1. Offline
    IsrAmeriPrius Progressive Member
    4,338
    Southern California
    Your Vehicle Year:
    253 MPH and Still a Little Late (click here for the complete article)
    The Bugatti Veyron is a superlative on wheels. But for VW, which spent six years and about half a billion dollars, it may be obsession run wild.
    By Dan Neil, Times Staff Writer
    PALERMO, Sicily — At 200 mph, the Bugatti Veyron pounds a beautiful, howling hole in the sweltering haze hanging over the motorway.
    This, the fastest production car in the world, is broad and low, an enameled ellipse in a spiffy two-tone paint scheme. By comparison, its now-vanquished supercar rivals, such as the Ferrari Enzo and McLaren F1, are all edges and blades and angles, like F-16 fighter planes or Japanese stunt kites.
    A superlative on four wheels, the Bugatti Veyron 16.4 is not only the world's fastest production car but also the most expensive: $1.25 million before taxes and richly deserved gas-guzzler penalties. Also, the most powerful: Its 8.0-liter 16-cylinder quad-turbo engine produces about 1,000 horsepower and churns it through a high-tech all-wheel-drive system and gob-smacking foot-wide tires. Also, the quickest: The Veyron accelerates to 60 mph in 2.1 seconds, faster than a Formula 1 car, but then it's just getting started. In 20 seconds — about the time it takes a fast reader to get through this paragraph — it reaches 200 mph. In 53 mind-blowing seconds, the Veyron reaches its marquee speed: 253 mph.
    At that speed, the tires would begin to soften in about half an hour. Fortunately, at top speed, it runs out of gas in 12 minutes. "It's a safety feature," Wolfgang Schreiber, the Veyron's chief engineer, says with a smile.
    Meanwhile, back at 200 mph, technical director Schrieber is urging me on. "This makes fun, doesn't it?" he asks.
    The main autostrada of Sicily is not exactly glass-smooth, nor particularly straight, and as I bend the car into a sweeping right-hander at about 205 mph, a flock of butterflies the size of vampire bats alights in my solar plexus. The suspension is working hard and I can feel the static of the tires coming through the stitched-leather steering wheel. I am very curious to see if the car will hold the line in the corner or slide off into the heavenly yonder.
    When the car reaches 137 mph, hydraulics lower the car until it has a ground clearance of about 3 1/2 inches. At the same time, the wing and spoiler deploy. This is the "handling" mode, in which the wing helps provide 770 pounds of down force, holding the car to the road. This drag-limits the car to about 230 mph.
    To go faster, drivers have to stop the car and activate the top speed mode with a special key in a lock to the left of the driver's seat. This lowers the car to a ground-skimming clearance of about 2 1/2 -inches and retracts the rear wing so that it just peeks out over the bodywork. At 250 mph, a little wing angle is all you need. At the same time, openings for aerodynamic tunnels built into the car close, creating a fully flat-bottom car.
    The Veyron has a lot of other tricks up its carbon-fiber sleeve. When the brakes are activated at high speed, the rear wing tilts to 70 degrees, creating what is effectively an air brake — should the 15-inch carbon-ceramic disc brakes not prove to be enough. Here is a fun fact: In a panic stop from 253 mph, the Veyron comes to a halt in less than 10 seconds — hard enough to pull the sunglasses off your face.
    Bugatti has said it will build no more than 300 of the cars, optimally 50 to 80 per year. There will be 20 dealerships worldwide, including O'Gara Coach Company in Beverly Hills. Ehren Bragg, president of O'Gara, says the dealership has four orders in hand. The down payment is $413,000, enough to buy six Chevrolet Corvette Z06s.
  2. Offline
    DocVijay New Member
    1,456
    Tampa, FL
    Truly a wonder of automotive engineering. Yes, it was a few years delayed, but who cares. You can't rush perfection.
  3. Offline
    Potential Buyer New Member
    290
    I'm 95% finished downloading a Top Gear episode aired today in which one of them drives the car across Europe. It'll be exciting I'm sure.
  4. Offline
    Oxo New Member
    535
    Oxfordshire, UK
    Your Vehicle Year:
    Shown last night on BBC 2. It's driven by Clarkson from Switzerland to central London in a race with a small aircraft, and the car wins. Clarkson says that the car is designed by Volkswagen as an experiment and sells for £84,000 but cost many millons over 5 years to design and build. The race is more boring that exciting.
  5. Offline
    DocVijay New Member
    1,456
    Tampa, FL
    Then it's the wrong car, or maybe just a mistake on his part. This thing was designed by Volkswagen in that they own Bugatti, but it costs more like 840,000 pounds (sorry, don't know keys for pound sign). Also, it cost them BILLIONS not millions.
  6. Offline
    4,338
    Southern California
    Your Vehicle Year:
    It is "only" £810,000 according to The Sunday Times (London):
    Bugatti Veyron; Utterly, stunningly, jaw droppingly brilliant
    P.S. Even though we do not have a "£" key, that symbol can copied and pasted from any other web page.
  7. Offline
    290
    It cost half a billion dollars to research and develop the prototype; that's always the most expensive step for any car anyway. Each production car costs somewhere around 5 million pounds to produce. Basically it's like a production concept car.
    Clarkson won, but he always wins. What I hate is how they give no indication of how much faster he was than the others... they edit it to make it look like they approach London at the same time, race up the elevators at the same time, but they didn't. Clarkson must have arrived at least 20 minutes before the other two.
  8. Offline
    • Moderator
    13,921
    1,217
    Far-North Chicagoland
    Your Vehicle Year:
    In 12 minutes you've traversed 50 miles. It would take me another five minutes just to pry my hands off the steering wheel.
  9. Offline
    14,314
    1,331
    Spokane, WA
    Your Vehicle Year:
    The subtitle of this thread says it all for me: Who'd want a car that needs gas every 12 minutes?
  10. Offline
    DocVijay New Member
    1,456
    Tampa, FL
    Yes, but you're also going 253 mile per hour!!! You can't leave that part out otherwise it's a useless number. If you drove your Prius at its maximum speed, exactly how long would your gas last? Would you get 55 miles per gallon? Hell no. It would be like complaining because it couldn't tow a boat as well.
    At 253 miles per hour, you don't want to be drivning for more than 12 minutes anyway...
  11. Offline
    micheal I feel pretty, oh so pretty.
    845
    Lubbock, TX
    Your Vehicle Year:
    The people that go 100+ report around 30-35 mpg, so about 3 to 3 1/2 hours.
    It sounds like a great piece of engineering, but a big fat waste of money if you ask me.
  12. Offline
    mt77 New Member
    I've never seen Clarkson lose before except for maybe that downhill race with rock climbers. Sad they didn't take the Veyron around the track with the Stig to see how it'd handle. Probably not too well I imagine.
    ~MT77
Share This Page
