1. Offline
    Can'tWait New Member
    May 10, 2009
    Message Count:
    28
    Michigan
    Your Vehicle Year:
    2010 owners - pl confirm this
    I just pulled in for the first 5K oil change; she wrote me up for 29.95 as usual
    I then mentioned that they need to use the OW20 (I read on this forum) oil since this is 2010 model; she then modified the price for $65..since it is synthetic oil....
    $65 for just an an oil change...can this be true
  2. Offline
    SW03ES New Member
    Dec 8, 2004
    Message Count:
    2,480
    166
    Gaithersburg, MD
    Your Vehicle Year:
    Well...yeah.
    The $29.99 is for the dino-oil change. 5 quarts of synthetic oil will cost more than that...just the oil. 5 quarts of Mobil-1 Synthetic costs me $35 or so when I buy it for my oil changes. and yes...I know the car doesn't hold quite 5 but they still have to open 5 quarts so you're going to get billed for 5 quarts.
  3. Offline
    Boji New Member
    Oct 15, 2009
    Message Count:
    47
    Ottawa, Canada
    Your Vehicle Year:
    I don't know if I'm reading your response incorrectly, but you seem to say that you buy your synthetic oil and then bring it to your dealer to have them do it for you? If so, I'm surprised your dealer would allow you to do that.
  4. Offline
    eaglesight333 New Member
    Apr 23, 2009
    Message Count:
    952
    33
    Northern, IL
    Your Vehicle Year:
    I think it is just a touch high. But I believe most of us who go to the dealer will be paying 55-65.
    I know there was another thread or several on this a month or two ago.
  5. Offline
    Boji New Member
    Oct 15, 2009
    Message Count:
    47
    Ottawa, Canada
    Your Vehicle Year:
    Thanks--I'm combing through this site to find more information about this, and I'm not adverse to the idea, especially if the oil change intervals are longer than with regular dino oil--now I'm just wondering if Toyota Canada will endorse this as well.
  6. Offline
    radiocycle New Member
    May 10, 2007
    Message Count:
    473
    63
    Morro Bay, CA
    Your Vehicle Year:
    OK, so that's an additional $7.00 @ quart, assuming they will charge your for five quarts. That seems a bit on the high side to me; that's seven bucks in addition to the price per quart of dino oil. They need to get real!
    But if you're not comparing the initial estimate to the new one, then the price is in range. My dealer wanted $90.00 for the first 5K service... and that's why I won't be having my servicing done there!
  7. Offline
    eglmainz New Member
    Jan 21, 2009
    Message Count:
    887
    137
    Chicagoland, IL
    Your Vehicle Year:
    My dealership charges 79.99 for the 0w20 Oil change w/ filter, etc... They also told me that if I bring it in, and supply my own own oil, they will so it all for only $20, which covers their filter, and labor. (and is $10 off the cost of the Dino Oil Change).
    Seeing as I can buy the 0w20 at Walmart for $22.00 for a 4 quart bottle, and $8 for a single quart, then my spending $30 on oil, and $20 on installing it, stills seems a good deal as compared to the 79.99 they wanted from me the first time (which caught me by surprise).
  8. Offline
    rrolff Prius Surgeon
    Aug 19, 2009
    Message Count:
    1,602
    219
    So Cal
    Your Vehicle Year:
    Keep in mind - whatever price should also include tire rotation !!! One local dealer has specials (synthetic extra) - $29 for oil change, $75 for 5K (which is really just oil+tires)
  9. Offline
    eglmainz New Member
    Jan 21, 2009
    Message Count:
    887
    137
    Chicagoland, IL
    Your Vehicle Year:
    No, most dealers in the midwest charge in the range of $80 for this oil change, and another $25 for the tire rotation. Many offer a 5k service for $99.99 which includes both, and a few other inspections.
    While some dealers may have a great deal, based on some horror reports I have read on this blog, I would imagine that some shops are not using the oil required by our cars.
    In my case, I found a local tire shop to do my rotations for me, for only $5.
  10. Offline
    mikepaul New Member
    Dec 2, 2003
    Message Count:
    1,764
    Columbia, SC
    Your Vehicle Year:
    I took Amsoil to my dealer back when I was still going there occasionally and never had an issue. Discount was minimal but I WANTED to use that oil.
