36 Mpg 2013 Prius package 5
Discussion in 'Gen 3 Prius Fuel Economy' started by adcsarge, Aug 15, 2014.
  1. adcsarge
    adcsarge Junior Member
    Fond du lac, WI
    I don't understand it, I do all city driving and getting only averaging 36mpg. I have under 3,000 miles on my car, does anyone have any advice for me. Thanks in advance! I am the original owner on this 2013 prius.
  2. Redpoint5
    Redpoint5 Senior Member
    1,026
    508
    Portland, OR
    Is your commute only 1 mile?
    I can get 36 mpg in stop and go traffic in my TSX.
  3. adcsarge
    Fond du lac, WI
    No, I am disabled so I don't drive much.
  4. abistro
    abistro Junior Member
    22
    Virginia
    Most of the MPG gains are through learning how to properly drive a hybrid. If you drive it like a regular car, it'll get dismal MPG. If I had to guess, you probably had the AC blasting too along with really hard stop/go.
    When I had my 2013 Prius 2, I was getting an average of 43 MPG because I have a heavy foot at times.
  5. Grren4ever
    Grren4ever Active Member
    347
    166
    IMO, the good thing about the prius is that you don't really need to learn how to drive it to get good MPG. If you do learn how to drive it, you'll get exceptional MPG.
    That being said, 36 is quite horrible. It is hard for us to know what is going on with your car unless we accompany you on one of your trips.
  6. terry brecheen
    139
    30
    houston, texas
    Check your tire pressures. It takes five to seven minutes for the engine to warm up and be efficient. If your trips are five miles or less you are not going to get great mileage out of it. I have a 2012 level five. I've aired my tires up to 42 front and 40 rear. In the mornings my trip to work reads out 57mpg. 16 miles highway and 4 miles city driving. On my trip home with a lot of traffic congestion I get somewhere between 48 to 53 depending on congestion. If I drive to lunch from 2 to 4 miles I get in the 39mpg range. There's is probably nothing with your car you just have to give it time to warm up and cruise a little bit. Goodluck and enjoy your really nice car.
    Jon Hagen likes this.
  7. bisco
    48,945
    if you don't drive much, that may be your hole problem.
  8. bwilson4web
    15,389
    I don't know your living situation but it sounds like you might be a good candidate for a Leaf or other EV or plug-in. But I also notice you live in Wisconsin and the cold weather can really hit Prius performance hard. One mitigation might be to get a block heater installed.
    Do you have trouble keeping the 12V battery charged? The Prius 'parasitic' loads that handles the key fob along with keeping memory alive can drain a 12V battery. Just curious.
  9. adcsarge
    Fond du lac, WI
    No problems to date, thanks for everyone's input.
    SCH-I545 ?
  10. bisco
    48,945
    pleasure.
  11. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    I think Bob's on the right track. If a lot of those 3,000 miles have been in cold weather, that would skew the mpg lower than what is considered normal. And if those trips are short, the mpg would suffer that much more, wouldn't it?
  12. Okinawa
    Okinawa Senior Member
    1,333
    317
    I have a 2014 Avalon Hybrid XLE Touring. I get 38 to 40 in suburban Chicago driving. Check your air filter and cabin filter. Check the air pressure in your tires and inflate to the recommended PSI on the label inside your drivers door. You should be getting about 50 in this kind of weather.
  13. adcsarge
    Fond du lac, WI
    Well today I had to run some errands and did not turn on the A/C and did my best to drive the Prius "the correct way" I drove 7.3 miles and was getting 65.8 MPG according to the trip odo. I guess it is my driving habits. A few angry drivers behind me.
  14. Okinawa
    1,333
    317
    What an improvement!!! Just slow down a little and enjoy the nice scenery in Fond du lac. I love it up there. Don't worry too much about the angry drivers behind you. They'll get over it. I'll be up that way this Fall and some of them will get behind me instead of you.
  15. DoubleDAZ
    1,209
    322
    Peoria AZ (Phoenix)
    Hey, I'll be going through Fond Du Lac next month. I spent quite a bit of time in Fond Du Lac, mostly Lakeside Park, back in the 60's. We also went down for football games. Small world!
  16. adcsarge
    Fond du lac, WI
    We will be glad to have you up here. The more Prius' s the better. Not all that many up here!
    SCH-I545 ?
  17. priusdonkey
    priusdonkey Member
    211
    51
    Los Angeles, California
    don't drive it like you stole it. lightly press the gas pedal like it is an eggshell. gently, not sure about your disablilty? you might try taking yous shoes off, you will have much better feel on the pedals. i drive almost 100% barefoot.
  18. bisco
    48,945
    it is illegal to drive in ma without footwear.
