1. Offline
    a64pilot New Member
    Aug 3, 2008
    Message Count:
    771
    56
    Albany Ga.
    Your Vehicle Year:
    I'm trying for 800 miles on one tank. Very mixed driving. Started with short trips, but my wife broke her ankle, I had to get both kids to school and her to work, so I went from short, to long commutes. I've been barely keeping 68 MPG as displayed, tough with short trips, and not driving the wife crazy. She won't tolerate P&G. I'm at 700 miles now with two "pips" lips left on the gas gauge, and back to short commutes now.
    Think I will make it?
    How does one get the car started if you run it out of fuel? I assume you simply add fuel and press the start button? There isn't any kind of priming procedure is there?
  2. Offline
    bwilson4web 03 and 10 Prius
    Message Count:
    7,495
    1,394
    Huntsville AL with 2003 Prius
    Your Vehicle Year:
    Yes.
    When the 'flash' begins, you have just over 2 gallons of fuel left.
    If you have an available trip meter, reset it "on flash" and then use the distance and MPG to figure out how much of the 2 gallons has been burned. Now the problem is when the last of the gas is gone, the car will flip into EV mode without any signal. However, you can see the battery level drop if you are watching for it.
    If you don't catch it soon enough, the traction battery will drain and the "electronic steering" icon will show. But the traction battery will be too low and the car will only roll to a stop.
    Regardless, take a photo of your trip meter. Then add a gallon of gas and the car will start and you can drive to a gas station to fill up.
    GOOD LUCK!
  3. Offline
    a64pilot New Member
    Aug 3, 2008
    Message Count:
    771
    56
    Albany Ga.
    Your Vehicle Year:
    Bob,
    I appreciate you answering as I know you have run one out. I thought the gen III was disabled and wouldn't move once the fuel ran out. I should know when it runs out because I have only been stealthing to start out as use of the traction battery has been detrimental for me in the long run. I try to run as much as possible in the middle of the HSI, leaving the ICE lit. Gliding and timing the traffic lights has been my best ploy, other than that and driving the car slowly, I am employing no techniques that I know of.
    I will take a Pic, probably several. Thanks again for your reply as I was worried about running it out. I seem to remember something bad happened to the Gen II.
  4. Offline
    DrJon New Member
    Jul 13, 2009
    Message Count:
    140
    Pinetop, AZ
    Your Vehicle Year:
    Dude, if you are at 700 miles and still have two pips left, there is virtually no chance you'll run out. Matter of fact, if you drive like you've driven the rest of the tank, you'll make 900 miles. I drove 129 miles after the first flashing! Good luck.:yo:
  5. Offline
    a64pilot New Member
    Aug 3, 2008
    Message Count:
    771
    56
    Albany Ga.
    Your Vehicle Year:
    Now it's like 725 and one pip, but it's solid. I'm going to run it out. One thing I want to find out is how much usable fuel there is, no good reason just curiosity. Somebody will get a 1,000 mile tank, maybe somebody already has.
  6. Offline
    • Moderator
    Sep 22, 2005
    Message Count:
    5,905
    1,081
    NY
    Your Vehicle Year:
    Based on what you're saying (one pip now, still solid, and at 725 for the tank) I think you'll make it no problem. I agree that once your DTE says 0 you'll still have about 2 gallons, so 800 will be no problem.
    But once you hit it, fill up! That's just my opinion... Sorry to be a killjoy but I never saw the big thing about hitting a certain number for a tank. It's just not worth the risk of damaging something for no reason. Still, 800 will be a great feat and if someone accomplishes 1000 eventually it will be amazing.
  7. Offline
    a64pilot New Member
    Aug 3, 2008
    Message Count:
    771
    56
    Albany Ga.
    Your Vehicle Year:
    I had forgotten about the DTE thing, it's at 49. I also took a picture. I assume Bob this is what you want for your data collection? If not let me know. Sorry about the quality of the pic, it seemed to need the flash for focus.
  8. Offline
    Message Count:
    7,495
    1,394
    Your Vehicle Year:
    Excellent photo but I'll start the data collection the end of this month. I'm going to try and assemble everything into a spreadsheet and keep it with the thread. More of a data analysis than a database, it will be good.
    You are still driving, right? You should make 800 miles with plenty to spare. However, I would start to carry a spare 1 gallon can. From 'flash', I believe you have ~2.1 gallons of usable fuel remaining. Even if the mileage drops to 50 MPG, you should bust 800 miles.
    FYI, I believe Ken@Japan scored a 1,000 mile tank in a 2010 Prius.
  9. Offline
    bestmapman "Dream" Prius
    Apr 8, 2007
    Message Count:
    1,107
    127
    Kentucky near Cincinnati, OH
    Your Vehicle Year:
    I think the Japan 2010 Prius has a lot bigger tank then we have.
  10. Offline
    a64pilot New Member
    Aug 3, 2008
    Message Count:
    771
    56
    Albany Ga.
    Your Vehicle Year:
    I don't know, from some of his fuel consumption pictures, I would say he could easily do it. I don't think it would be impossible to do, I think 80 MPG would do it, I just don't have the commute that that is mileage friendly. I think it would take P&G to do it and I don't have the patience or the lack of traffic. Lately it's been 4 to 6 miles several times a day with at least an hour between trips and it's hard to keep the mileage up. I can't get the first 5 min. segment above maybe 50, and it's hard to average 68 or better if you drive is only 8 or 10 min., but given the desire etc.
