Took Prius in for 60,000 mile servicing. Was told that the necessary and the recommended servicing would be over 400 dollars. I asked them to do only the necessary - oil change, tire rotation. They discovered seepage around the water pump. I need new water pump. Cost 400 dollars. And it just happens that my standard guarantee only covers 5 years or 50,000 miles. Just sounds suspicious, since I declined 400 dollars of work. What do you think? Also, I did buy an extended warranty. Should that cover my water pump work? I looked at warranty but could find nothing.... maybe I read it thru too quickly. Maybe one of you experts would know. You're always so good to help. Thanks. Sharon
Get a 2nd opinion at another Toyota dealer. But water pumps *do* fail, sometimes. Whether your extended warranty covers this depends on that warranty.
Hi Sharon, Suggest that you ask to be shown the water pump seepage. If it is leaking you should be able to see a reddish or pinkish powder residue where the leak is occurring. If you have the Toyota extended warranty then this repair should be covered.
Hi, Sharon, If your extended warranty happens to NOT be the official Toyota Financial Services one (in other words a 3rd party one that may have a lot of loopholes so that it won't cover the water pump), your factory warranty for the drive train is 5 yrs/60,000 miles (not the 50,000 you stated), so it should be evident (if the dealer isn't lying to you) that the seepage/leaking started before the 60,000 miles, so it should be covered under the factory warranty. However, the thing I'm not sure about here is if the water pump is considered part of the engine to them (I think it is). Ken (in Bolton,Ct)
TRouble is, I was a little late, like 60,300 getting it in; so if they wanted to be technical about it, it probably would have expired anyway. But I do have the extended warranty, bought from the dealer at the time of purchase, so I hope it is covered. Is seepage around the water pump a typical thing? Is the only repair total replacement of the pump? Not just gaskets or seals or something like that?
A little weep around the shaft seal of the mechanical, engine-driven water pump is *not* a problem. It can happen under higher pressure when things get hot, and will fling a very thin line of pinkish crust up onto the hood liner. But if you're not actually losing coolant at any visible rate, it's not a problem as the volume is very low and occurrence infrequent. . My car's been doing it every since I got it. . Backing off belt tension a little bit may also help. . _H*
I disagree with Hobbit on this point. If the leak is sufficient to fling coolant on the hood, then the pump should be replaced. In the case of the OP who apparently has extended warranty coverage, there should be no question about replacing the water pump now.
The water pump is only about $50 from Toyota and I replaced the damaged one on my salvage car in about an hour.
I agree wiith you. I bought a used 2005 prius from a bmw dealership. It had 100k. Car was in perfect condition. I bought some denso spark plugs, air filter, ac cabin filter, oil filter, etc from amazon.com. I came to prius chat and read the forms and replaced everything myself. I also decided to register my car on toyota owners website. Toyota had a waterpump recall for electric water pump. I made an appointment and showed at my toyota dealership. I told them that i just got the car and would like to get the recall done. My car was ready in about an hour. I was told that my car needs another water pump for engine 480 with labor, water pump belt 180 with labor, new ac filter 59.99, new air filter 30, transmission flush 180, coolant replacement 120 etc. I was really surprised because bmw dealership gave me a whole inspection report. They did a full inspection. They even changed tires because it did not meet bmw standards. I would have kept old tires for another 10k. They had brake pad readings, tire pressure, fluid checks, carfax ,etc. I knew this was all made up because i had just serviced my car few days ago. Everything i did matched with bmw paper work. How can these people tell me that i need new filters when i changed them two days ago? However i was still concerned about water pump so i bought a water pump, coolant and belt. My family mechanic put the car on his lift and could not find any leak. He decided to change the coolant since car had 100k and bmw did not change the coolant. I paid my mechanic $40 for half an hour of labor. My mechanic worked at honda dealership for 4 years and he said service advisor make up all kinds of service because they are paid on commision. Half of them are used car sales people. He said mechanics did most of the work and service advisors made 6 figures at the dealerships I took all the parts back to dealership and got a refund. I asked for a service manager but he was on lunch. I wrote a bad survey when i was send one. In the mean time i received a gift basket from bmw thanking me for my business. It came with swiss choclates, olive oil, cheese, cookies, etc. It looked expensive. Bottomline i am never going back to steallership. I am not even sure if they did the recall or just parked the car in the lot. Thanks to everyone on prius chat for sharing valuable info with everyone Sorry about my rant. I just hate dishonest service people trying to exploit anyone that steps into the dealership
I have a used 2005 Prius as well and just experienced a stealership experience. My water pump had been recalled so I brought it in. They told me it would take 3 hours to fix it. Well, after two hours they told me they were done, not to mention they told me my auxillary battery needed to be replaced, another water pump, some headlights, a belt, new wipers etc. etc. Well unbeknownst to them I had brought my car in the shop a couple of days before to get an oil change, new tires and coolant flush and no one in the shop mentioned these other issues. The dealership quoted me over $1000 worth of work just because i decided to bring in my car on a recall issue. ( And there was nothing wrong with the wipers - I replaced them last year). I didn't get any of the work done, and to be honest, I don't think they replaced the water pump. I asked the service guy why it only took two hours when he quoted me three and he said that he requested really fast service cuz he knew I wanted to get out of there. HAHAHA! Right. The next time Toyota sends me a recall notice I'm throwing it in the garbage. What a bunch of scam artists!!!
If I'm taking a car in for work that involves replacing parts, I sometimes mark the old part to make it easy to tell if it has been changed. Or if it's an internal engine or other internal part, do something so I can tell if that part of the engine has been opened up. A small dab of hardening putty or bondo on the side of a bolt head does the job.
1. I suggest you look for the inverter coolant pump which is behind the driver's headlamp assembly and in front of the main relay/fuse box. See if it looks like it is new, or if it is covered in dust/dirt (which would imply it is original.) 2. I also suggest that you differentiate between Toyota Motor Sales USA which is sending the recall notice, and the local dealer you dealt with. Although the latter may be acting in a devious manner, if TMS USA sends a recall notice then the car really could benefit from service. Hopefully you can find a better local dealer to work on your car.
