1. Offline
    xvs New Member
    Start a Conversation
    Aug 29, 2009
    52
    san francisco
    Your Vehicle Year:
    I seem to have hit a bug in the Prius firmware.
    I had a passenger in the back seat. She got out and closed the door. I think she closed it as I was already driving off.
    The yellow triangle with the ! in it turned on and a loud beep started, but there was no indication that the door was not closed properly, which was my first thought.
    Nothing I tried got rid of the warnings, until I stopped the car and power cycled it. Rebooting cleared the problem.
    Has anyone else run into something like this?
    Oh, and how do we get firmware updates?
  2. Offline
    Bobsprius BobPrius
    Jul 23, 2009
    679
    79
    Buffalo
    Your Vehicle Year:
    I would have to believe since I tried this with my car as well, while your car in in "D" just stop the car and open the Drivers Door. You will see the Yellow Triangle and ! point lighted. I would tend to believe that the person opened the door with the car still in "GEAR" thus the warning. In most cases you should hit park...it's just a second more to do that. So does it need a Firmware update?? I think it's just way it was designed. If the Triangle didn't clear something tells me the door was never relatched correctly. As once I closed my drivers door on my test the Triangle went away but NOT until it was latched correctly.
  3. Offline
    jim256 Member
    Jun 18, 2009
    317
    69
    Eastern NC
    Your Vehicle Year:
    When the triangle appears I believe there will also be a description of the issue in the Multi-Information Display. Do you recall?
  4. Offline
    • Moderator
    May 11, 2004
    14,020
    1,329
    Far-North Chicagoland
    Your Vehicle Year:
    When I have the driver's door open while in [D] I get a message that the battery can not recharge while in [N] or some other such silliness. I took a picture and it's floating around here somewhere.
Share This Page
