1. Offline
    mostl harmless New Member
    Start a Conversation
    May 26, 2005
    Sykesville, MD
    Just wondering... I notice that my 2004 Prius spins the ICE at about 42 MPH. From reading Graham's description of the original THS this makes sense to preserve MG1. I thought that THS II allowed higher revs for MG1 than THS.
    Did they change the gear ratios in the PSD, the gearing of the ring gear to the wheels, or is this just an artifact of the THS software?
    mostly curious,
    jim
  2. Offline
    DanMan32 New Member
    Aug 27, 2004
    3,775
    Tampa Bay, FL
    They did design MG1 to allow more revs, but I believe the intent was to get more generated power. I believe what you're seeing is an artifact. Shouldn't matter much though.
  3. Offline
    hobbit New Member
    Mar 23, 2005
    4,083
    406
    Bahstahn
    Your Vehicle Year:
    If you get in a situation where you're under 42
    mph, ICE-off, on a downhill, you can move to Neutral
    and actually wind up going considerably faster than
    42 mph without the engine spinning at all.
    Kind of fun, and probably helps mileage a bit. Until you
    have to slow down, of course; moving back to D
    spins the engine and enables regen.
    _
    Save the rants about "illegal to coast in neutral".
    The definition doesn't apply to the prius, because the
    geartrain is always engaged and Neutral is just an
    electrical state. The car can coast like a soapbox
    derby racer anyways, and that's part of the fun.
    _
    _H*
Share This Page
