2016 Prius Product Info
Discussion in 'Gen 4 Prius Main Forum' started by Danny, Nov 18, 2015.
  1. Danny
    Danny Admin/Founder
    7,093
    2,100
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    I'll work on cleaning this up soon, but here is the 2016 Preliminary Prius Product Information (pdf included at bottom).
    HYBRID POWER SYSTEM
    ENGINE 2ZR-FXE (Atkinson cycle)
    Type, Materials
    1.8-Liter 4-cylinder aluminum block and head, double overhead cam (DOHC) 16-valve VVT-i
    Valvetrain 4-valve/cylinder with VVT-i
    Displacement 1,797 cc
    Bore x Stroke 3.17 x 3.48 in.
    Expansion Ratio 13.0:1
    Horsepower (SAE Net) 95 horsepower @ 5,200 rpm
    Hybrid System Net Horsepower 121 horsepower
    Torque 105 lb-ft @ 3,600 rpm
    Recommended Fuel 87-octane unleaded
    Emission Certification SULEV (with AT-PZEV) Tier 2 Bin 3
    Estimated Fuel Economy* Prius Two Eco 58/53/56 (city/highway/combined MPG) Non-Eco grades 54/50/52
    MOTOR GENERATOR TWO
    Function Drives front wheels, regeneration during braking
    Type Permanent Magnet Synchronous Motor
    Max Voltage DC600V
    Electric Motor Power Output 71 hp/53 kW
    Torque 120 lb.-ft.
    HYBRID BATTERY PACKS
    Type Nickel-Metal Hydride Lithium-Ion
    Nominal Voltage DC201.6V (168 x 1.2V cells ) DC207.2V (56 cells)
    Capacity 6.5 ampere hour 3.6 ampere hour
    System Voltage 600 volts maximum 600 volts maximum
    * Toyota internal estimate. Actual mileage will vary.
    DRIVETRAIN
    Transmission Type Electronically Controlled Continuously Variable Transmission (ECVT)
    CHASSIS AND BODY
    Suspension - Front Independent MacPherson strut suspension with stabilizer bar - Rear Double wishbone with stabilizer bar
    Steering - Type Electric power-assisted rack-and-pinion
    - Turning circle diameter, 33.5 ft. (15-inch tires) 35.4 ft. (17-inch tires) curb to curb (ft.)
    Brakes - Front
    - Front Diameter - Rear
    - Rear Diameter - Parking
    Ventilated disc (hydraulic with power assist) with standard Anti- Lock Brake (ABS) system and integrated regenerative brake system
    10.0 in. rotor
    Solid disc (hydraulic with power assist) with standard Anti-lock Brake System (ABS)
    10.2 in. rotor Pedal brake
    Anti-lock Brake System (ABS) Standard
    Wheel Size 6.5J x 15 in.
    7J x 17 in. (available)
    Wheel Type and Material 5-spoke aluminum alloy
    Tire Size P195/65 R15
    P215/45 R17 (available)
    Tire Type All-season
    Spare Tire/Wheel Temporary on Two, Three; and Three Touring
    Tire Repair Kit on Two Eco, Four, and Four Touring
    EXTERIOR DIMENSIONS
    Overall Length 178.7 in.
    Overall Width 69.3 in.
    Overall Height 58.1 in. (with 15-inch and 17-inch tires)
    Wheelbase 106.3 in.
    Tread Width (Front/Rear) 60.2/60.6 in. (15-inch tires) 59.4/59.8 in. (17-inch tires)
    Front Overhang 37.4 in.
    Rear Overhang 35.0 in
    Ground Clearance 5.1 in.
    Coefficient of Drag 0.24
    INTERIOR DIMENSIONS
    Seating Capacity 5
    Headroom (Front/Rear) 39.4/37.4 in.
    Legroom (Front/Rear) 43.2/33.4 in.
    Shoulder Room (Front/Rear) 55.0/53.0 in.
    Hip Room (Front/Rear) 53.4/51.9 in.
    EPA Passenger Volume 93.1 cu. ft.
