Attention: If you have a squeaky CHS water pump! New TSB
Discussion in 'Toyota Prius Service Bulletins - TSBs' started by galaxee, Jun 8, 2008.
  1. galaxee
    galaxee mostly benevolent
    9,810
    469
    MD
    it's covered under the powertrain warranty- 5/60.
    T-SB-0087-08 June 5, 2008
    Abnormal Noise from Coolant Heat Storage Water Pump
    Introduction
    Some 2004 – 2008 model year Prius vehicles may exhibit a “squeak†type noise during vehicle
    startup or shutdown. This noise can be heard coming from the coolant heat storage water pump
    during cold ambient temperature conditions. Use the following procedure to address this condition
    only if the noise is confirmed to be coming from the coolant heat storage water pump.
    Meg&Bear, cwerdna, danniel and 3 others like this.
  2. galaxee
    9,810
    469
    MD
    for the record, we're having this done since ours makes the noise when it's cold.
  3. Patrick Wong
    18,200
    6,498
    Thanks, Galaxee! I also want to get a new pump. This one bulletin will probably increase Toyota's warranty costs significantly as ~100,000 Prius owners request CHS pump replacement...
    Since your DH is no longer working as a tech, what is your source for the TSBs?? Do you subscribe to techinfo.toyota.com ?
    Meg&Bear and volcomholls like this.
  4. galaxee
    9,810
    469
    MD
    pay money... for tis... lol
    let's just say we have remaining connections to that world.
  5. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    Another "thanks" here.
    Since we're in the midst of 3 days of 100F temps, the pump is kind of quiet now. ;) I'm assuming it's pretty warm down your way too. Are you waiting until cold weather returns, or are you still connected enough to convince the dealer to do the work now?
  6. VaPrius
    VaPrius New Member
    150
    Virginia Beach
    Thanks! I've noticed a squeak as well. Glad to hear it's under warranty.
  7. galaxee
    9,810
    469
    MD
    hoping to have it done yet this week- would prefer to invoke the powertrain warranty rather than the extended warranty.
  8. TheForce
    3,461
    537
    Wheelersburg, Ohio
    So what does this noise sound like? I have posted a link to what mine sounds like during shutdown.
    When you listen to my recording you will hear a hiccup type of squeak and then the normal sound. Near the middle of the recording you will hear that hiccup again. During the colder days this hiccup sound is quite constant. Do I need to get this TSB done on my car?
    http://stuff.jaygroh.com/priuschat/coolantnoise.wav
  9. Bill Merchant
    Bill Merchant absit invidia
    4,096
    85
    Thanks galaxee!
  10. Sufferin' Prius Envy
    Sufferin' Prius Envy Platinum Member
    3,998
    Well, looks like a bunch of us who live in mild climates will have to take a vacation in a cold climate come next Winter. It just may turn out to be a very prudent financial decision. :p
  11. redhandeddenial
    138
    harrisonburg,va
    TheForce i also have that noise in my 06 and just assumed it was the generator spooling down
  12. ny biker
    ny biker Member
    463
    Northern Virginia
    2022 Prius
    This is great, thanks.
    Any idea how to get them to confirm that the noise is coming from the CHS pump if it only happens on a cold start and even then it doesn't happen every time?
  13. Sufferin' Prius Envy
    3,998
    It doesn't "only happen(s) on a cold start."
    The TSB states:
    Some 2004 – 2008 model year Prius vehicles may exhibit a “squeak” type noise during vehicle startup or shutdown. AND . . . during cold ambient temperature conditions.
    Your use of the term "cold start" can also be confusing to some, as the TSB says "cold ambient temperature conditions," not a cold engine.
  14. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    What's mildly bizarre about this from my experience is that when
    it's *really* cold, the pump doesn't even try to pump. Not
    because it's failed in any fashion, but because the car doesn't
    bother. Like it thinks there's nothing worth using in the bottle,
    or something. Even odder is that if I give it a short period
    of block-heater, which tends to warm up the engine coolant temp
    sensor fairly quickly, *then* it will pump and my temp gauge
    proves that there was *plenty* of hot stuff available in the
    bottle after all. I'm thinking of adding some sort of ECT fakeout
    for those winter startups when I can't use the EBH just so I
    get the preheat I went to all that trouble of driving to generate
    and store.
    Oh, and yes, the thing sounds horrendous in cold weather but
    since it's only occasionally run, I'm not going to worry about
    it until it really fails. I'm over 60K at this point so it would
    cost me $.
    _H*
    Meg&Bear, prius_chatter and SageBrush like this.
  15. Ichabod
    Ichabod Artist In Residence
    1,794
    Newton, MA
    My car would qualify, since it clearly makes a squeaky noise during operation of that pump. I even took it to the dealer's shop a month or two ago and they told me it was "normal" and didn't do anything about it.
    My questions for the experts:
    1. Should I have this done? i.e. Is this just an annoying sound, or does it lead to failure of that pump?
    2. Would it be better to wait around for my warranty to be near expiration? I'm at 24k miles now and 2 years, so not too close to the 5yr/60k mark.
    3. It's not cold now, so how are they going to verify the noise if I take it in?
    4. Since it's something I already took it in for, are they going to say "we already told you no," or should I just refer to T-SB-0087-08?
    p.s. TheForce, your recording sounds downright pleasant compared to how mine sounds in cold weather! :)
    Meg&Bear likes this.
  16. TheForce
    3,461
    537
    Wheelersburg, Ohio
    Well mine sounds a lot worse in cold weather too. I'll have to record it again when the weather gets cold.
  17. ny biker
    ny biker Member
    463
    Northern Virginia
    2022 Prius
    Okay I will clarify. I hear the noise when I first start up the car after it has been sitting for a long time, such as overnight. If I drive a few miles, such as to the dealership, power down and then power up again, the noise does not happen.
    Also, this has not happened since the warmer weather kicked in. With temps in the 50s or lower I was hearing it, but not with temps in the 70s or higher.
  18. galaxee
    9,810
    469
    MD
    i suspect they're going to want to confirm the noise is due to the water pump before going ahead with the replacement under warranty. of course, now that it's warm out this will be damn near impossible to prove.
    the squeak on ours happens when the car was shut down during cold weather. (ie, if yours does this, you can take it to the dealership, park it, wait for the tech, then shut down and listen for the noise.) no signs of impending failure or anything, and it's been 3 winters now. DH has tested the thing and saw no problems.
    now that there's a tsb out, once you can demonstrate the noise they should take care of it.
  19. Danny
    Danny Admin/Founder
    7,093
    2,118
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    I thought I just had a beta version of the Prius with a "pedestrian warning system".
    Thanks for the info, galaxee!
    Meg&Bear and SageBrush like this.
  20. Nords
    Nords Member
    101
    Oahu
    Well, looks like this won't be a problem in our climate...
