35 mph EV barrier
Discussion in 'Gen 2 Prius Accessories & Modifications' started by drjake, Dec 27, 2011.
  1. drjake
    drjake New Member
    PA
    Has anyone found a way to break the 35 MPH EV barrier I was thinking
    putting a flip flop on the speed sensor to divide the signal by 2 and maybe that would make it to 70MPH? any thoughts
    If this could work then I would think about adding batteries and a charger system.
  2. Rokeby
    Rokeby Member
    3,006
    693
    75
    Ballamer, Merlin
  3. F8L
    19,149
    4,040
    50
    Sacramento, CA.
    2013 Chevy Volt
    The upgraded plug-in systems allow for higher speeds so why would you want to increase the speed on the the OEM system?
  4. LIPriusFreak
    LIPriusFreak Can I haz JDM?
    449
    31
    Long Island, NY
    100% true but in the OP's defense...what if the owner doesn't have $7k+ to spend on a plug in system?
  5. F8L
    19,149
    4,040
    50
    Sacramento, CA.
    2013 Chevy Volt
    Then why would you want to increase the EV speed? You shouldn't be driving in pure EV mode in most situations and going freeway speed in EV mode will get you all of about 1/4mile before it needs to be recharged. lol
  6. LIPriusFreak
    449
    31
    Long Island, NY
    to save on gas??? lol.... me personally, since my baby (acura legend) gets 17mpg, I am more than happy even getting 35-40mpg on my prius...
    but some want more.....I personally wouldnt wanna drive in pure EV mode.....the car has no balls as is, forget straight EV LMAO!
  7. F8L
    19,149
    4,040
    50
    Sacramento, CA.
    2013 Chevy Volt
    But you will LOSE gas mileage by driving in EV mode, especially at high speed. The Laws of thermodynamics cannot be bent. lol There are very few cases that forced EV mode at high speed would help mpg.
  8. LIPriusFreak
    449
    31
    Long Island, NY
    call me an idiot, but at ANY speeds using no gas = unlimited MPGs no??
    if the car ran in EV mode onlly (assuming it was possible) then how could it not get better MPG since its not burning gas at all?
  9. F8L
    19,149
    4,040
    50
    Sacramento, CA.
    2013 Chevy Volt
    Let me answer your question with another question. Where did the energy stored in the battery originally come from? :)
    The answer 95% of the time is gasoline. So you burned gas and turned it into electricity. You have suffered a conversion loss when you did that and transformed some of that energy into heat. Now you will use the energy to propel the car and that energy will have to be replaced. Unless you are going down a long hill and can regenerate energy through the braking system you will replace that energy with the ICE which runs on gasoline. So as you can see, the energy stored in the HV battery came mostly from gasoline so using that energy to propel the car completely is a huge waste of energy and should only be used to assist the ICE and not as a sole power source.
  10. F8L
    19,149
    4,040
    50
    Sacramento, CA.
    2013 Chevy Volt
    I should have stated that the real improvements in efficiency in the Prius and most other hybrids comes from the Atkinson Cycle engine and the fact it can turn off when coasting or at stops as well as the regenerative braking system. The HV battery system is mainly there to supplement power as needed for acceleration because the Atkinson Cycle engine is rather weak on its own.
  11. LIPriusFreak
    449
    31
    Long Island, NY
    lol wut? I get what you mean and me being a dumbass, forgot to realize the energy has to replenish and it replenishes through the gasoline motor so there is no way to NOT burn fuel
  12. F8L
    19,149
    4,040
    50
    Sacramento, CA.
    2013 Chevy Volt
    Nah, you're not a dumbass. It is a common misconception with hybrids so there are millions of other people who forget or didn't realize where the engery comes from. That is why we have that question in our fuel economy questionnaire. There are so many people who try to drive in EV mode to save fuel. lol
    The OP may have something else in mind though. I only added my question because other people may be lurking in the thread who would have been misled otherwise. :)
  13. drjake
    drjake New Member
    PA
    OK back to the question is it possible to go faster than 35 MPH. I like to do things myself
    I don't want to take my car to some one and pay 7K to convert it to a PHEV
    first step is has anyone found a way to go faster than 35 I'm not looking to break the sound barrier
    just go like 55mph if that can be done then I will look in to adding a plugin system and more
    battery power
    Thanks for any help
    Newbie
  14. F8L
    19,149
    4,040
    50
    Sacramento, CA.
    2013 Chevy Volt
    I already said it is possible. The plug-in kits can do it.
    Honestly if you have to ask this question I am not sure you are qualified to perform a plug-in upgrade. I know that sounds harsh but there is a lot that goes into it besides speed caps. :(
  15. cproaudio
    cproaudio Speedlock Overrider
    2,300
    629
    CA
    driving faster than 35 MPH on EV only is possible if you accelerate gently. a stock hybird battery has only enough power to accelerate the Prius to 42MPH before running out of juice and force the ICE kick on to recharge. during this recharge you'll get about 30-35MPG until the stock battery has been recharged back to normal level. this may take a couple of miles. the overall mileage with depleted battery will be far worse than keeping the battery at normal charge.
    the Prius doesn't accelerate well with electric motor even with plugin conversion. however, it can sustain EV at higher speed than a stock Prius.
    I think the OP meant how to accelerate past 35MPH in EV only. it's not that simple and cheap. if it was, everyone will be doing it. this is a Prius, not a volt. it's going to take a lot of money to make it drive like one.
  16. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,448
    38
    Santa Fe, NM
    All you have to do is cut power to the fuel pump, then it will let you go 52. Just about anything else is a lot more work.
  17. cproaudio
    2,300
    629
    CA
    1, stock battery doesn't have enough power to let you go from 0 to 52mph, 41 maybe, 43 if you're lucky, beyond 45 forget it.
    2, creating an open circuit on the fuel pump will light up your dash like a Christmas tree.
    3, once you've created an open circuit, you need to power off then on the Prius to reenable the ICE.
    4, the distance you can travel on EV is way less than 2 miles
    5, you'll run the risk of depleting the HV battery below the recommended SOC.
    6, EFI hack is only recommended on cars with contactor type of PHEV and not even recommended on converter type PHEV.
    If you ignore all the precautions, then yes, pulling the EFI fuse is the easiest way to bypass the Gen II's 34mph and Gen III's 25mph barrier. If you're gonna do it, at least get a cheap PHEV kit. That way, if you ran down the HV battery below 40% SOC, at least you'll have a way to recharge the HV battery back up to safe SOC.
  18. seilerts
    3,326
    1,448
    38
    Santa Fe, NM
    Exactly the point. The car will go 52, because it thinks it is out of gas, but you need to have some serious juice stored up in some sort of PHEV pack to have any sort of range. But it is the quickest route for the original poster to break the 34 mph EV mode barrier, and was the method used by some of the early PHEV systems. The modern systems have person-years of development in SoC spoofing, piggyback ECUs, etc, and would be a lot more work for someone to duplicate DIY if starting from scratch.
    2 people like this.
  19. Rest
    Rest Active Member
    1,210
    35
    CA
    Really? There are non hybrid vehicles getting that now.
  20. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,285
    447
    Maine
    But they probably aren't driving in busy Long Island traffic.