    EPA Cargo Volume 27.4 cu. ft. (Prius Two Eco, Four, Four Touring) 24.6 cu. ft. (Prius Two, Three, Three Touring)
    WEIGHTS AND CAPACITIES
    Curb Weight 3,075 lbs.(Prius Two) 3,010 lbs. (Two Eco)
    3,050 lbs. (Three, Four)
    3,080 lbs. (Three Touring and Four Touring)
    Fuel Capacity 11.3 gal.
    STANDARD EXTERIOR FEATURES
    Prius Two
    •  Bi-LED projector low and high-beam headlights with LED accent lights and auto off feature
    •  LED Daytime Running Lights (DRL) with on/off feature
    •  LED tail lights and stop lights
    •  Heated power outside mirrors with folding feature
    •  Color-keyed outside door handles
    •  15-in. 5-spoke alloy wheels with full wheel covers and P195/65R15 tires
    •  Intermittent rear window wiper (on all Prius grades excluding Prius Two Eco)
    •  Washer-linked variable intermittent windshield wipers
    •  Active grille shutters
    •  Color-keyed roof-mounted shark-fin antenna
      Prius Two Eco and Prius Three (In addition to or in place of Prius Two standard features)
      •  Bi-LED projector low and high-beam headlights with LED accent lights and auto-on/off feature
      •  15-inch 5-spoke alloy wheels with two-tone wheel covers and P195/65R15 tires
        Prius Four (in addition to or in place of Prius Three standard features)
     Rain-sensing variable intermittent windshield wipers (also standard on Four Touring grade)
    Prius Three and Four Touring (In addition to or in place of Prius Four standard Features
    •  Integrated fog lights and accessory lights
    •  LED clearance lamps
    •  17-in. 5-spoke alloy wheels with P215/45R17 tires
     Touring grade unique rear bumper treatment
    STANDARD INTERIOR FEATURES
    Prius Two
    •  Smart-flow climate control system with pollen filtration
    •  Integrated backup camera
    •  4.2-inch Color Dual Multi-Information Display with customizable screens including Energy Monitor, Hybrid System Indicator and Eco Score, Eco Savings Record, Drive Monitor, Eco Wallet, Eco Diary, Climate Control, Driver support systems, audio system content, and navigation system content
    •  Fabric-trimmed front seats with seatback pockets; 6-way adjustable driver’s seat; 4-way adjustable front passenger seat
    •  60/40 split fold-down rear seats with center armrest
    •  Cruise control
    •  Tilt/telescopic steering wheel with audio, Multi-Information Display and Bluetooth® hands-free phone controls
    •  Upper door trim with chrome accent, soft-touch door armrest area with chrome accent interior door handles
    •  Digital instrumentation with speedometer, fuel gauge, odometer, current and average fuel economy, distancetoempty,shift-position indicatorandEV/ECO/POWERModeindicators
    •  Smart Key System on driver’s door with Push Button Start
    •  Power windows with driver and passenger auto up/down
    •  Power door locks
    •  Dual sun visors with illuminated vanity mirrors
    •  Center console with armrest and storage compartment
    •  Cargo area lightweight tonneau cover
    •  Two 12V auxiliary power outlets (1 front, 1 rear)
    •  Rear dome light and cargo area light
    •  Two front and two rear cupholders; two front bottle holders
      Prius Two Eco (In addition to or in place of Prius Two standard features)
     Smart Key System on three doors with Push Button Start and remote illuminated entry Prius Three (In addition to or in place of Prius Two Eco standard features)
    •  SofTex®-trimmed tilt/telescopic steering wheel with audio, Multi-Information Display, and Bluetooth® hands free phone controls
    •  Soft-touch upper door trim with chrome accent, SofTex-trimmed door armrest area with chrome accent interior door handles
    •  White accent on steering wheel, shifter, and center console
    •  Qi-compatible wireless smartphone charging with charge indicator light
    STANDARD INTERIOR FEATURES CONTINUED
    Prius Three Touring (In addition to or in place of Prius Three standard features)
     SofTex®-trimmed front seats with Blue contrast stitching, seatback pockets; 6-way adjustable driver's seat; 4-
    Prius Four and Four Touring (In addition to or in place of Prius Three and Prius ThreeTouring)
    •  SofTex®-trimmed heated front seats, contrast stitching (Blue contrast stitching on Touring grade only) with seatback pockets; 8-way power-adjustable driver's seat with power lumbar support; 4-way adjustable front
