2015 Solar roof - Options for racks?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by mikeyb1377, Aug 3, 2015.
  1. mikeyb1377
    mikeyb1377 Junior Member
    New York
    I've been looking at roof rack options for my 2015 Prius. I'm wondering if anyone out there has some experience with putting a rack on their roof for kayaks and such. Opening and closing the moonroof isn't a huge concern, on hot days I can just stick with the a/c if I can't open the roof with a rack on. :)
    Thanks!
  2. qdllc
    qdllc Senior Member
    1,358
    395
    Please clarify. Are you concerned with how a roof rack impacts the function of the solar panel, are you looking for a roof rack that doesn't affect the function of the solar panel, or are you asking for a roof rack that's compatible with the solar panel (fit) so it doesn't damage it?
    FWIW, I'd say ANY roof rack that doesn't totally block sunlight would have a negligible impact on solar collection function...as all the panel does is run a fan. :rolleyes:
    If there is stuff loaded on the roof rack that blocks a significant portion of the solar panel, obviously it will compromise function, but again, it only really matters when your car is parked.
    I DO NOT have a solar panel on my Prius, and I don't miss it. Unless you're going to park a long time in the south, I doubt you'll notice much of a loss of utility.
  3. mikeyb1377
    New York
    Thanks. Here's a bit more detail.
    I was looking at Yakima racks, because I have parts I can use for my kayak and mtn bike. On their site, they have an option for Prius 5dr, and Prius 5dr with solar. If I pick the solar option it has no roof options. So I wondered why that is and if anyone has other ideas or rack options.
    I'm not concerned with using the solar panel, or even the moonroof when the rack is on. I just want to make sure it doesn't cause any issue.
    Thanks again!
  4. qdllc
    qdllc Senior Member
    1,358
    395
    What has the manufacturer said? Did you e-mail them and ask?
  5. EGGS
    EGGS Member
    108
    NYC
    i own an solar roof . and couldn't live without it . the car is always a comfortable temperature no matter when i get in it .
    the problem with roof racks is the weight . the entire roof is glass and can crack . you can just install a hitch . i have a ecco hitch @in receiver . very stable bike rack and easy to install . my kayak is smaller so it fits inside . although i did look into the Foam blocks that strap on to the roof and they look like they would work .
    Torklift Central | 2010-2015 Toyota Prius & Prius Plugin EcoHitch
    Highland SportWing 4 Bike Rack for 2" Hitches - Aluminum Highland Hitch Bike Racks 1370400
    btw minimal impact on fuel economy with the bikes off the back . i see a slight loss at 3 bikes and 3 people in the car but that is expected . and i never use the 4th position . to much leverage / weight
  6. bino
    bino JDM ZVW30
    1,348
    705
    SoCal 91739
    I have the solar roof on my Gen 3 and I was able to put in the yakima rack..... just remember not to open the moonroof when the rack is on the car.....
    check out the pics here - After 1 year (JDM ZVW30 project).... | Page 25 | PriusChat