    Lately I take Mobil 1 with me to Pope-Davis around the corner, and pay $20.99 or so for the change and tire rotation. So I guess I'm at $43 or so, but the rotation alone is listed at $19 so I'm OK with the cost...
  11. Offline
    EternityInBlack New Member
    Aug 27, 2009
    Message Count:
    28
    Thousand Oaks, CA
    Your Vehicle Year:
    Three of the local Toyota dealerships here where I live are quoting me for $99 for the 5000 mile service for all the following:
    • Replace engine oil
    • Replace oil filter with Genuine Toyota oil filter
    • Lube chassis
    • Check & top off all fluid levels
    • Check tire pressure
    • Inspect suspension, steering & exhaust systems
    • Inspect, clean & adjust brakes
    • Check battery
    • Inspect lights & wiper blades
    • Inspect drive belts & coolant hoses
    • Rotate tires
    • Road test vehicle.
    Plus 21 point inspection.
    Is anyone getting all these services cheaper than $99?
  12. Offline
    wjterry New Member
    Jun 20, 2009
    Message Count:
    47
    Winchester, KY
    Your Vehicle Year:
    I can't tell...are you braging or complaining?
  13. Offline
    Mar 27, 2004
    Message Count:
    7,384
    760
    United States
    Your Vehicle Year:
    Mine changes the oil and filter for $20 when I bring the oil.
    You can save more by refusing the tire rotation. It's not really needed.
  14. Offline
    eglmainz New Member
    Jan 21, 2009
    Message Count:
    887
    137
    Chicagoland, IL
    Your Vehicle Year:
    I would disagree with your assesment that a tire rotation is not needed. However, I am following the sage advice I have followed for years, from my brother an ASE Master Mechanic with Chevy:
    If it is recommended to rotate your tires every 5k miles, then you can do the following, and save 1/2 the money with zero ill effects:
    5k, rotate all as expected.
    10k, do nothing.
    15k, rotate.
    20k, do nothing.
    25k, rotate tires.
    If you do this, instead of every 5k miles, your tires will still get the same total # of miles, but you will only change them 1/2 as often.
    It's like when we step. We can double the steps taken if we step forward, and then bring the rear foot even with the first. Instead, I prefer to take the rear foot, and bring it past the other foot, placing it front of me when I walk. Both walking styles will make you walk the same number of miles, but with twice the number of steps (rotations).
  15. Offline
    Indyking Happy Hyundai owner...
    May 28, 2009
    Message Count:
    1,280
    89
    I don't know... Indy, Chicago, Madison (WI)... it
    Your Vehicle Year:
    No, you have not being ripped off... welcome to the "high-cost maintenance 2010 Toyota Priusâ€â€¦ That’s all I can say after having Hondas for years...
  16. Offline
    Bica2go New Member
    May 21, 2009
    Message Count:
    321
    Boston, MA
    Your Vehicle Year:
  17. Offline
    jburns Senior Senior Member
    Oct 13, 2005
    Message Count:
    828
    104
    Archdale, NC
    Your Vehicle Year:
    Let us know how that drive belt inspection comes out.:rolleyes:
    It would also be fun to ask for a print out of the 21 points they are going to inspect.
  18. Offline
    DeadPhish New Member
    Sep 10, 2005
    Message Count:
    1,959
    325
    Outer Banks of NC.. Retired to play golf and poker
    Your Vehicle Year:
    Jiffy Lube here in SE VA is $79.95 for a syn-oil change.
  19. Online
    fuzzy1 New Member
    Message Count:
    4,363
    716
    Your Vehicle Year:
    At 5k and 10k miles, I wouldn't pay anything for most of those items.
    This had better be a generic car list, not specific to the 2010 Prius. If they intend to check the drive belts on the 2010, then I'd ask them about the clutch and transmission bands too. Then go find another shop.
    My maintenance guide doesn't ever list any chassis lube out to 120k, but does list other things not clearly called out on this list. Get a printout of those 21 other inspection points.
  20. Offline
    Boji New Member
    Oct 15, 2009
    Message Count:
    47
    Ottawa, Canada
    Your Vehicle Year:
    What makes you say that? Apart from the oil change, what else does the Prius require that, say, the Honda doesn't? I always thought it was the opposite--the Honda Civic Hybrid (HCH) required special tires and a pricey and special maintenance schedule.
Share This Page