      passenger seat
    •  Cargo area tonneau cover
      STANDARD AUDIO SYSTEM
      Prius Two and Prius Two Eco
     Entune Audio - includes the Entune Multimedia Bundle (6.1 in. touch-screen display, AM/FM CD player, 6 speakers, auxiliary audio jack, USB 2.0 port with iPod® connectivity and control, advanced voice recognition, hands-free phone capability, phone book access and music streaming via Bluetooth® wireless technology), Siri® Eyes Free, and integrated backup camera display
    Prius Three, Prius Three Touring, Prius Four, and Prius Four Touring
     Entune Premium Audio with Integrated Navigation and App Suite - includes the Entune Multimedia Bundle (7-in. high resolution touch-screen with split screen display, AM/FM CD player, 6 speakers, auxiliary audio jack, USB 2.0 port with iPod® connectivity and control, advanced voice recognition, hands- free phone capability, phone book access and music streaming via Bluetooth® wireless technology), Siri® Eyes Free, Entune App Suite®, HD radio, HD predictive traffic and doppler weather overlay, AM/FM cache radio, SiriusXM All Access Radio with 3-month Complimentary Trial, Gracenotes album cover art, and integrated backup camera display. Access to EntuneTM services is subscription free. See toyota.com/entune for details.
    Entune® App Suite - includes Destination Search, iHeartRadio, MovieTickets.com, OpenTable®, Pandora®, Facebook Places, YelpTM and Slacker Radio; real-time info including traffic, weather, fuel prices, sports and stocks. Access to EntuneTM services is subscription free. See toyota.com/entune for details.
    STANDARD SAFETY AND SECURITY
    •  Star Safety System TM - includes Enhanced Vehicle Stability Control (VSC), Traction Control (TRAC), Anti- lock BrakeSystem(ABS)withElectronicBrake-forceDistribution(EBD),BrakeAssist(BA),andSmartStop Technology (SST).
    •  Driver and front passenger Advanced Airbag System
    •  Driver and front passenger front seat-mounted side airbags, passenger seat cushion airbag, driver’s knee
      airbag, and front and rear curtain shield airbags
    •  Driver and front passenger active headrests
    •  LATCH (Lower Anchors and Tethers for CHildren) includes lower anchors on outboard rear seats and tether anchors on all rear seats
    •  Tire Pressure Monitor System (TPMS)
    •  Vehicle Proximity Notification System (VPNS)
    •  Toyota Safety Sense-P (TSS –(P)) - Pre-Collision System with Pedestrian Detection, Lane Departure Alert with Steering Assist, Auto High Beams and Full-Speed Dynamic Radar Cruise Control (standard on Prius
    Touring grades only)
    STANDARD SAFETY AND SECURITY CONTINUED
    •  Blind spot monitor (BSM) with Rear Cross-Traffic Alert (RCTA) (Prius Four and Prius Four Touring only)
    •  Hill Start Assist Control
    •  Engine Immobilizer
    •  Side-impact door beams
    •  Front and rear energy-absorbing crumple zones
    •  3-point seatbelts for all seating positions; driver-side Emergency Locking Retractor (ELR) and
      Automatic/Emergency Locking Retractor (ALR/ELR) on all passenger seatbelts
    •  Child protector rear door locks
    •  Adjustable front seatbelt shoulder anchors, driver and front passenger seatbelt pretensioners and force limiters
      FACTORY OPTIONS
     Premium Convenience Package (available on Prius Four and Prius Four Touring)
    o Intelligent Clearance Sonar (ICS) with Intelligent Parking Assist (IPA)
    o Entune Premium JBL Audio with Integrated Navigation and App Suite - includes the Entune
    Multimedia Bundle (7-in high resolution touch-screen with split screen display, AM/FM CD player with MP3/WMA playback capability, 10 JBL® GreenEdgeTM speakers in 8 locations, auxiliary audio jack, USB 2.0 port with iPod® connectivity and control, advanced voice recognition, hands-free phone capability, phone book access and music streaming via Bluetooth® wireless technology), Siri® Eyes Free, Entune App Suite®, HD radio, HD predictive traffic and doppler weather overlay, AM/FM cache radio, SiriusXM All Access Radio with 3-month Complimentary Trial, Gracenotes album cover art, and integrated backup camera display. Access to EntuneTM services is subscription free. See toyota.com/entune for details.
