80 Watt headlight bulbs
Discussion in 'Prius c Accessories and Modifications' started by GRich, Jun 22, 2013.
  1. GRich
    GRich Junior Member
    28
    16
    Has anyone tried the high wattage 80watt bulbs in there projector lights? Can the housing withstand the extra heat? Will it tax the headlight wiring to much?
    Drdiesel likes this.
  2. Mo G
    Mo G Member
    317
    98
    Dallas,Tx
    I think there will be heat issues. And after I while, there will probably be burn marks in the projector bowls as well. Why the need for 80 watt bulbs?
  3. Nel
    Nel Member
    174
    84
    SF Bay Area
    Because more is better. It's the American way of life.
    Or at least that's what I heard on an infomercial
    Galaxy Nexus ? 2
  4. DKTVAV
    DKTVAV Active Member
    510
    101
    Not sure what "more is better" means but it will be "LESS is better" if you use 35W HID when talking about light output.
  5. Drdiesel
    Drdiesel Active Member
    585
    152
    Monterey CA
    All you'll get is a shorter bulb life with headlamp damage :eek:
    xpcman likes this.
  6. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    get 35w hid kit. done deal.
    ztanos, Nel and xpcman like this.
  7. Mo G
    Mo G Member
    317
    98
    Dallas,Tx
    Or get a hid retro fit done with a quad setup (2 projectors each side, so two 35w kits on each side, 70w of lighting on each side.)
  8. Drdiesel
    585
    152
    Monterey CA
    Is that the setup you have ? Do you have a link ? Thanks.
  9. Mo G
    Mo G Member
    317
    98
    Dallas,Tx
