal with a cold car when it's parked outside.
  9. bisco
    48,945
    i tested mine this morning out of curiosity, 39 degrees, turned the temp to high and fan to two bars. felt warmth at 2 miles, better at 3 and by 4 miles, it was nice and toasty.
  10. Montgomery
    Montgomery Senior Member
    2,254
    2,233
    Orange County, CA
    Yes to all above. This car is smart. Won't turn on due to the tempurature you set. It waits till the coolant will supply the necessary temperature to you and Violllaaa! It turns on after awhile. I love this Car!!
  11. TCW1184
    TCW1184 Junior Member
    I like this feature a lot. It's nice not having freezing cold air blown in my face
    iPad ?
  12. Mendel Leisk
    38,211
    Block heater will help with the warm-up time.
    "DE" is Deleware, USA?
  13. bisco
    48,945