    o Safety Connect® — includes Emergency Assistance, Stolen Vehicle Locator, Roadside Assistance and Automatic Collision Notification. Available by subscription. (Complimentary one-year trial subscription).
     Advanced Technology Package (available on Prius Three and Prius Four) –
    o Toyota Safety Sense-P (TSS-P) - Pre-Collision System with Pedestrian Detection, Lane Departure
    o Color Head-Up Display (HUD) with speedometer, navigation and Hybrid System Indicator
    o Power tilt/slide moonroof with sliding sunshade .
    AVAILABLE EXTERIOR COLORS
    - Hypersonic Red (New Toyota color) - Blizzard Pearl
    - Sea Glass Pearl
    - Blue Crush Metallic
    - Magnetic Gray Metallic
    - Classic Silver Metallic
    - Midnight Black Metallic
    - Super White (available to Fleet customers only)
    BASIC LIMITED WARRANTY COVERAGE
    •  3-year/36,000-mile Comprehensive
    •  5-year/60,000-mile Powertrain
    •  5-year/unlimited-mileage Corrosion Perforation
    •  8-year/100,000-mile Hybrid-related Component Coverage
    •  15-year/150,000-mile Hybrid-related Component Coverage (applicable states are: CA, MA, NY, NJ, VT, CT, ME, NM and RI) with the exception of the hybrid battery. The hybrid battery is warranted for 10 years/150,000 miles.
    •  Toyota Care – Complimentary maintenance plan with the purchase or lease of every new Toyota. For
    two years or 25,000 miles, whichever comes first, every new Toyota will be covered for all normal factory scheduled service, as well as three years* of 24/7 roadside assistance
    *Exclusive to Prius Liftback over the standard two years for all other Toyota models
    It appears your Web browser is not configured to display PDF files. No worries, just click here to download the PDF file.
    SAronian, Jeff N, Ashlem and 5 others like this.
  2. giora
    giora Senior Member
    1,966
    729
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Cannot see 0-60 time! Did I miss it?
  3. Danny
    Danny Admin/Founder
    7,093
    2,100
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    Not sure that they have officially published it, but it is the same 9.7 as the 3G Prius.
    But 0-30 is greatly improved.
    john1701a and giora like this.
  4. DtEW
    DtEW Active Member
    242
    137
    SF Bay Area, CA
    No weight reduction + a net 13hp loss + "(0-60) same 9.7 as the 3G Prius" + "0-30 is greatly improved" = 30-60 much worse than the 3G Prius? Torque hits early, but engine wheezes out? Does that mean that 60-onwards might be worse as well?
  5. Danny
    Danny Admin/Founder
    7,093
    2,100
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    The HP loss is not what it appears. They are calculating horsepower differently than they did with the 3G Prius. It's explained in this video:
    I'll also try to explain it in my written review later in the week.
    Ashlem and cycledrum like this.
  6. bwilson4web
    15,372
    city combined highway model
    1 51 MPG (100%) 50 MPG (100%) 48 MPG (100%) 2010 Prius
    2 54 MPG (105.9%) 52 MPG (104.0%) 50 MPG (104.2%) 2016 Prius Non-Eco
    3 58 MPG (113.7%) 56 MPG (112.0%) 53 MPG (110.4%) 2016 Prius Eco
    Now to find the new Japanese HP rating. Also, I like the idea of replacing the valve springs to improve engine efficiency . . . that would work on our ZVW30.
    #6 bwilson4web, Nov 18, 2015
  7. giora
    giora Senior Member
    1,966
    729
    2013 Prius Plug-in
    This new calculation method also means that the max battery power is more than just 26 kW (121-95), probably similar to Gen 3 (or more?) indicated by the improved 0-30.
