2015 Prius Plug In "Check Hybrid System"
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by TrinaF., Oct 10, 2014.
  1. TrinaF.
    TrinaF. Junior Member
    74
    23
    Southern California
    I have a new Prius Plug In, less than a week old. This morning I started the car and it told me the charge had been interrupted and that I didn't get a full charge. And then I get the "Check Hybrid System" light with the big old exclamation point. I drove it to work, which was 30 miles. It had charged enough I got about 6.5 miles on the EV.
    Should I just unplug the battery for a few seconds, or should I take it in to the dealer and have them look at it?
  2. -Rozi-
    -Rozi- Member
    134
    59
    Slovenia, E.U.
    2014 Prius Plug-in
    Welcome!
    Take your PiP back to the dealer. "Check Hybrid System" is not normal.
  3. TrinaF.
    74
    23
    Southern California
    Thank you, Rozi.
  4. TRUC NGUYEN
    TRUC NGUYEN Junior Member
    2014 Prius Plug-in
  5. TrinaF.
    74
    23
    Southern California
    I wondered if that might be the issue. I haven't been able to plug it in yet. I will report back after I plug it in.
  6. mrbigh
    3,686
    699
    Long Island, NY
    The power to your EVSE most likely that was interrupted some how, hence the warning sign in the vehicle
  7. rxlawdude
    rxlawdude Active Member
    701
    219
    So Calif
    2015 Tesla Model S
    That would be a "Charge Interrupted" message. She got a "Check Hybrid System" message.
  8. mrbigh
    3,686
    699
    Long Island, NY
    More likely cause by he interrupted charging...............
  9. -Rozi-
    -Rozi- Member
    134
    59
    Slovenia, E.U.
    2014 Prius Plug-in
    I get my charging interrupted every now and then for various reasons. However, never ever did I get "Check Hybrid System", neither the yellow triangle with exclamation mark. Only thing I ever got was "Charging interrupted" message when starting PiP. The message stays on screen for a couple of minutes and can be dismissed by DISP button. Exactly as rxlawdude explained.
  10. bisco
    48,945
    i get it when i unplug before it's finished. but i have never had the power go out when it was charging.
  11. -Rozi-
    -Rozi- Member
    134
    59
    Slovenia, E.U.
    2014 Prius Plug-in
    Actually, there are two kinds of "Charging interrupted" messages:
    1. If you unplug charger from PiP first, you get: "Charging interrupted due to charger operation".
    2. If you unplug from the wall first, you get: "Charging interrupted due to the power outage".
    Or something like that. I can't recall literaly, but notice the difference according to the unplug sequence.
    Never the less, "Check hybrid system" is not something owner of a PiP could reproduce by holding his left ear with his right hand while touching his nose, doing three spins standing on the left leg and spelling "Toyota" backwards. ;) It's a "take me to the dealer" kind of message.
  12. bisco
    48,945
    except in the link to another thread provided by truc in post #4.
  13. -Rozi-
    -Rozi- Member
    134
    59
    Slovenia, E.U.
    2014 Prius Plug-in
    Ups, missed that. :oops:
    retired4999 likes this.
  14. vvillovv
    vvillovv Senior Member
    3,529
    1,242
    NY
    I wouldn't recommend disconnecting the 12v battery in this situation for two reasons.
    It's a brand new car and if it's a lemon you want to find out as soon as possible. (I'm in NO way suggesting the car might be a lemon ) And the car will most likely fix itself, anyway :)
    If you disconnect the 12V battery you will loose any or all the freeze data stored when the incident happened, making it near impossible for anyone using
    tech stream or another diagnostics package to see the freeze data if there is any freeze data for the incident.
  15. bisco
    48,945
    you don't lose the diagnostic codes when the 12 volt is disconnected.
  16. GregP507
    GregP507 Senior Member
    3,002
    480
    I pulled out the plug too fast once, saw a white spark, got the same messages as you. They went away after awhile, and haven't appeared since.
  17. PImPinSD
    PImPinSD New Member
    2014 Prius Plug-in
    It's not normal to get the "Check Hybrid System" message. At the very least, even if I suspect there is nothing wrong, I would still take it in to the dealer and let them run a diagnostic. Ask them to quick charge your car and see if there is a problem.
  18. vvillovv
    3,529
    1,242
    NY
    That's a new one. How long has that been the case? And is it for all gen3 prius or just with the PiP?
  19. bisco
    48,945
    i just made it up, but i thought they were stored in non volatile memory on all pri.
  20. TRUC NGUYEN
    2014 Prius Plug-in