    Oh and I doubt the Japanese Prius would have a bigger tank, if nothing else why would they want the extra weight?
  11. Offline
    Apr 8, 2007
    Message Count:
    1,107
    127
    Your Vehicle Year:
    I did a 1000 tank in the Gen II, but have not attempted one in the Gen III
  12. Offline
    DrJon New Member
    Jul 13, 2009
    Message Count:
    140
    Pinetop, AZ
    Your Vehicle Year:
    So..... Tell us the mileage when you get the beep and first flashing!!
  13. Offline
    a64pilot New Member
    Aug 3, 2008
    Message Count:
    771
    56
    Albany Ga.
    Your Vehicle Year:
    Yesterday at 743, but then it went away for a while but was back by 750 and has been flashing since then, so I'm calling it 743. I'm a little over 800 now, happened on the way to work this morning. I am travelling with exactly one US gallon in a spare tank with funnel so I can get every drop out of it. Oh and the flashing pip started with about 20 miles left to go on the DTE? I assume the flashing pip is not triggered by the DTE getting to 0? DTE is computed by what I don't know, it doesn't seem to come from past mileage performance, but I guess it has to be pessimistic or there would be great cries about not getting the mileage they were promised by the DTE?
  14. Online
    qbee42 My other car is a boat
    Mar 2, 2006
    Message Count:
    17,752
    2,804
    Northern Michigan
    Your Vehicle Year:
    I was also under the impression that the 2010 will stop dead when it runs out of gas. There was quite a thread about it a while ago, with much finger pointing and gnashing of teeth.
    Is one gallon enough to restart a 2010? I would be worried about that.
    Tom
  15. Offline
    Message Count:
    7,495
    1,394
    Your Vehicle Year:
    You've got an 800 mile tank 'in the bag.' <GRINS>
  16. Offline
    Prius 07 New Member
    Jun 6, 2007
    Message Count:
    717
    Toronto, Canada
    Your Vehicle Year:
  17. Offline
    Message Count:
    7,495
    1,394
    Your Vehicle Year:
    Hi Tom,
    What happens is this:
    • engine finally runs out of gas - there is no "check engine" light or other indication that the last of the gas was consumed
    • car switches to traction battery power - unless you are watching the energy display or monitoring the traction battery SOC bars, you can't tell
    • traction battery reaches ~2-3 bars and throws "electronic steering" light and stops providing power - this is the really strange part that still no "check engine" light and a steering error is shown. But as soon as it stops providing traction battery power, the car only coasts. There is no way to get the car to move another foot to a safer place to park.
    My fuel exhaustion tests were:
    1. On a down grade and "electronic steering" light came on. I coasted into the parking lot at a park; added the 1 gallon; and started right up; and drove to gas station to fill-up.
    2. On an up grade at 3:00 AM and "electronic steering" light came on. I applied the accelerator and first learned there was nothing. I still had momentum and coasted into a parking lot to add the spare gallon.
    3. Making a "U turn" on I-565 where I'd been running 70 mph to run out the gas. As I turned onto the 'on ramp' and applied the accelerator, the car was sluggish and I then noticed the traction battery SOC was down one bar. However, I had traction battery power, still. I went down the "on ramp" and pulled on the shoulder and using the traction battery, went another 200 yards to be away from "on ramp" traffic. I didn't see the "electronic steering" light and still had at least 4-5 bars on the SOC indicator. I added the spare gallon and proceeded to the gas station.
    With the maintenance manual, I can find the wire that powers the electronic fuel pump. I'll put in a current 'shunt' and record the current for the next fuel exhaustion test. When the fuel pump runs out of gas, it should 'spin' and the reverse EMF cut the current flow. I can then engineer a circuit with an "OUT OF FUEL" indicator.
  18. Offline
    DrJon New Member
    Jul 13, 2009
    Message Count:
    140
    Pinetop, AZ
    Your Vehicle Year:
    What does Trip A say for MPG? Maybe you can make 900.
  19. Offline
    a64pilot New Member
    Aug 3, 2008
    Message Count:
    771
    56
    Albany Ga.
    Your Vehicle Year:
    68.1, I don't think so. I assume that's really only about 64 MPG or so? 64 x 12.5 = 800. I think there must be more than 12.5 gl. usable or I would have run out by now. I based my attempt on 12.5 gl and 64 MPG
    I could do better, this was on a whim as I would be the only driver for a while, and the wife won't play.
    By 1000 mile tank, I meant Gen III. I'm sure it's been done on the Gen II. Pretty sure it had been done by somebody on a Gen III.
    The only thing that had me real worried if it was possible to discharge the traction battery enough so that a re-start wan't possible. Seems from Bob's description, unless I'm stupid, that won't be a problem.
    Bob have you "topped it off" to see how much usable fuel capacity there is?
  20. Offline
    Message Count:
    7,495
    1,394
    Your Vehicle Year:
    My three fuel exhaustion events showed 12.1 gallons. So working it backwards:
    800 / 12.1 = 66.2 MPG (true)
    69.4 MPG indicated (using 5%)
Share This Page