    30-60 portion of the 0-60 test is slower, however, overtaking 30-60 may be quicker as the battery can give its max power in this situation (i.e. it is not exhausted).
    Also, I assume this 'net system power' will be much closer to max power result from a dyno test.
    #7 giora, Nov 18, 2015
  8. GasperG
    GasperG Senior Member
    1,168
    597
    Slovenia
    2018 Prius
    Under max acceleration regardless of speed ICE is the main generator of power, with previous version it was rpm restricted (PSD MG1 restriction) and it produced less torque under low rpm.
    Remember power = torque * rpm
    I will try to make this in numbers, just as an example (not real numbers)
    Gen3 @20 mph:
    - max iCE Speed 3.500 rpm, max torque 120 Nm = 44 kW
    Gen4@20 mph:
    - max ICE spee 4.000 rpm, max torque 142 Nm = 59 kW
    There is also electric motor power@speed rating, that could make a change, but battery power IMHO is just the same or even lower then previous version.
    Again this is just wild guess what is going on under a skin, don't take my numbers as real.
  9. giora
    giora Senior Member
    1,966
    729
    2013 Prius Plug-in
    Not true for max acceleration at very low speeds where battery is the main generator of power.
  10. giora
    giora Senior Member
    1,966
    729
    2013 Prius Plug-in
    Still miss what models will have Li-ion battery?
    OOPS found it, NiMH on model 2, Li-Ion for all the rest.
    #10 giora, Nov 18, 2015
  11. GasperG
    1,168
    597
    Slovenia
    2018 Prius
    Not true, as I pointed in my previous post, even under low speed ICE can work in the region 40-50 kW, that is way more than power from the battery, use torque app and OBD if you don't believe me.
  12. giora
    giora Senior Member
    1,966
    729
    2013 Prius Plug-in
    What about 0-20 MPH?
  13. GasperG
    1,168
    597
    Slovenia
    2018 Prius
    I see your point, but even at 0 MPH you can force charge battery in D with brakes on, what happens when you release the brake? ICE rpm goes up and power that was charging the battery goes to the wheels, battery assists, but as soon ICE rpm reaches 2.000 rpm it delivers more power than battery, at what speed the car is by then is hard to say, but if certain load would brake the car (trailer, big incline) we would see this more slowly.
  14. giora
    giora Senior Member
    1,966
    729
    2013 Prius Plug-in
    Danny reported improved acceleration 0-30, this must come from improved MG2 torque at these speeds (where else can it come from?) which is achieved, in my opinion, by higher currents from the battery (higher battery delivery power).
    Size of battery dictates that this high power is available only for a short time period, on the other hand higher regeneration power means capacity is replenished rather quickly (ready for the next load mission).
  15. monskie15
    monskie15 Junior Member
    Massachusetts
    Active grill shutters? Would that mean no more grill blocking during the winter?
  16. Lee Jay
    Lee Jay Senior Member
    5,850
    4,017
    Westminster, Colorado
    As expected, the packages are crap. If I want advanced collision avoidance technology or *gasp* a garage door opener, I have to get fake leather seats. Or I could buy a higher end package and then pay to have the fake leather seats removed.
    And no E-Four.
    I'll go test drive one in hopes they pull their collective heads out sometime later, but I'll be keeping my 2004.
    Sergiospl and C W like this.
  17. bisco
    48,862
    yep.
    Danny likes this.
  18. john1701a
    john1701a Prius Guru
    12,747
    5,243
    57
    I wasn't expecting that change from the current specs of: 42.5/36.0
    The extra room in front is obviously a welcome improvement for the long-legged. For the shorter, that front extra can simply be used in the rear. So, it's really like 42.5/34.1 in. But overall, it did shrink.
    TonyWilkey likes this.
  19. Stevevee
    Stevevee Active Member
    821
    224
    Vermont
    That should bode well for winter mpg's
  20. bisco
    48,862
    should work better than my rag tag styro tubing.:cool:
    Danny likes this.
